Old 03-10-2005, 05:44 PM   #1216
dsrbltoys's Avatar
Biggest change I see is you moved rear arm back, which took all the weight off the rear of the car, and less rear traction. Otherwise looks good. So the first thing would be move arm forward again (like when you got the car )
dsrbltoys is offline   Reply With Quote
Old 03-10-2005, 09:39 PM   #1217
The inner hole on the arm is prolly the major point it softens the front suspension too much. Prolly point loads the suspension way too fast. Before you do anything else move the lower out on the arm and resume testing.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 03-10-2005, 11:25 PM   #1218
Korey Harbke's Avatar
I agree with the D-man, that was the first thing I noticed.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-11-2005, 10:02 AM   #1219
rayhuang's Avatar
Dan, Kevin and Sushi-thanks!! WIll do on wheelbase and front shocks. Resume testing THhursday night!!
Ray
Old 03-13-2005, 01:06 AM   #1220
nitro_D's Avatar
Thumbs down Missing screws
I got a TB-02 yesterday with the Impul Z body . When i was building it i noticed that i couldnl't find some king pins that go into the caster blocks . The screw that has a ball end, then a cylinder type thing then a screw thread . Do i have to make this up or should it be included and it was the factories fault.
Thanks.
I bought it for drifting and im getting impacient!!
nitro_D is offline   Reply With Quote
Old 03-13-2005, 08:39 AM   #1221
RCGaryK's Avatar
If it's the combined kingpin screw/ball stud, no, It should have been included.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-13-2005, 05:03 PM   #1222
purplepro3's Avatar
Originally posted by rayhuang
TB02 set-up when it was spinning out in high speed corners.
Front
shocls 60 wt Trinity oil Purple spring. Out on tower, in on arm.
Camber link middle hole on alum mount raised 4mm (angled dwon very steep).
4-deg caster, a/a blocks. BLue sway bar. 2mm uptravel for droop. Arms all the way back.
Ride height 4.5mm , camber 2, type A tires on grey rims and hard insert-full air gap. Sauced half with Paragon FXII
Rear
Shocks 50 wt Trinity oil Grey springs. Out on shock tower-out on arm.
Camber link is long on camber plate raised 1mm. Long on hub. LInk is pretty flat.
Yellow sway bar, stock hubs. 2.5mm uptravel for droop.
Arms 4mm back, a/b blocks. Ride height 5mm , camber 2, type A tires on grey rims and hard insert-full air gap. Sauced full with Paragon FXII
Body is NIsmo Skyline .
Let me know if I left anything out. OH_I would also traction roll if I even nicked a flapper. if I didnt touch a flapper-car wouldnt flip-probably because the car would slide instead of lift.
I also have now gone to 2 deg rear hubs, red rear sway bar and reduced droop all around. Also planningn on going to 3 deg rear camber..
even the F-R ride height to 5mm
purplepro3 is offline   Reply With Quote
Old 03-13-2005, 05:36 PM   #1223
nitro_D's Avatar
Default missing screws
So if it was meant to be included what should i do?
Old 03-13-2005, 06:57 PM   #1224
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Default Re: missing screws
who did you buy it from?
madjack is offline   Reply With Quote
Old 03-13-2005, 08:09 PM   #1225
nitro_D's Avatar
My lhs RC Champ Advisor
Old 03-15-2005, 04:38 AM   #1226
P956LH's Avatar
Hey guys,
How should I shim the diff bearings (the 10x15mm ones) if I'm running Evo3 delrin diffs on both ends? should I stick with the TB-02 kit setting (0.1mm on both sides) or change the shimming (to loosen the bevel-diff gear mesh)? I'm running an MVP with 58/20 gearing...will loosening the mesh bring the danger of stripping gears?
P956LH is offline   Reply With Quote
Old 03-15-2005, 11:31 AM   #1227
RCGaryK's Avatar
Give them a call and say you were missing parts from your kit. It is pretty rare with Tamiya kits, but it does happen from time to time. In think in nearly 20 Tamiya kits I've bought and built, I only had parts missing from one (the diff balls, thrust bearings, and the screw were missing).
HorizonHobby.Com
Old 03-16-2005, 01:06 AM   #1228
nitro_D's Avatar
I dont speak japanese. Im going to my lhs this weekend so ill just buy some. Only 100 sumthing yen
Old 03-16-2005, 10:11 AM   #1229
rayhuang's Avatar
Thanks for all your help guys. I have added rear camber to the car (2+), moved out on arm on front shocks, added rear toe in via a/b blocks and 2deg hubs, moved my rear arms full forward. if it pushes but is other wise planted and balanced-I think I will be able to make adjustments from there.
I am also bringing a brand new set of type A's to run as well.
Thought of another question. What should the ehandling difference be between the Skyline body and the Acura 2003 NSX?
Thanks in advance,
Ray
Old 03-16-2005, 10:50 AM   #1230
chrisman's Avatar
Send a message via MSN to chrisman Send a message via Yahoo to chrisman
Originally posted by tamiyarcracer
Pancit???
mmmmmm Lumpia
Better have enough for everyone at nationals!
Me too...I may make it this year...
CHRIS LIM
OVERGEARED RACING
chrisman is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
