Old 04-15-2004, 07:42 PM   #571
dsrbltoys's Avatar
Don't know about the other cars, If you want the tamiya ball pieces they are part # 50994
dsrbltoys is offline   Reply With Quote
Old 04-16-2004, 11:15 AM   #572
psycho's Avatar
Speedtech should have them. I ordered them recently from him.
psycho is offline   Reply With Quote
Old 04-16-2004, 12:29 PM   #573
RCGaryK's Avatar
Should have the suspension balls or the RW Pinions Psycho?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 04-16-2004, 12:43 PM   #574
psycho's Avatar
Sorry. I meant the suspension balls.
Old 04-16-2004, 10:54 PM   #575
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
I don't see izzy's name on either the main list or the waiting list on 2004 Reedy Race...are you running, izzy?
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 04-16-2004, 11:02 PM   #576
RCGaryK's Avatar
Have you guys noticed that even in the shortest wheelbase, the rear wheels sit really far back in the wheelwells?
HorizonHobby.Com
Old 04-16-2004, 11:10 PM   #577
fabolousRC's Avatar
it happens on my TB Evo I n II too. I don't know why....
Old 04-17-2004, 07:59 PM   #578
RCGaryK's Avatar
Well I ran the car today for the first time, and it was...different. It wasn't like either my Surkiarn or my 04ss. Even its shortest wheelbase the car was still pushy and it didn't transition as well as I would have liked. But it did respond to changes well, and I was running against a friend with an Evo and wasn't losing anything to him. One thing that troubled me was how I managed to pick up a stone in the motor pinion even though the chassis is sealed there?!?! Weird. I didn't get any times today, I was more worried about finding a comfort level. I dunno at this point if it is better than my 04, but there's potential. What are you guys running for setups on asphalt? My carpet setup from my Surikarn felt decent on the 02, but it was a little lazy transitioning and slightly pushy like I said.
HorizonHobby.Com
Old 04-19-2004, 01:44 PM   #579
psycho's Avatar
I pretty much have the same feeling, Gary. I think I'm about 90% there on figuring out how to set the car up. The last time I raced it, I played around with rollcenter adjustments and feel that it seems to like having the rollcenter lower. I'm running the SS arms on my car, so I can't use a front swaybar to take some of the rollyness out, so I'm using reduced droop and compensating for the lack of steering with softer inserts or bigger airgap at the moment. It's not ideal, but getting closer to how I want it. Also, it seems to have a lot of mechanical grip in the rear, so you might try running the rearend stiffer to get it rotating a bit. That may or may not suit your driving style, though. I usually set my cars up that way because I like to be able to break the backend loose if I need more steering to stuff the car down the inside to make a pass.
Old 04-19-2004, 02:35 PM   #580
TFR
TFR's Avatar
Where do you guys place the antenna? All the way at the back hole? Anybody have a good way to mount the antenna closer to the servo/receiver. Would it be illegal to drill a hole thru the chassis for a antenna mount for TCS?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 04-19-2004, 02:51 PM   #581
psycho's Avatar
I use the rear antenna mount position and just keep the wire tight by putting a black rubber cap over the top of the antenna tube and the antenna wire. This way it doesn't get wrapped up in the prop shaft or scorched on the motor. I remember reading that it is legal to change the antenna mount location, but I'm not sure under what circumstances or what methods are legal. Have a look over the rules and I think it should be pretty clear.
Old 04-19-2004, 03:19 PM   #582
RCGaryK's Avatar
I used a TA04S one actually, and mounted it with the screw that goes into the right bellcrank post.
HorizonHobby.Com
Old 04-19-2004, 06:11 PM   #583
TFR at local regional unless you got an anal tech guy they would probably not call you at Nats they would. I had that happen on my Mini.
I ran an antennae tube glued to the receiver back to the mount and routed that way. Garys solution should get you thru tech without drilling at all.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 04-19-2004, 06:32 PM   #584
TFR
TFR's Avatar
Thanks, I'm going to go with Gary's way...just need to find that part now.
Old 04-19-2004, 09:32 PM   #585
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I run my antenna thru some fuel tubing to the rear mounting position to protect it and then into the antenna tube.
ST Racing Concepts (STRC)
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
