Old 10-14-2008, 05:27 PM   #16
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
The TiN tips are hardened (spring) steel. The tips are then hardcoated with the TiN. If you look at a black oxide coated tip on a kit allen wrench you can see where an allen wrench wears. It willl be shiny near the sharp points. In the smaller size this wear eventually causes the tool to strip out or round off. I find the TiN Integy tips are the best available as far as not tending to round off and they last a long time. Hardened steel does tend to be a little brittle. If you bend the tool to the side hard enough you will snap that .050 tip off. With care you do it less often. Once in a while a stubbornly stuck screw is just too much for the small size. I keep a spare .050 inch (part #C22671)and 1/16 inch tip in the box. These are available for less than $3.00 at Tower. I would rather snap off the tip of a good hard tool than round off the screw hole using a softer tip. It is a much faster repair replacing the tip.
john
John Stranahan is offline   Reply With Quote
Old 10-14-2008, 05:30 PM   #17
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Originally Posted by John Stranahan View Post
The TiN tips are hardened (spring) steel. The tips are then hardcoated with the TiN. If you look at a black oxide coated tip on a kit allen wrench you can see where an allen wrench wears. It willl be shiny near the sharp points. In the smaller size this wear eventually causes the tool to strip out or round off. I find the TiN Integy tips are the best available as far as not tending to round off and they last a long time. Hardened steel tends to be a little brittle. If you bend the tool to the side hard enough you will snap that .050 tip off. With care you do it less often. I keep a spare .050 and 1/16 inch tip in the box. These are available for less than $3.00 at Tower. I would rather snap off the tip of a good hard tool than round off the screw hole using a softer tip. It is a much faster repair replacing the tip.
john
Well..hopefully I don't have any issues.....
y2kgtp is offline   Reply With Quote
Old 10-14-2008, 05:35 PM   #18
They will do fine. I would still by a spare tip for the tiny ones.
::AE Factory Team T4/J82::Pristine::Spared no expense! Catalyst R/C Items: For Sale/Trade 20 05-01-2009 11:20 PM
Getting Out. Everything must go. Rob Mincey R/C Items: For Sale/Trade 52 04-08-2005 05:32 PM
Clean Up Sale!!! 2Lmon R/C Items: For Sale/Trade 18 04-01-2004 09:17 PM
