Old 09-24-2008, 03:14 AM   #1
dOM91's Avatar
Default Team Orion LiPO Balancing system
hey guys and girls of the RC world!
i've bought myself the Team Orion LiPO Balancing system, i had to rewire the 2S harness. then i plug my system into my PeakProdigy charger (very similar to the orginial Avionics charger) and i set it to charge. then is has a warning saying that there is no battery or that the battery circuit is open... can anyone help?
thanks dom
-Victoire ou défaite, on est toujours fiérs-
dOM91 is offline   Reply With Quote
Old 09-24-2008, 05:55 AM   #2
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
thanks dom
If you have the Avionics balancer that is plugged in to the charger then the battery is plugged in to the balancer then you need to push the button on the balancer to the charge mode. I'm not sure but after you hook everything up, you'll see the lights blink twice to show you have a 2 cell hooked up then you need to push the button and you will be in the link or charge mode, then you can start charging. Hope that helps......Check the directions to make sure, if that doesn't help you.
EA Motorsports
picco007 is offline   Reply With Quote
Old 09-24-2008, 06:01 AM   #3
FOXY923's Avatar
Are you using an Orion lipo? If so, chances are the pack is balanced and the balancer shuts off before you can turn on the charger. That happened to me so I just balance my packs off the charger every ten chargers or so.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 09-24-2008, 06:04 AM   #4
picco007's Avatar
Dom,
Just thinking, if the charger says no battery and if you have the Orion balancer between the battery and charger then you need to change the mode on the balancer. If it says open circuit, then there may be an issue with the wiring. Let us know!
EA Motorsports
Old 09-24-2008, 06:08 AM   #5
dOM91's Avatar
yaaa, i managed to get it to work, just had to read the manual PROPERLY
thanks picco
Old 09-24-2008, 06:09 AM   #6
picco007's Avatar
No prob.
EA Motorsports
Old 09-24-2008, 07:27 AM   #7
RC MARKET's Avatar
buy a balancer price can buy a with balance charger !
http://rcmarket.com.hk/index.php?manufacturers_id=107
RC MARKET is offline   Reply With Quote
Another begginer/returning question mark in wi Electric Off-Road 21 08-12-2009 08:51 PM
