Corally RDX Phi 09 >
Corally RDX Phi 09
Corally RDX Phi 09
Old 06-10-2009, 01:56 AM
Pro Models's Avatar
Default Corally RDX Phi 09
Hi Guys since I haven't come across a specific thread for the new chassis I decided to open one. I just received my new kit yesterday and was wondering if any body out there has any tips or tricks we should follow before starting to build it.
It would be great to have some Team Corally drivers contributing to this thread every now and then.
I'll post some pics and give an update once I'm going through the build process.
Bye
Pro Models is offline
Old 06-10-2009, 02:01 AM
Hey bud did you buy it online?
Oblivionixx is offline
Old 06-10-2009, 02:30 AM
Pro Models's Avatar
No i picked it up from my local shop here in Malta dhiracing.com
Old 06-10-2009, 03:45 PM
I'll post a basic setup in a few days.
Rick Thomson is offline
Old 06-10-2009, 06:29 PM
~McSmooth~'s Avatar
Don't lubricate your bearings with CA glue.
~McSmooth~ is offline
Old 06-11-2009, 01:19 AM
Tip for building, don't use the standard steel balls for your differential, but you the ceramic ones. It makes your diff feel a lot better, and it holds better so you don't have to rebuild it as much as a diff with normal balls. Furthermore ceramic's don't wear out easily so you can race an entire season with just 1 set of diffballs.
Old 06-12-2009, 11:51 PM
Uziman's Avatar
Has anyone got one online?? Our first shipment to Australia is sold out and the next one is not due to next month
Cheers
Uziman is offline
Old 06-13-2009, 01:25 PM
Trader Rating: 16 (100%+)
Cheers
Anyone know when upgraded aluminum steering blocks will be available to replace the plastic ones in the kit?
Still Bill is offline
Old 06-20-2009, 03:41 AM
B4james's Avatar
I took some clearer photos of some of the new features and differences, I will post up some more soon.
Diff Bearing holders are now moulded and bulkheads are keyed to the holders
Diff is the 08 Style but now in a gunmetal anodising rather than machined look
Bulkhead now has screw that can be removed for more grip on low grip surfaces, bulkhead brace no longer screws to the chassis and is only a brace between the bulkheads
New moulded front diff bearing holders and raised top deck
B4james is offline
Old 06-20-2009, 07:59 AM
Mark506's Avatar
Trader Rating: 42 (100%+)
Bulkheads are shimmed up? That might become a tweak issue.
Mark506 is offline
Old 06-20-2009, 08:03 AM
B4james's Avatar
It is only one screw that has the shim, all the other screws on the bulkeads do not have this so tweak will not be an issue. It is purely there so can stiffen or generate a little bit more flex.
B4james is offline
Old 06-20-2009, 08:04 AM
Mark506's Avatar
Oh, Alright, I see. Thanks for clearing that up. I was kinda confused. Ill be waiting for some more pics. Thakns
Mark506 is offline
Old 06-20-2009, 09:23 AM
Pro Models's Avatar
Has anybody noticed that the rear carbonfibre bearing holder isnt flush on the bulkheads when tightening it up? it stays at an angle do I have to place washers underneath it?
Old 06-20-2009, 10:06 AM
niznai's Avatar
How do Lipos fit? Does it still have the chassis slots for Nimh?
How does it adjust belt tension?
niznai is offline
Old 06-20-2009, 10:26 AM
mickrcarver's Avatar
Trader Rating: 101 (100%+)
looks kinda cheap now
mickrcarver is offline
