Old 12-05-2003, 05:18 PM   #121
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default Tub Chassis Material
Is it the same material as the TA04-R Tub Chassis or your standard plastic?
Izzy
izzyracer is offline   Reply With Quote
Old 12-05-2003, 06:35 PM   #122
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Supersonic, Not sure about a 54 in 48p, but the F201 has a 52p, in the tamiya metric pitch. see if you can work with that. The biggest pinion I know of in the Tamiya pitch is 27.
Izzy, the whole car is out of a plastic, it seems different than regular plastic, but I guess it is the same as the gearboxes on the EVO3S. It cuts differently than regular plastic, but not as hard as the hard arms.
tamiyarcracer is offline   Reply With Quote
Old 12-06-2003, 04:17 AM   #123
supersonic's Avatar
Izzyracer, the car is made out ABS plastic, it tells u this on the tamiya usa site if u want to check out some info on the car.
tamiyarcracer i was thought there might be a 28t pinion, Is the 27t pinion only in tamiya brand or is it in the other brands
supersonic is offline   Reply With Quote
Old 12-06-2003, 08:58 AM   #124
I know that for the metric .04 or .06 (which ever is the course gears) module as tamiya calls it, tamiya has a 27, but no 26 then the have 25 and down, THe 26 I use is a HPI pinion, and I heard rumors years ago that Kyosho had a 27 mut I have never found it.
As for the plastic issue, it might say abs, but it is a different mix than other abs plastic parts I've worked with.
Old 12-07-2003, 08:30 PM   #125
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
TB02 Gear mesh
Hello All,
recently finished my 02 and noticed the car is very noisy compared to my EVO3....
So is this a function of 48 vs. 64 pitch gears or the plastic chassis acting as a drum?
anyone else running into the same situation?
thanks,
JC
madjack is offline   Reply With Quote
Old 12-07-2003, 10:10 PM   #126
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Does anyone know if the tub is available for sale yet? Also is the battery hold down bar available as well?
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 12-07-2003, 11:21 PM   #127
Larry, I'm not sure if Tamiya America has them yet. But they should soon.
I notice mine was a tad noisy, but I figure it is the gear mesh was a tad off, seeing as I'm running a 52t from a F201 speed tuned gear set, and tring to get the 27 tooth to best fit, with the included holes.
Old 12-08-2003, 12:22 AM   #128
madjack's Avatar
Post gear mesh
Troy?
I'm running the stardard Tamiya spur & pinion which equates to a 6.85...but the beast is WAY loud.
(even louder than my Cuda with the stock Xenon spur)
Have you tried to run the EVO3 adaptor yet? I was giving it some thought, but not with 64 pitch gears....thinking the chassis has too much flex for that gear mesh.
BTW the blue convertion looks good on your car. I canibalized my EVO for GT2 since it appears that the 415 might be the weapon of choice in GT1 this year.
JC
Old 12-08-2003, 12:23 AM   #129
madjack's Avatar
Post TB02 parts
I know Tamiya America had the majority of the hop-ups in last week...not sure if the standard parts are in the invt. yet?
Old 12-08-2003, 06:06 AM   #130
Yes sir You guessed tha name correctly. I am very pleased with the car.The noise on mine is getting quieter, maybe as the gears mate to each other.
So I'm guessing you thinking hard about GT1 this year?
Old 12-08-2003, 07:35 PM   #131
madjack's Avatar
Post TB02 sway bars
Anyine having problems with the front suspension binding up due to the lack of clearance when running the larger sway bars?
Looks like is is time to break out the old dremel.
Old 12-08-2003, 07:57 PM   #132
John, in the instructions It says to open the slot up, on the hold down. Did you miss it???
Old 12-08-2003, 11:38 PM   #133
madjack's Avatar
Don't have the kit, just the tub and parts tree
Old 12-09-2003, 06:18 AM   #134
So dear sir, please dig out your dremel, and hog away! (as the instructions recomend) ;-)
Old 12-09-2003, 11:22 AM   #135
izzyracer's Avatar
MadJack :-)
Can you use the steering arms from the EVO 3 Limited/Surikarn with the TB02 Tub? or you have to use the steering arms form teh TB02?
Izzy
Izzy
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
