Old 03-06-2005, 06:49 PM   #1186
RCGaryK's Avatar
The big question is how serious do you want to get? If you just want to run the spec tcs classes, then the tt01 is just fine. For serious racing in like the gt2 or 3 classes, I would say the TB-02 would be better because it's more of a race bread machine.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-06-2005, 07:52 PM   #1187
RCGaryK's Avatar
This is off of the Tamiya USA site...directly answers many questions:
The TB-02R Chassis Kit was developed with the goal of providing an affordable chassis that still had the power to achieve top ranking finishes in Tamiya Grand Prix. Using the basic design of the TB Evolution III gearbox, we have applied the minimum amount of tuning to achieve a versatile and reliable new chassis. The TB-02R is fully adaptable with a wide variety of optional parts, expanding its potential to compete against even the fastest high-end machines.
New Parts
- Uses front and rear upper braces, (bathtub frame is connected by two 2mm carbon plates, strengthening torsional rigidity and lightening weight).
- Uses 2mm thick carbon battery plate, with TB-02R mark.
Standard Features
The TB-02R chassis comes with the following items and features:
Lightweight reversible suspension. (same one used in 415MS and TB EVO 4 kits)
Full ball bearings.
universal swing shafts
front and rear carbon plate chassis stiffeners.
Front and rear stabilizers (medium hardness).
Aluminum motor heat sink (blue).
Lightweight propeller shaft (blue).
Tires are a combination of medium narrow type A and molded inner type S.
Medium TRF damper spring.
Aluminum wheel nuts (blue).
Body, motor and pinion not included.
HorizonHobby.Com
Old 03-06-2005, 08:04 PM   #1188
Aries326's Avatar
Trader Rating: 19 (100%+)
I don't know really how serious I'll get into the hobby. I definitely like going to the local LHS and watching the races and I'm into tweaking/fixing things up. As a kid, I used to put together model planes and cars. I have most of the hop-ups already on my M-04L. Its too bad I've got no one to race around here and winter is dragging. I've only run this thing once out in our cul-de-sac.
I probably won't have much time to race. At most once a month. I definitely want to put my money into something that will be competitive, upgradeable and durable.
On the same note, is the TB-02R the same as a TB-02 with the Tamiya Conversion Parts Blue for the TB Evo III?
Aries326 is offline   Reply With Quote
Old 03-06-2005, 08:17 PM   #1189
Myker*'s Avatar
Send a message via AIM to Myker*
off topic:: hebiki, was nice running with you today at tcs man.. you are fast!~
Tamiya Racing Factory
Myker* is offline   Reply With Quote
Old 03-06-2005, 08:25 PM   #1190
RCGaryK's Avatar
Soooo???? Who won?
HorizonHobby.Com
Old 03-06-2005, 09:08 PM   #1191
Myker*'s Avatar
im not sure, i didn't get to stay that long.
Old 03-06-2005, 09:15 PM   #1192
RCGaryK's Avatar
d'oh
HorizonHobby.Com
Old 03-06-2005, 09:49 PM   #1193
westerdude42's Avatar
Post Aries
I have both the TT01 & TB02. The TB02 is in my opinion the far superior car. The TT01 has serious durability issues with the steering knuckles as well as the chasis. The TB02 is more tuner friendly and has many more hop up options. Just the gearing options alone make the TB02 the better car. I see the TT01 as a toy that can be converted into a low end racer. I see the TB02 as an excellent mid level racer that can also double as a parking lot fun car.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 03-07-2005, 11:58 AM   #1194
RCGaryK's Avatar
If anyone has bought the LW arms for the TB-02, could you possible scan the instructions and post them please?
HorizonHobby.Com
Old 03-07-2005, 01:50 PM   #1195
Hebiki's Avatar
Trader Rating: 26 (100%+)
myker... im not sure who you were. but i had a lot of fun. juan definitely put on a clinic (too bad i forgot to take notes). i had a fun battle in the GT2 A-main with someone. never got his name tho.
mr. aveytia is definitely my pick this year to keep the GT2 title in california (enter gary's response....)
gary.. sorry i didnt return your call.. i was asleep! barely woke up.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-07-2005, 01:53 PM   #1196
Hebiki's Avatar
Default Re: TB-02 or TT-01???
Originally posted by Aries326
My question is, which should I get? A TB-02 that can be upgraded with many TB EVO III parts if my compulsiveness takes over me, or should I get the less expensive TT-01 that still has alot of parts available to it?
Aries
careful with the TB-02... once you get into faster racing (stock 27T and up)... you'll start to munch gears on the TB-02. the main problem i had this past TCS was the shaft TWISTING inside the bevel gear.
i solved the problem of one way gears stripping...and bevel gears stripping. now the shaft is starting to spin and strip the inside of the bevel gear.
for the main... CA that sucker and my car was very LOUD!
btw... TT-01 will cost you about $410 USD total when/if you buy ALL the hopups. (TCS legal i mean)
Hebiki Design Works
Old 03-07-2005, 02:01 PM   #1197
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Originally posted by Hebiki
Mr. aveytia is definitely my pick this year to keep the GT2 title in california (enter gary's response....)
Back to the drawing boards! Chris, don't give up... send me your car...
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 03-07-2005, 05:24 PM   #1198
dsrbltoys's Avatar
Wow, once again the trash talk has started for tcs nats, we only have had 2 races so far. Bring it on
I race my TB02 in gt1 a lot. I have a fix for the stripped gear PM me Ian.
dsrbltoys is offline   Reply With Quote
Old 03-07-2005, 08:39 PM   #1199
RCGaryK's Avatar
What, the rest of us aren't good enough to know your fix Kevin? Sheesh, lol
HorizonHobby.Com
Old 03-07-2005, 09:54 PM   #1200
Aries326's Avatar
Default TB-02
Thanks for the heads up on the TB-02 stripping. I'm going to Southeast Asia in May for a little vacation. I heard RCs are cheaper over there.. I'm hoping to pick up a kit over there for cheap. So far, it looks like its gonna be the TB-02. If the TB-02R is around $150 American, I'll pick that up instead. Just got my tax refund. Yahoo!!!! Divert some of it for a new car!!!!
Yo, dsrbltoys, why don't you share with us the fix to stop the TB-02 from gear stripping? Thanks, dude...
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
