Old 09-15-2008, 04:51 AM   #1
Born2Run's Avatar
Default I NEED SOME HELP PLEASE
Im running a XRAY T1FK05 on foams ,spool in front,sway bar and stiffer springs in front , loosen differential on rear with softer springs without sway bar and im losing my rear end coming out of the 180' corner.Any suggestion will be very helpful.
Whatever
Born2Run is offline   Reply With Quote
Old 09-15-2008, 05:09 AM   #2
ummmm
maybe more toe in, try a sway bar, or even your springa my be to soft on the rear, and also chek your ride hight that your rear is higher then the front
rcmad2700 is offline   Reply With Quote
Old 09-15-2008, 05:14 AM   #3
Born2Run's Avatar
Toe in is already 2' .Ride hight 5mm front 6 mm rear.I think with a sway bar on rear it will be worst.
Whatever
Old 09-15-2008, 06:37 AM   #4
todd8603's Avatar
Default Some help
You may try this;
1) decrease front uptravel(droop). Possible that so much weight moving rearward that the rear chassis is touching causing a slide out. possible but relatively unlikely
2) Raise rear roll centre - ie insert 1.5mm spacers under hub end of camber link. this is somewhat counterintuitive but has worked in past for me.
3) check tweak - If you get a chance, run the same corner in the opposite direction to determine if the car acts the same way.
4) camber links - switch from shorter to longer or the other way. No change effect is cut in concrete so may be worth trying. The shorter link should give more camber gain s a result better tracking but worth testing.
todd8603 is offline   Reply With Quote
Old 09-15-2008, 09:39 AM   #5
Drew Ellis's Avatar
Is this foam carpet if so all these are good ideas but the main thing is take the spool out and put in a diff that will help a lot...Later Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 09-15-2008, 12:36 PM   #6
Born2Run's Avatar
Thanks for your help guys.I'll start trying these setup changes one by one.
Whatever
Old 09-15-2008, 02:43 PM   #7
corallyman's Avatar
Trader Rating: 99 (100%+)
This may sound kinda stupid but are you using tire traction on the foams? As good as foam tires are on carpet, you still need the "sauce". Sometimes this is overlooked by new racers.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 09-15-2008, 03:32 PM   #8
snoopyrc's Avatar
My Yoke was doing that. Three degree toe in on the rear took most of it out.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 09-15-2008, 11:00 PM   #9
Born2Run's Avatar
Steve
Yes i use Trinity Red Dot or Nosram traction additive asphalt.Without the "sauce" is even more difficult to turn as the traction is not so good.
Whatever
Old 09-16-2008, 01:09 AM   #10
corallyman's Avatar
Both of those are asphalt traction additives. Are you allowed to use Paragon. Paragon works the best on Carpet but it has a wintergreen smell to it so its banned at a lot of indoor tracks but the stuff is great. If you can't use that then use Jack the gripper. Once you use the correct carpet traction I bet most of your problems will be gone.
Steve
Old 09-16-2008, 01:13 AM   #11
corallyman's Avatar
Steve
I just re read your original post again, just to be clear are you running carpet or asphalt? Indoor or outdoor, the more info the better your responses can be. lots of people willing to help, we just need to know more.
Steve
Old 09-16-2008, 02:27 AM   #12
Born2Run's Avatar
Sorry my mistake. I had to give some more info.Im running outdoors on asphalt (parking lot with not so good traction).I know Paragon i have use it in past.Smell is not a problem at all.
Whatever
Old 09-16-2008, 08:49 AM   #13
Little_Mike's Avatar
Rule of thumb: Run a front diff with foams on carpet
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 09-16-2008, 01:41 PM   #14
Born2Run's Avatar
OK but im running foams on asphalt not on carpet.
Whatever
Coral Springs On-Road Track yyhayyim Florida Racing 1646 01-12-2014 07:32 AM
R/C Stuff Wanted Kenneth Tan Singapore R/C Racers 10018 09-09-2009 08:32 AM
Help with tyres please. Limerick91 Electric Off-Road 7 03-24-2009 04:18 AM
Need Some Help Please!!! meronr Nitro On-Road 10 09-09-2008 04:24 AM
SOUTH FLORIDA ONROAD RACING iceman76 Nitro On-Road 44 11-25-2007 08:09 PM
2006 CORCS Canadian National Final goatman Canadian R/C Scene 230 09-17-2006 10:31 AM
MI2 Steering problem brakkie Electric On-Road 6 02-13-2006 07:01 PM
