Old 09-15-2008, 11:23 AM   #1
Default Tekin Redline Sensored 10.5 Motor
Yes I just pick up the 10.5 no manual.Iwant to know the FDR to start with.
I was told for all 10.5 motors to start as close as i can to 5.0 and go from there..
iceman76 is offline   Reply With Quote
Old 09-15-2008, 11:27 AM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
5.2 is a safe FDR to start
Old 09-15-2008, 02:35 PM   #3
what size track
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 09-15-2008, 04:11 PM   #4
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Jeff Cuffs View Post
what size track
Hi Jeff, it's an outdoor asphalt w/ 140ft straight...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 09-15-2008, 04:12 PM   #5
yyhayyim's Avatar
Hey Brian, why are you asking about FDR if you refuse to run the car
Old 05-08-2009, 09:06 AM   #6
C van der Hagen's Avatar
I recieved the 10.5 today, but i noticed that the 3 screws on the front are not flush with the front plate. Mounted in the car only the screws are in contact with the motormount (car), this result in a not optimal heat conduction.
Can i remove the top of the screws to avoid contact?
http://www.facebook.com/SepesRacingProducts
C van der Hagen is offline   Reply With Quote
Old 05-08-2009, 09:49 AM   #7
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by C van der Hagen View Post
I recieved the 10.5 today, but i noticed that the 3 screws on the front are not flush with the front plate. Mounted in the car only the screws are in cantact with the motormount (car), this result in a not optimal heat conduction.
I replaced mine with button screws. It's an odd design decision for sure.
syndr0me is offline   Reply With Quote
Old 05-08-2009, 06:01 PM   #8
Team Tekin
Tekin Prez's Avatar
We had not caught that. They were flush
We will call it 'proportional point loaded seismic dampening system', PPLSDS for short.
Looks like we need to adjust the endbell cut depth where screws are, or the screw heads got larger which I doubt. We are on it and it will be fixed in the next round of motors.
Checking all my older motors they are flush. Some of the newer motors are not. It appears this just came up and the machining varies some. Thank you for the heads up. We will get everything back in spec and replace any endbells that are severely off and causing problems.
Tekin Prez
[email protected]
Smarter, Smaller, Faster....
www.teamtekin.com
Tekin Prez is offline   Reply With Quote
Old 05-08-2009, 07:03 PM   #9
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
ROFL. Good to see a rep having a good bit of fun
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 05-09-2009, 09:06 PM   #10
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Exclamation
Ditto for me
All of my screws are metric, so its a bit more of a challenge to replace them.
Cheers
cosmo1974 is offline   Reply With Quote
Old 08-14-2009, 12:12 PM   #11
Skiddins's Avatar
How does the timing on the motr from the factory compare to other manufactures?
The notch on the plastic endbell is lined up with 14deg as marked on the can.
Should I leave it and undergear it or put it to 0 then start gearing as normal?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-14-2009, 12:41 PM   #12
Skiddins
It's standard on 12
I drove it with 12 on the motor and my Tekin RS Pro with Turbo and lipo.
I geared it on a big track on 6,3FDR
15 Boost and max Turbo.
The other drivers used a FDR of 5,7 or lower.
Only 1 SPX with 10,5 LRP was using 5,7FDR, all the others used 5,2FDR and the TC drivers 4,7FDR.
I gear my motor lighter than the others because than the Tekin is faster.
You can also set it to 0 on the motor.
Than you have some more acceleration power.
On big tracks I like more timing on the motor but the smaller tracks or tracks with a tight infield I use a lower till 0 motor timing.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-16-2009, 05:44 AM   #13
2wdrive's Avatar
Received the tekin 10.5t yesterday and it got the same thing. The screws werend flush with the front plate and another thing was that two of the screw holes where the motor mount screws go had small burrs in them
No big problem, I changed the screws in buttonhead screws on the front plate and i carefully cut the burrs off with a knife. The motor mount screws could get in perfect afterwards but at first it looked a little sloppy when i received the motor. For the rest the motor looks pretty. Haven't tried the motor yet.
2wdrive is offline   Reply With Quote
Old 08-16-2009, 10:00 PM   #14
PPLs what??? Jim you need to get out of the office for a day and go ride your mtn bike up a hill!!!! LOL Jim are you and randy comin down for the tri-state? Utah is gonna put a whoopin on you ho's (IDAHO's) from up north
Speedpassion USA Team Driver
Schumacher USA Team Driver
Lucky 13 rc graphics
Remember this..... Heaven and Hell are really not places, just your state of mind.
JdogL is offline   Reply With Quote
Old 08-20-2009, 03:08 AM   #15
Taffyjnr5's Avatar
Hi,
This might be a little off topic but I have just picked up a 17.5 Tekin Redline motor and wondering what gearing should I start with. The Novak site says their 17.5 to gear it at 3.5 FDR is that correct or close to the mark............
Taffyjnr5 is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Sydney Model Autosports Inc [smaracing.org] The Ideas Man Australian Racing 25432 10-18-2017 12:09 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
