Old 08-02-2005, 06:27 AM   #1426
zax
zax's Avatar
Originally Posted by Phenochilus
Tobee craft as in http://www3.kcn.ne.jp/~tobee/English.htm
Tamiya don't make them at that size. Smallest for the tb-02 is the f1 high speed gear set which has the 52t spur.
The 49t spur is a must have if you're racing 540 silver can motors and a high speed track.
You might want to check legalities if you race in TCS though.
WHERE TO FIND AND WHICH BRAND IS THE 49T SPUR GEAR?
zax is offline   Reply With Quote
Old 08-03-2005, 12:30 AM   #1427
ford_racing's Avatar
Send a message via MSN to ford_racing
Tobee Craft make it, I think Kawada also makes it, I know they make the pinions
www.kawadamodel.co.jp
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 08-03-2005, 02:58 AM   #1428
zax
zax's Avatar
if i use kawada 49t spur..can i use tamiya pinion gear?
Old 08-03-2005, 03:12 AM   #1429
no, Tamiya doesn't make pinions big enough to work with the 49tooth spur.
Tamiya stops at a 25 tooth pinion, you can use the kawada pinions though
ARC R11
Yokomo YRF001
AE B5m
Old 08-03-2005, 03:29 AM   #1430
zax
zax's Avatar
so i use kawada pinion and spur...do i need to change anything on the TBO2R car?
Old 08-03-2005, 04:18 AM   #1431
I believe thats all you need, the TB02R is a great car, I just wish I got that instead of my TB02
ARC R11
Yokomo YRF001
AE B5m
Old 08-03-2005, 04:27 AM   #1432
zax
zax's Avatar
but the kawada spur is same wit tamiya spur adapter?
Old 08-03-2005, 06:18 PM   #1433
I use the Tobee craft 49t spur. Kawada only makes the pinions up to 28 tooth I think.
So you can use the Kawada 28 tooth pinion with the Tobee craft 49 tooth spur gear which gives you a 4.53 gear ratio.
If you want to run 4.13 gear ratio you need to buy a Tobee craft 31 tooth pinion.
Datum is offline   Reply With Quote
Old 08-03-2005, 07:09 PM   #1434
im pretty sure i've seen kawada 31tooth pinions but i may be wrong
ARC R11
Yokomo YRF001
AE B5m
Old 08-04-2005, 02:45 AM   #1435
zax
zax's Avatar
so TBO2R can use KAWADA pinion gear and KAWADA spur gear?
Old 08-04-2005, 03:08 AM   #1436
it sure can
ARC R11
Yokomo YRF001
AE B5m
Old 08-04-2005, 04:01 AM   #1437
zax
zax's Avatar
Default THANK YOU..
NOW I KNOW ALREADY..THANK YOU EVERYBODY THAT TELLING ME SO MUCH...THANKS..
Old 08-05-2005, 11:04 PM   #1438
zax
zax's Avatar
Default PIC
HII EVERYBODY..CAN U ALL POSE YOUR TBO2 PIC THERE..THANKS.
Old 08-11-2005, 03:28 PM   #1439
Does tamiya make a CF top deck to go on the TB02?
Seatbelt is offline   Reply With Quote
Old 08-11-2005, 05:12 PM   #1440
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
does anybody have any set ups for the TB O2R?( asphalt)
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
