Old 03-07-2005, 10:35 PM   #1201
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by dsrbltoys
Wow, once again the trash talk has started for tcs nats, we only have had 2 races so far. Bring it on
I race my TB02 in gt1 a lot. I have a fix for the stripped gear PM me Ian.
kevin.. willing to share? if you are... im on AIM. hit me up
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-08-2005, 12:57 AM   #1202
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
KEV... I personally had not have this problem in my TB02. Not sure why Jasper and Chris' car seems to strip quite a lot... hmmmm...
Thanks for the help in advance! BTW, Mr. Katzer started the trash talking as usual...
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 03-08-2005, 01:44 AM   #1203
RCGaryK's Avatar
WHAT?!?!?! What-ever you has been you
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-08-2005, 05:33 PM   #1204
Hebiki's Avatar
i guess kevin doesnt want to help me
no lumpia and pancit for you mr. kevin m!
Hebiki Design Works
Old 03-08-2005, 06:23 PM   #1205
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Pancit???
mmmmmm Lumpia
Better have enough for everyone at nationals!
tamiyarcracer is offline   Reply With Quote
Old 03-08-2005, 08:05 PM   #1206
dsrbltoys's Avatar
He could share!
dsrbltoys is offline   Reply With Quote
Old 03-08-2005, 08:56 PM   #1207
rayhuang's Avatar
Default rear traction help
Hey guys,
I ran my tb02 last practice night -only chnages from previus week when the car just had tons of roll-but was other wise planted was go to purple frnt and grey rear springs. After tires warmed up-it wold spin out in any fast corner and NOT sharp corners.
So-of course I put some soft rear springs on it-no chnage still spun out.
Any ideas? Is it possible the tires just gave up the ghost -I dont know the total number of runs on them.
For chnages i put the 2 deg hubs on and a-b block, softened up the sway bar from yellow to red and put the grey springs back on.
Again-understand-I dont run rubber tires. Thsis all greek to me.
Old 03-08-2005, 11:02 PM   #1208
westerdude42's Avatar
Default Ray
What letter blocks are you running in the rear?
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 03-09-2005, 12:19 AM   #1209
Hebiki's Avatar
Default Re: rear traction help
Originally posted by rayhuang
Hey guys,
i had a similar problem on sunday's TCS. i asked a local TRF driver. (Ling Kang Tong, 2004 GT-1 National Champ)...and he noticed how short the camber links were in the rear. i made the rear camber links longer..and it really settled the car down.
Hebiki Design Works
Old 03-09-2005, 07:54 AM   #1210
rayhuang's Avatar
Default Re: Ray
I started the evening with the rear block a/b and zero degree hubs and the camber link long and raised 1mm on the vertical ballstud. It wasnt loose at all the previous week like that.
Also interesting is cars got tons of steering-even with a 5 to 6' turning circle. No doubt as its so loose.
Thanks guys for the tips,
Ray
Old 03-09-2005, 09:38 AM   #1211
Default Ray
I ran Saturday with 2 degree hubs and an A/C block setup. I stuck like glue and finished nicely.
Hedgehogs rule!!!
Old 03-10-2005, 12:03 PM   #1212
dsrbltoys's Avatar
Default Ray?
Where did you find 0 deg hubs?
Tamiya only makes 1 deg in two types of plastic, and an alloy. Then a plastic 2 deg.
What is the rest of the setup? you said you went to grey, what did you have?
Old 03-10-2005, 12:09 PM   #1213
rayhuang's Avatar
Default Re: Ray?
OH-sorry-must be 1 deg huubs then in back with a/b blocks. I'll post up the rest of the set-up soon..
Old 03-10-2005, 01:44 PM   #1214
Ray if it is the Alu rear hubs with the 3mm hinge pin then they are 1d hubs. If it is the LW suspension with the 2.6mm hinge pin then it can be a 0, or 1d hub. The 0d hub came with the Worlds upgrade with the XA etc. blocks.
All that said you should have the 1d rear hubs. You might look at doing a couple of things with the car.
1. Go to the middle hole rear hub and raise the link to 2mm. This will help get some camber gain as the car rotates through the corner.
2. Move the front arm forward 1-2mm to transfer some weight off of the front of the car.
3. Move the rear arm forward 1-2 mm to again transfer more weight over the rear axle.
4. Not sure where you have the front link under spacing at but you might need to raise 1-2mm to bleed some of the midcorner traction. It might come at teh expense of having a harder turn-in initially. Also remove arm sweep if you have some in.
Try them all in order of 1-4 and see what helps. The tires could be some of it but it should not degrade that fast.
Also check the usual that there is no parts rubbing in the front or body dragging.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 03-10-2005, 02:19 PM   #1215
rayhuang's Avatar
TB02 set-up when it was spinning out in high speed corners.
Front
shocls 60 wt Trinity oil Purple spring. Out on tower, in on arm.
Camber link middle hole on alum mount raised 4mm (angled dwon very steep).
4-deg caster, a/a blocks. BLue sway bar. 2mm uptravel for droop. Arms all the way back.
Ride height 4.5mm , camber 2, type A tires on grey rims and hard insert-full air gap. Sauced half with Paragon FXII
Rear
Shocks 50 wt Trinity oil Grey springs. Out on shock tower-out on arm.
Camber link is long on camber plate raised 1mm. Long on hub. LInk is pretty flat.
Yellow sway bar, stock hubs. 2.5mm uptravel for droop.
Arms 4mm back, a/b blocks. Ride height 5mm , camber 2, type A tires on grey rims and hard insert-full air gap. Sauced full with Paragon FXII
Body is NIsmo Skyline .
Let me know if I left anything out. OH_I would also traction roll if I even nicked a flapper. if I didnt touch a flapper-car wouldnt flip-probably because the car would slide instead of lift.
I also have now gone to 2 deg rear hubs, red rear sway bar and reduced droop all around. Also planningn on going to 3 deg rear camber..
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
