Old 09-17-2008, 01:51 AM   #1
Default Help with Futaba 3pm 2.4 setup
I have the Futaba 3pm 2.4 radio and installed a 603ff rx in my TA05. when i turn on the car with the radio on, it stays on full throttle and i have to push the trigger forward to stop it. there is no neutral. i tried looking all over google as well as this site to find out the solution but i found no info. can somebody please help.
cadeezy1 is offline   Reply With Quote
Old 09-17-2008, 02:11 AM   #2
ok i got neutral, but now when i push forward for brake it just goes right back into throttle.
Old 09-17-2008, 02:27 AM   #3
Drifting101's Avatar
Reset your speedy with the new radio, In ALL the futaba radio manuals it says reset your speedy
Reading the manual can be good sometimes
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 09-17-2008, 02:35 AM   #4
Xtant3150c's Avatar
Did you try to rebind the radio and rx?
If not try that. If you did then I would say try and reset the esc again.
I know someone at RCMH last week was having the same issues but I was'nt around to see what was done to fix it.
space for rent
Xtant3150c is offline   Reply With Quote
Old 09-17-2008, 02:57 AM   #5
Default futaba
i rebound the tx and rx and tried doing the novak one touch setup instructions for my esc but the light just stays solid red. even when i pull to full throttle or brake.
Old 09-17-2008, 04:26 AM   #6
try setting it up with the radio rather than a one touch
Schumacher
Old 09-23-2008, 10:40 PM   #7
I am having the same problem with mine and i am running a Novak Velocity5.5r and i have done everything by the manual and have reset the esc many times. Everything else works fine except the throttle. I have been doing some searching and have found many people having this problem and all are using some sort of Novak esc
ddtjr is offline   Reply With Quote
Old 09-24-2008, 06:27 AM   #8
MikeXray's Avatar
Trader Rating: 73 (100%+)
reverse the throttle channel in the radio and re do the one touch setup.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 12:12 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 02:42 PM
Suggestions for a radio setup... jbmx4life Radio and Electronics 8 10-29-2008 11:30 AM
Cen Matrix Arena Tr Fre 3nigma R/C Items: For Sale/Trade 20 11-30-2007 12:43 AM
Insane Speed Run car almost complete b4maz Electric On-Road 154 08-05-2007 11:15 AM
