Old 09-15-2003, 01:27 PM   #16
iam going to get the quantam 2.
trf racer is offline   Reply With Quote
Old 09-15-2003, 04:37 PM   #17
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Originally posted by JesseT
To be honest there is absolutely no controller that will make your car faster than what it is with the Cyclone. Cyclone is a very good controller when it was introduced some five years ago, and it still is. During these last five years the things improved are the size and the user interface, nothing else in my opinion. I have both an original Cyclone and a Keyence zero extreme 2002 edition and they provide identical car feel, speed, ans runtime,.. you name it. However the Keyence is smaller and much easier to use. It's like having a slightly smaller cyclone with an in-built pit-wizard.
Having had one for 4 years, I'm just wanting a change. Really I'd like something smaller.
Does anyone have a link to the quantum 2? Is it even out yet? I don't see anything about it on the LRP site.
Josh
Speedo is offline   Reply With Quote
Old 09-15-2003, 07:29 PM   #18
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Ko Propo VFS-2000
Originally posted by BigDogRacing
I'm kinda diffing the KO VFS2000 or any variation of it like the Hara ESC.
Has anyone ever heard of someone having a REAL problem with a VFS2000 that didn't cause the problem themselves?
i own three of these speed controls. no problems yet. they're great because you can program them. if your in southern california, head out to socal or tamiya (if you have a tamiya car) and look for robert from ko propo.
he gave a lot of tips for setting up the VFS. i mostly run stock, but i ran mod a few times.. no problems there either. just take the normal precautions (like you would with any other esc, diodes, capacitors etc) and you should be fine.
if you can.. try to get the VFS-2000J.. it has a feature that saves a little bit of the battery just in case you sudden dump, you can move your car out of the way.
if you can, buy the esc that has a the programming unit too. i have different profiles already set up for the different tracks i race at (i.e. tamiya, so cal and oc circuit in la mirada) and i can feel the difference.
my first esc was LRP. didnt have any problems with it. only cosmetic. the paint came off the esc when i used a certain type of double sided tape!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-15-2003, 07:38 PM   #19
TFR
TFR's Avatar
Isn't all the VFS-2000J gone? I thought it was a limited edition one. I wanted to get one too, I just have the VFS-2000...
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 09-15-2003, 07:50 PM   #20
Cole Trickle's Avatar
Something different:
AFC is the active frequency control that leads to hammer hard acceleration on one hand and super smooth acting on the other. The frequency of the power FET transistors is depending on the speed of pushing the throttle stick. Fast throttle movement--> low frequency Slow throttle movement--> high frequency In the end you have more control over the car from the sticks. AFC can also be disabled.
There are some other interesting features too, like programming, and a auto run function.
Link
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 09-15-2003, 07:53 PM   #21
dux
Whoah, way cool.
dux is offline   Reply With Quote
Old 09-15-2003, 08:15 PM   #22
TFR
TFR's Avatar
Link
That's a similar feature that the new Quantum Competition 2 will have...
Old 09-15-2003, 09:19 PM   #23
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
some of the VFS 2000J's ar still floating around in Japan ...you can still get them I think..?
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-16-2003, 04:44 AM   #24
True. But the CS have been on the market for around a year, and have proven it's value. Have done well in some races. The guy I know which uses, is very satisfied, no problems at all. And I'll bet the CS is cheaper than the LRP too. Besides, why go for copies?
Old 09-16-2003, 05:00 AM   #25
TC3
TC3's Avatar
the cs rocket max is a very good speedo
TC3 is offline   Reply With Quote
Old 09-16-2003, 08:33 AM   #26
burito's Avatar
@cole trickle: copies? sure buddy...
the re-active software in the LRP QC-2 works in a very different, let's say more advanced, way then it does in the rocket-max were only stick movements get into consideration of the frequency.
information about the LRP QC-2 are going to be on LRP's website very soon.
Reto Koenig
burito is offline   Reply With Quote
Old 09-16-2003, 09:01 AM   #27
che
che's Avatar
I have been running the CS Rocket 2000 Max for over 2 years now and love it! I also have the CS Rocket 2000 (non-Max) and it is great!
I am now switching over to Mtroniks, they will be releasing a new ESC, the 'Cirrus' very shortly.
che is offline   Reply With Quote
Old 09-20-2003, 08:28 AM   #28
TC321go's Avatar
Following this thread closely and got a couple of questions:
1. I'm looking at running stock mainly and am keen on the Keyence Zero V Extreme ESC. Any other opinions or experiences on the Keyence speedies?
2. Does the Keyence speedy come with a power cap? Has anyone run theirs with a 10,000uf 10v power cap??
3. Does anyone know of any International/top-line drivers who run a Keyence speedy?
Any help would be greatly appreciated
thanks
TC321go is offline   Reply With Quote
Old 09-20-2003, 09:24 AM   #29
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
The keyence does not need a power cap, therfore it doesnt come with one.
Alex Lopez runs a keyence.
I love mine for stock and mod, very smooth and lots of punch. PLus i like the wires, probly the only guy that does lol.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-20-2003, 10:43 AM   #30
che
che's Avatar
Mike Dunnigan won the 1/12th scale ROAR onroad nats with a Keyence
What's the latest and greatest stock 27T motor ppl are running? Porkibear Electric On-Road 33 05-07-2007 01:50 PM
Might start racing again! Keep new SP1 or latest/greatest? FREAKAH Electric Off-Road 8 01-04-2007 02:41 AM
BIG REG IS THE GREATEST!!!! Big Reg Australian Racing 1 08-28-2006 03:12 AM
Latest and the Greatest Electric Tourer = Who's next? danjoy25 Electric On-Road 8 09-12-2005 08:02 PM
latest and greatest in RC controller. Uthaya Malaysian R/C Racers 4 05-21-2004 01:47 AM
