Old 05-01-2005, 06:26 AM   #1336
Ghost-Rider's Avatar
yo RC driver Gary
Episode III
Ghost-Rider is offline   Reply With Quote
Old 05-09-2005, 12:16 AM   #1337
rayman's Avatar
Aluminum motor mount got too hot and distorted the plastic chassis its mounted on and gearbox cover beside it. Anyone experience this? Its very hot here in the Philippines.
rayman is offline   Reply With Quote
Old 05-09-2005, 01:20 AM   #1338
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
mine get some crack on the chassis screw. Over tighten when its hot
KREATOR1 is offline   Reply With Quote
Old 05-09-2005, 09:29 PM   #1339
rayman's Avatar
maybe its not a good idea to install motor mount and just use the motor heatsink coz the material is plastic.
Old 05-10-2005, 05:29 PM   #1340
dsrbltoys's Avatar
depends on motor. If its a silver can. I use a heatsink, or the reedy heatsink fan. If its a roar stock type motor, the heatsink will cover the holes that allow air to pass through the motor, and not allow it to stay cool.
dsrbltoys is offline   Reply With Quote
Old 05-12-2005, 09:07 PM   #1341
rayman's Avatar
But do you use the aluminum motor mount? Its mounted on plastic which it melted on mine.
Old 05-16-2005, 03:40 AM   #1342
rayman's Avatar
any idea?
Old 05-16-2005, 03:58 AM   #1343
westerdude42's Avatar
Default Heat sink
I use an aluminum motor mount and no heat sink when running a 27 turn. With a silver can I run with the heat sink and aluminum motor mount. No problems either way.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 05-16-2005, 04:00 AM   #1344
Default Heat sink
What motor were you running when you melted the chasis?
Hedgehogs rule!!!
Old 05-16-2005, 05:37 AM   #1345
rayman's Avatar
Default Re: Heat sink
was using type s with 55 spur and i think 23t pinion
Old 05-16-2005, 09:19 AM   #1346
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Default Re: Re: Heat sink
That might have been the issue there. Heck the black cans get pretty hot with a 55 / 25. You might have too low of gearing for the Type S motor. Try the 22 pinion, or a 61 and as big of a pinion as you can go with it.
tamiyarcracer is offline   Reply With Quote
Old 05-16-2005, 01:13 PM   #1347
Post Heat sink
I am running a 58/19 with a 27 turn motor. When I went to a 58/20 it started to get to hot. On the other hand I run a 52/27 with a silver can and it's no problem. I have no experience with the black cans but many of the guys here run TCS Canada where that is the motor. I was just curious what motor you were running with that gear combo.
Hedgehogs rule!!!
Old 05-16-2005, 01:18 PM   #1348
The type s is a 23 turn
Old 05-16-2005, 03:21 PM   #1349
Post Type S
Thank you. They ran those at the Atomic Hobby indoor series. Was it the Red or the Blue writing on the can. When my friend ran his it was the blue endurance version and he always kept his ratio in the 8's. It sounds like it was just to high a gear ratio for the motor. I would ask dsrbltoys or Tamiya Racer on this one they are excellent with gear ratios and I've never run that motor.
Hedgehogs rule!!!
Old 05-17-2005, 04:29 AM   #1350
rayman's Avatar
Default Re: Re: Re: Heat sink
So you mean that my gear ratio is too high and that I should make my gear ratio lower maybe in the 7.2 to 8 range? I've attached a pic where the recommended gear ratio for type s motor is. Tell me what you think guys.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
