Old 09-14-2003, 05:57 PM   #1
bt
Default reedy mvp
trying to rebuild reedy mvp can anyone tellme how the shims locate there are two thin shims and one thicker shim it is the thicker shim that i am wondering what end it goes on any help would be appreciated
bt is offline   Reply With Quote
Old 09-14-2003, 06:28 PM   #2
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
If the thicker shim is a brown colored one it goes on the side the comm is on.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-14-2003, 08:10 PM   #3
JoshR 85's Avatar
HeY!!!
like trinity said if it's brown then put up on top prolly where the comm is and then one one bottom. u put the brown thinker one on first by comm then a small one.
JoshR 85 is offline   Reply With Quote
Old 09-14-2003, 08:23 PM   #4
lazyboy's Avatar
Send a message via AIM to lazyboy
Originally posted by JoshR 85
HeY!!!
u need to reword that becuase some ppl would get confused. also i found out after u have it put together make sure to use shocky dioads and capacitor. for my mvp if kept it from acting weird, kinda like when u get a radio hit but the motor breaks periodicly on the strait away.
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 09-14-2003, 08:49 PM   #5
bt
Default not the brown one
no its not the brown one its three metal bushes one is thicker where does it go
Old 09-14-2003, 09:04 PM   #6
It does not really matter if there is no Brown, Just put the arm in the can and put it together, spin the arm then move it back and forth to see which side needs shims, put some shims in and repeat till the arm is in the center of the can. The you'll be flyinnnnnnn
teamAE is offline   Reply With Quote
Old 09-14-2003, 09:11 PM   #7
bt
Thanks teamAE iget what you saying except, once its in the can there is no way it will spin free
Old 09-14-2003, 09:51 PM   #8
bt
any ideas
Old 09-14-2003, 09:58 PM   #9
popsracer's Avatar
Default Motor shimming
The number of shims is irrelevant.
What you want to do is have the Armature center itself in the Magnetic Field of the Can. With approximately .004-.005 clearance in both directions (total .008-.010) for a Bushing Motor.
Any less and there will not be enough clearance when the Armature expands from heat. Too much, the Armature moves around in the can excessively and will un-seat the brushes causing a loss of Power.
The large Fibre Washer is to stop any possible arcing between the Com and Endbell Bushing or Bearing.
popsracer is offline   Reply With Quote
Old 09-16-2003, 12:44 PM   #10
speedxl's Avatar
R/C Tech Charter Subscriber
pops youre correct and on the money
pops know best!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 09-16-2003, 02:01 PM   #11
Moderator
pops, i was assuming he only had 3 shims in his motor as listed and thats generally where the shims go.
SMC Racing
Old 09-16-2003, 02:18 PM   #12
popsracer's Avatar
Default Motor Shimming
Guys;
I had many an EPIC Motor (P2K, MS, etc.) that had zero clearance on the Endbell with just the Fiber Washer and 1 thin Shim installed.
What I've done in the past is to remove the Endbell Bushing and lap the inside face down far enough to provide me with an acceptable clearance.
Some People might recommend a tighter endplay clearance, but I've found that Power and RPM is severely reduced by doing so.
Old 09-16-2003, 02:20 PM   #13
Moderator
correct pops, it will bind otherwise
SMC Racing
Old 09-17-2003, 06:58 AM   #14
seaball's Avatar
Send a message via Yahoo to seaball
i've recently started giving my motor a bit more play when i build it. though it was an entirely new motor, it did run extremely well. i am curious though.
why does the armature expand more than the can causing binding? is it an extreme temperature difference between the two? assuming both the arm and the can are some type of ferrous material, i can't find a reason that one would expand .008 - .010 more than the other. infact, that seems like an extreme amount of expansion for an increase of less than 130*F.
can someone help?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-17-2003, 08:25 AM   #15
fatdoggy's Avatar
seaball - My Mvp comes off a 5 min qualifier at about 183F, that's with a 6.5 overall on a mid sized track(not overgeared at all). I'm sure it expands quite a bit. I'm running three thin fiber washers on the pinion end and on the comm end I'm running the large fiber washer and another thin fiber washer. I'm seeing good performance throughout a whole run.
fatdoggy is offline   Reply With Quote
Futaba MC800, Reedy Neo One 6.5, Reedy Ti Mods convikt R/C Items: For Sale/Trade 6 10-08-2007 06:38 AM
Comm Lathe, NIB Reedy 19T Armature, Reedy 766 or 767 brushes, Sonic Fiddlestick Cain R/C Items: Wanted to Buy 4 06-12-2007 07:43 AM
Airtronics Synthesized-stuff,FM rec's,REEDY BRUSHESS,REEDY MOD MOTORS,etc,etc, nobike R/C Items: For Sale/Trade 89 03-22-2007 10:33 AM
JR XS3, LRP 7.1, Reedy Quasar Pro, Reedy 12 double S.Heath R/C Items: For Sale/Trade 1 10-31-2005 07:48 AM
MR-4TCSD, Reedy X-Cell 3300, Reedy Kr Randy Caster R/C Items: For Sale/Trade 9 07-03-2003 08:27 PM
