Old 06-08-2005, 02:44 PM   #1381
stonedgti's Avatar
Trader Rating: 15 (100%+)
Does anyone know what kind of motor we're running at the Nats for GT2? Also, are we allowed to use the hi speed 52spur from the f201 in GT3?
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 06-08-2005, 06:44 PM   #1382
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
the 52 spur was used last year. I would think if we run silver cans it would be fine.
As for Nats motors. I would assume that the silver can would be the choice. The black cans found to be short lived, for a weekend of racing, where as the silver can is hearty, and can hold up all weekend.
tamiyarcracer is offline   Reply With Quote
Old 06-08-2005, 07:05 PM   #1383
stonedgti's Avatar
What pinion gear do you use with a 52 spur? 27 teeth or does tamiya make bigger ones?
Old 06-08-2005, 07:32 PM   #1384
27, 26, and 25.
I would love something bigger, but haven't found one.
27 tooth makes the ratio just about right.
Old 06-08-2005, 09:18 PM   #1385
Hebiki's Avatar
Trader Rating: 26 (100%+)
yah i have a black can that just blew up on me...and it was in my brush serrator!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-09-2005, 09:05 PM   #1386
rayhuang's Avatar
Hey all-I wanted to let you guys know my TCS regional winning TB02 will be on the for sale forums in a day or so. Its a tricked out TB02 and a EvoIIISE all in one. I need to buy a ton of Tamiya parts, tires and bodies and need to free up the cash. I hate to see it go.
Old 06-10-2005, 03:35 AM   #1387
rayman's Avatar
27/52 is 5.01. Is that the lowest a silver should be geared? I havent' found any metric pinions higher than 25T. What brand is it?
rayman is offline   Reply With Quote
Old 06-10-2005, 03:58 AM   #1388
ford_racing's Avatar
Send a message via MSN to ford_racing
There i sKAWADA model company and
GPM racing products, both these companies make 26 and 27 tooth pinions with Kawada making upto 31 tooth
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 06-10-2005, 06:27 AM   #1389
I bought a 28t kawada pinion in the metric pitch, And it was smaller than my tamiya 27t I tried another brand to (forgot who) and again it was smaller.
Old 06-30-2005, 05:13 PM   #1390
Hawk6's Avatar
Trader Rating: 50 (100%+)
Default Building a TB-02
I've got a TB-02 I'm ready to build. Hopefully, this will be my entry into the 2006 TCS at Trackside. So, I want to build it carefully and practice during the summer and fall.
My questions are:
Should I add sway bars while I'm building? Or, aren't they needed? Or, are they easy to add later?
What about shock oil? 50 all around? 60 in front, 40 in rear? Something else?
Should I get hex screws? If so, where can I get some? Or are the Tamiya Phillips heads OK. I've read that it's worth it to buy a Tamiya metric screwdriver. Any thoughts?
Anything else I should know before I start building?
Thanks.
Hawk6 is offline   Reply With Quote
Old 06-30-2005, 05:32 PM   #1391
westerdude42's Avatar
Hex screws are nice. Tamiya makes shock oil. The soft works well for me. I started out with sway bars, and took them off. Everyone I run with told me to build it to kit specs and drive it. Adjust after that.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 06-30-2005, 05:41 PM   #1392
Hebiki's Avatar
My questions are:
Thanks.
id buy hex TI screws for the motor mount since this will get a lot of use/wear. switch over to any type of hex (steel or Ti) and you'll be okay. the stock screws suck.
Hebiki Design Works
Old 06-30-2005, 06:33 PM   #1393
You've bought the wrong ones. Kawada make the 0.6 28t pinion which will match the f201 52t spur gear.
PNB-628
http://babelfish.altavista.com/babel...model.co.jp%2f
You can also get 0.6 29t to 31t pinions to fit a 49t spur gear from tobee craft.
The 49t spur gear holder and spur gear part no's are:
42710 TB02-05 Aluminum gear holder (Light blue)
41190 TB01-05 Spur gear 49T
Phenochilus is offline   Reply With Quote
Old 06-30-2005, 06:44 PM   #1394
Hawk6's Avatar
So where can I get hex screws for the TB-02??
rcscrewz.com only advertises TB-01.
Can someone post a specific source?
Thanks again.
Old 06-30-2005, 06:50 PM   #1395
My questions are:
Thanks.
Don't over tighten the screws, the screw holes can strip pretty easily especially the gear box ones and upper arm mounts.
Buy a pack of Tamiya 53587 5mm shim set to shim out the slop in the wheels.
Buy the 53570 clamp type aluminium wheel hubs (4mm thick). You'll find that the plastic ones won't last long and after a few crashes, your wheels will wobble like jelly.
Make sure the bearing behind the bevel gears is seated properly - otherwise you'll get binding of the drive train.
Sway bars are easy to add later, best to build the kit and run with no sway bars first.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
