Old 01-11-2005, 06:16 PM   #916
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by jodyburn1
YEA THE OPENINGS THAT HOLD THE BEARINGS THEY JUST DONT HOLD THE BEARING STRAIGHT AND THEY BIND BUT ITS NO PROBLEM IF YOU KNOW BEFORE YOU PUT IT TOGETHER
IF NOT YOU WILL COOK A SET OF BRUSHES REAL FAST
I WAS RUNNIG THE 19T PINION AND THE 61T SPUR GEAR
SO IT WAS NOT GOING TO BE OVER GEARED AND MY MOTOR
GOT UP TO 250 DEGREES FERENHIT WITH IN 10 LAPS
THAT WAS THE LAST OF THAT PAIR OF BRUSHES
interesting...
gonna have to look into that. my drive train spins pretty freely.... but better safe than sorry.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-11-2005, 07:04 PM   #917
jodyburn1's Avatar
well man if yours spins free and your motor dont heat up
dont worry bout it
with mass produced kits they are never two kits that are
the same
the problems i had you may never see
but its just some thing to keep an eye on
if you have raced yours you would have known right away
jodyburn1 is offline   Reply With Quote
Old 01-11-2005, 07:13 PM   #918
PIIHB!'s Avatar
I'll keep that in mind when I build mine. My kit arrives friday
PIIHB! is offline   Reply With Quote
Old 01-11-2005, 07:48 PM   #919
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Default need help!!
Somebody mention before about the F201 spur can fit in the TB-02.
The max ratio now is 5.72 . I want to go lower. Anybody can send some pictures of the F201 spur in the Tb02?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 01-11-2005, 07:58 PM   #920
jodyburn1's Avatar
well man not sure about that
but i do know that the tb02 does
come with a spur gear adapter that with let you
run 48 pitch spur gears and if you get the billit motor mount
you can slot out the bolt holes so you can adjust your gear mesh
to about any ratio spur and pinion combo
Old 01-11-2005, 09:39 PM   #921
ford_racing's Avatar
Send a message via MSN to ford_racing
Default Re: need help!!
The F201 speed tuned geas does fit in the TB02 but you will have to use pinions 25 (A) 26 (B) 27 (C) 28 (D) holes and it will work, the 27T will equate to a 5.01
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 01-11-2005, 10:32 PM   #922
KREATOR1's Avatar
Default Re: Re: need help!!
Thankss alot guyss.
Old 01-11-2005, 10:41 PM   #923
Yeah... Check this site out for the bigger sized pinions, because I don't think tamiya make the 28t 0.6m pinion. Although I think a 27t 0.6m pinion for the ta04 is available.
http://www.kawadamodel.co.jp/partsli...6module_e.html
Phenochilus is offline   Reply With Quote
Old 01-13-2005, 07:40 PM   #924
Aluma's Avatar
tc3 shocks will also work with minamal modifacation
sacrilige!!!!! guess he hasn't tried the TRF shocks...
Aluma is offline   Reply With Quote
Old 01-13-2005, 09:35 PM   #925
KREATOR1's Avatar
TC3 shocks on Tamiya?? why why?
Old 01-13-2005, 09:42 PM   #926
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
Default TB Evo 4 diff gears
hi there,
has anyone tried fitting the tb evo4 diff/bevel gear set in their tb02? i'm new to tb02 chassis, besides motor mount, ssg t-bar, stabilisers, what else is needed to make this car perform good on races, besides steady hands...
thanks.
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 01-13-2005, 09:59 PM   #927
KREATOR1's Avatar
do you mean the ALumn evo4 spur? they have the same spur size?
Old 01-14-2005, 06:33 AM   #928
alana07's Avatar
no, i'm referring to the internal diff/bevel gears....read in a HK mag and it says those gears have a carbon mix and fits evo 3, so should fit tb02 also.....
没有最好,只有更好!!!
Old 01-14-2005, 07:25 AM   #929
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
the diff gear is the same, but the small bevel gear attaches to the driveshaft totally different... dont think it will work.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-14-2005, 08:40 AM   #930
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
I have not run the alloy gear personally, however I have been told by a quality source that it has worked well in his EVO3 SL
madjack is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
