Old 09-03-2004, 10:55 PM   #736
linger's Avatar
Originally posted by eeyan
Man... how come nobody's asking for my setup...?!?
Don't worry eeyan, nobody asked for my setup either
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 09-03-2004, 11:05 PM   #737
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Ling, i would have asked, but i dont think that even if my car was perfect, i couldnt have gotten those lap times!!!!! you guys were machines!
i did use Fred's setup from the KO race, tho... minus the rear swaybar. the car drove pretty well - better than me, anyway!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-10-2004, 12:25 AM   #738
Send a message via Yahoo to heftybone
Default Clarification...
Hello from Russia...
"and I did add the alloy rr 1 deg upright."
Does the "rr" mean "right rear"? And, if so, was the car imballanced? That's a pretty neat setup, if so...
I'm thinking of doing the European version of the TCS this year and thought the TB-02 would be a nice car to run in the GT-2 class.
hb
heftybone is offline   Reply With Quote
Old 09-12-2004, 10:28 AM   #739
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
any of you guys convert it to off road rally car?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 09-16-2004, 06:33 PM   #740
dsrbltoys's Avatar
Yes, The Rr was referring to the Alloy rear 1 degree upright part number 53687.
dsrbltoys is offline   Reply With Quote
Old 09-17-2004, 10:01 AM   #741
mtveten's Avatar
Kev,
How much does the short arm conversion shorten the wheel base by, and if I use the short arms, am I required to use the Sort arm bodies or can I lengthen the wheel base with the spacers and throw a standard body on?
Oh one last thing, have you tried moving your inner camber links to the towers and shiming them to keep them inline with the a-arms, the 5-10deg sweep I in the upper camber link just seems wrong, doesn't it change the caster as the suspension compresses?
Mark
mtveten is offline   Reply With Quote
Old 09-17-2004, 10:15 AM   #742
Turbonium's Avatar
the short wheelbase difference is 10mm.... you can alllmost get it the same, just not quite.
Wes
Team Novak
Old 09-17-2004, 01:48 PM   #743
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by mtveten
Kev,
Mark
Mark..if your TB-02 has a surikarn evoIII on it.. and then you put on the TA04-SS arms.. if you shim the arms so that its the longest wheelbase... then YES you can use the regular bodies (nsx, ferarri). ive tried it.. but never actually drove the car. ive always used the MRS body (because its so freaking cool! )
BUT that might be considered a loophole and be deemed illegal at TCS events. since if you are using the SS arms, you might be required to use an SS body (MRS, Audi TT). im NOT sure on that. and im not sure if the SS arms are tied to the two bodies mentioned above. really NOT sure.email fred and have him clarify for you.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-17-2004, 02:20 PM   #744
The only issue is that it binds the rear CVD pretty hard. Well not bind but puts an extreme angle on the CVD.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 09-23-2004, 09:09 AM   #745
Default ESC for TB02
Hi I just built my TB02 all still stock parts.Would like u guys recon. which esc to buy.I had in mind LRP V7.1 and Quantum pro sport.Can u guys give me a commment on these two esc.I will race local at TCS.And what parts should I upgrade on my TB02 for race. Thanks...
faiunie is offline   Reply With Quote
Old 09-23-2004, 09:43 AM   #746
KREATOR1's Avatar
7.1 is high end ESC no limit motor turn
and the Quantum pro sport is 7 turn limit.
More, they both eazy to set.
they Both good runing on stock motor + The Tb-02 is a great Tc car.
Old 09-23-2004, 12:50 PM   #747
Hebiki's Avatar
Default Re: ESC for TB02
i suggest picking up the center chassis brace, universals, alum. motor mount and steering rack.
OR..buy an old EVOIII/EVOIIISE... those cars will directly fit onto the TB-02. pick up a lightweight shaft also.
Hebiki Design Works
Old 09-23-2004, 05:42 PM   #748
Aluma's Avatar
ummm, geee, correct me if I'm wrong here, BUT if you bought an evo3 to upgrade the tb-02, wouldn't it just be better to put the diff into the evo3 and have a BETTER car? I mean the evo3 is SUpposED to be better chassis/car right? I want TB-02, but just to play around outside/park kinda thing...maybe to drift it, but if you have an Evo3, wouldn't it be better to race that?
Aluma is offline   Reply With Quote
Old 09-23-2004, 06:25 PM   #749
Hebiki's Avatar
aluma has a point... but i wasnt sure what application faiunie was going to use the car in. strictly bashing and drifting, the car is fine.. but if you want to use for TCS.. or want a "TUB" version of the evoIII then the hopups are necessary. plus evoIII's are cheap nowadays since the EvoIV is out.
bare minimum hopups you'd want for parking lot/club racing applications would be the center chassis brace, aluminum motor mount and maybe the alum. steering rack.
Hebiki Design Works
Old 10-04-2004, 07:24 PM   #750
Default Blur newbie
Thanks guy for the infor. I just get my self LRP V7.1 look fast too at accleration compare to my S705 GP car look EP car more faster than GP.I am using an old Trinity Monster Horse power 1987 version motor hand over by a fren.Only problem I got is the brake I cant get it jam brake after a couple of adjustmnet follow in the manual.Looks like my ep car brake like in ABS mode gradually slow down.And what spur and pinion gear can I use to make my car go faster(presently I am using the stock gearing spur 58T and pinion 19T)What fast gear can my TB02 handle.Any recondmendation?What changes should I make for the gearing?
Thanks GUYS....
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
