Old 11-30-2003, 07:27 PM   #91
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Originally posted by DZ
Does any one know exactly what comes in the blue conversion kit
i Specficily want to buy it for the tb-02,
Cheers Dz
Here is a picture of the contents.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is offline   Reply With Quote
Old 11-30-2003, 09:54 PM   #92
Izzy yes you can but that is also why you want the blue conversion set as it gives you all of the toe blocks to change the parts.
The rear uprights are the 1d uprights which also have different link locations on the hub
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 11-30-2003, 11:36 PM   #93
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Izzy, the TB02 comes with only 4 blocks, wich would be the same as the "A" block on the evos.
As for the Blue conversion kit, you get 4 "A" blocks, 1 "B" block, 1 "C" block, 1 "D" block, 1 Propeller shaft, 1 EVO3 heat Sink motor mount, 1 spur gear adapter, 1 front one-way housing (no drive cups), 2 servo mounts, 2 steering posts, 2 swing shafts (uni shaft not complete unit), 1 steering arm (left), and 1 steering arm (right)
19 total parts
there are 3 itmes that don;t work on the TB02. EVO3 heat Sink motor mount, 1 steering arm (left), and 1 steering arm (right).
the stering doesn't work do to interference with the tub reienforcements, the motor mount doesn't have any mounting for it in the tub. ALL other parts will fit on a tub car.
tamiyarcracer is offline   Reply With Quote
Old 12-01-2003, 04:03 AM   #94
supersonic's Avatar
Does anyone know a online store that as the TB-02?
I have only seen it on rainbow ten and tower has it only as rtr
supersonic is offline   Reply With Quote
Old 12-01-2003, 07:22 AM   #95
Super sonic.
The Tamiya America had them last week, so that meen that distributors sould be getting them, and shipping them out to the store very quickly. I beleive that the kit TA had was the mercedes 58310 I think.
Old 12-01-2003, 01:37 PM   #96
MikeR's Avatar
Trader Rating: 15 (100%+)
I have the Xanavi Skyline if anyone is interested... http://www.rctech.net/forum/showthre...threadid=28614
MikeR is offline   Reply With Quote
Old 12-01-2003, 01:47 PM   #97
izzyracer's Avatar
Trader Rating: 27 (100%+)
19 total parts
I think it is indeed a good option to get the blue conversion kit. But I will try to get the EVO 3 limited instead so that I can get the parts plus the all important universal shafts. I won't have any use for those lightweight swing shaft if I don't have the uninversals right?
Izzy
izzyracer is online now   Reply With Quote
Old 12-01-2003, 03:53 PM   #98
For those of you looking for a TB-02, here's where I got mine..
TB-02 HERE
CustomfibreR/C is offline   Reply With Quote
Old 12-02-2003, 12:59 PM   #99
Trader Rating: 62 (100%+)
Got mine today unexpectedly. Was buying stuff for my mini-t and saw Sheldons hobbies unloading them. $149 for the kit. Looking forward to building it and racing at TCS.
sipaboy is offline   Reply With Quote
Old 12-02-2003, 01:06 PM   #100
Hebiki's Avatar
Trader Rating: 26 (100%+)
sheldon's hobbies in san jose had them? i was just there on saturday? are you sure its the TB-02?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-02-2003, 05:15 PM   #101
Yes, sheldons has them. Ist one they got and I bought it. I called the other lhs and non of them got it. It's the Mercedes body. Anyone knows what tires these are. Low profile and kinda sticky[24mm]. A's or B's?. Uses Ta04 arms,carriers. Not sure if the universals wil work too. They have 2 more I think.Got it at 10:30 this morning just when ups just dropped them off. Remember timing it right when the Associated RC10T first came out years ago.I was in the store when the first delivery came. We even had a waiting list that you sign up if you want one.
Old 12-02-2003, 05:23 PM   #102
izzyracer's Avatar
You must like sleep by your LHS's door (joke).
That would be cool if you got at least type A's. More than likely they are just rubber slicks. I think the Tb uses the 41 or 42mm universals use with the the TB evo 3 series and 414M2 series. The TA04's use a 39mm shaft.
Give us a report on building (pictures?) and if possible your initial impressions on handling.
Me and Hebiki will be getting our's soon with the Xanavi body.
Izzy
Old 12-02-2003, 07:25 PM   #103
The tires are a kit slick, atleast the ones in my skyline are.
Izzy I have pictures of mine, but it is with the blue conversion kit on it.
As for handling, out of the box it had a little push with the kit set-up, the tracktion was low on the surface I ran on, it was at Burien RC. The only change was a set of A tires soft inserts in the front, and hards in the rear. The changes that were mad was, lengthening the upper arms (camber links) and shock oil. The car was pretty good with those changes. I then went to sway bars, yellow all the way around and it got really pushy again.
Old 12-02-2003, 07:36 PM   #104
How about shock position?Shock oil?Camber? What do you think is the potential of the kit competing againts the ta04r?
Old 12-02-2003, 07:53 PM   #105
I was running against a 414m2. he was beating me, but I had geared it at a 5.0 he was a 5.3 I think the main difference was the puch he had out of the corner. he did a 45 lap and I was a 44. again it was a small track with sub 6 second laps. I also had a few more mis haps with slower traffic.
I think the car will be good as long as you can hit the gear ratio for the motor. We were racing silver cans.
In a nut shell only two packs for set up. It did very well, and he is a better driver. I think the car will hold it's own very well, I haven't tried a roar stock yet.
Oh I did change the shock position I started with the kit oil in the kit shocks, and moved to flourine coated with three hole pistons, 600 tamiya oil. That was about it
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
