Old 11-10-2004, 08:18 PM   #751
ford_racing's Avatar
Send a message via MSN to ford_racing
Default Carpet setup
Reading through this topic was quite interesting, with a lot of arguements about the SS rear arms
anyway, I've just recieved a new TB01, is still kit standars and was wondering what setup would be the best for a high grip carpet track
also what are the hop up options that I should get to make the car competitive in silver 540 racing?
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 11-10-2004, 09:48 PM   #752
RCGaryK's Avatar
they should be illegal...but I think the LW suspension set is going to make that a moot point anyways...
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-10-2004, 09:48 PM   #753
RCGaryK's Avatar
HorizonHobby.Com
Old 11-10-2004, 11:01 PM   #754
Default drivetrain
how do u make the drivetrain spin freely?? mine seems to be quite stiff at the moment ...
hapiya is offline   Reply With Quote
Old 11-10-2004, 11:12 PM   #755
Originally posted by dsrbltoys
Ok set up
car was a surikarn, so all the hop ups from that car. The only additional hop ups used were of course the steering belcranks, the motor mount, lt wt shaft, and I did add the alloy rr 1 deg upright.
Front
700 wt oil gold spring 2 hole piston (1 black oring on bladder)
top of shock out on tower, IN on arm
inner upper link in middle hole, with 3mm under inner link
A-A blocks, no kick or pro drive
Akerman in outer hole
5mm ride height
blue sway bar
2 deg camber 1 deg toe out
almost no droop
Rear
500 wt oil gold spring 2 hole piston (1 black oring on bladder)
top of shock outer most hole on tower, and outer on arm
upper link (inner) middle hole +2mm / (outer) most at arm +.7mm
A-C block no anti squat
5 mm ride height
blue sway bar
2 deg camber 2, deg toe in per side
a little more droop than the front
Speeder QC2 profile 5
radio had 10 points of forward roll into it
Radio steering set to -25 exp.
gearing was 27/52
what track were you using this on? ie. polished concrete, carpet, tarmac, etc and what grip levels were available
ARC R11
Yokomo YRF001
AE B5m
Old 11-11-2004, 11:47 AM   #756
dsrbltoys's Avatar
At the Tamiya USA headquarters. This was in the GT3 class with the silvercan motor. The track is an asphalt permanant racing facility!
dsrbltoys is offline   Reply With Quote
Old 11-23-2004, 06:09 PM   #757
dsrbltoys's Avatar
Well after some time on the car with the new suspension, I am going back to the old suspension, at least the arms. I cant keep buying inner hinge pins to replace the bent ones. With the new arms I have like 12 mm of shims on the arms to adjust wheel base. I think this is too much. I may try using the new uprights on the old arms to see how that works.
Old 12-05-2004, 02:07 PM   #758
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Post TB02 top deck
I heard rumors that the new TB02 top deck was released in Japan recently.
Any pictures and/or experiences with the new item would be appreciated!
Ian...have any extras in your suitcase by chance?
madjack is offline   Reply With Quote
Old 12-05-2004, 02:09 PM   #759
RCGaryK's Avatar
if he did he's holding out on me. He said they weren't available
HorizonHobby.Com
Old 12-05-2004, 03:14 PM   #760
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Unhappy
ahh shucks... No, seriously... they weren't available when we were there. I got pictures though from the display they had at the worlds!
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 12-05-2004, 03:17 PM   #761
RCGaryK's Avatar
if u have pics, share them
HorizonHobby.Com
Old 12-05-2004, 03:19 PM   #762
Hebiki's Avatar
Trader Rating: 26 (100%+)
i got mine. works great!
he said under his breath... "only available for TAOB"
JUST KIDDING!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-05-2004, 03:21 PM   #763
eeyan's Avatar
Unfortunately, I'm like 100 miles away from home... you guys need to wait 'til tonight. I have some close up pics of what's to come (or as Hebiki says in his dreams... already came )
Old 12-05-2004, 05:54 PM   #764
madjack's Avatar
sounds good, hope this item will add a bit more stiffness than that lower brace that helps soooo much
Old 12-05-2004, 06:03 PM   #765
eeyan's Avatar
Unhappy
John... I have a feeling the new parts are just for bling bling (actually, I find the design a bit "cheesy" IMO)... once you see the pic, you'll probably agree with me. I'm still hoping Tamiya makes a carbon graphite version of their current plastic tub.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
