What lube works best for bearings?
Ok i've heard that the white lightning sometime leaves a wax film on the bearing surface and causes them to stick a little so what do you guys recomend?
I use molybdinum (not sure if I spelled that right) grease, and it works very well.
Josh
Josh
Trinity Royal oil
tricklosi;
I personally would NOT use White Lighting for Ball Bearings. It is designed more for sliding/rubbing applications.
Trinity Royal Oil (Purple) is one of the best out there for Bearings.
For Bushings, take your pick. All of the availible brands seem to work well.
Cool, thanks for the info guys..... I'll try the trinity royal and see how it works
i usually open the bearings when cleaning(which i removed the seal) , i plan to put grease in it now, will grease causes drag?
Re: What lube works best for bearings?
well while were on the subject of bearing cleaning and maintance how about removing the old grease ? do you soak them in anything?
Try mineral spirits, it will cut the grease, but it will sink, so best if you can elevate the bearings, and let the old stuff, "drip" out.
