Tamiya TB-02
#66
Hebiki,
I bought the car kit from R10. I got the Skyline car. That body is soo cool.
Difuser is talking about my car. R10 had all the spares but the tub. to convert the EVO to a tub.
THere are two parts that won't transfer, and Tamiya already has them as hop-ups. The motor mount is tub only, and the steering bell cranks are tub only.
The 27 / 52 was loose as well, I'm gonna try a different hole next race for the motor.
The 27 tooth pinion is Tamiya Part # 49230 ithink it was for a spec gearing on the TA04 in japan racing
#67
Do you have to put the pinion on the motor then in the motor mount, or can you put the motor in the mount then the pinion on.
#68
The motor mount removes after you remove 2 screws. if the pinion is small enough. But the pinion needs to be on the motor when you put it in the car. If you have a large pinion you need to remove the upper support to get the motor assy out.
#69
Originally posted by tamiyarcracer
Hebiki,
Hebiki,
#72
will it have the same gear problem as the evo 3? or has something changed?
#75
thanks for the reply, diffuser i also saw the blue conversion kit for the evo3, but in our lhs, its the same price as the TB02 car kit itself i hope the parts will be available separately. if i get a TB02, my primary hopups will be hard arms, aluminum arm mounts, aluminum motor mount, and universals (at least front.) its good to know that the TB02 shares many parts with existing kits btw, how many bodies are initally available with the kit? i only saw a skyline and CLK.
