Old 03-30-2004, 04:52 PM   #481
RCGaryK's Avatar
the Chassis was like $10, about $22 for the steering, $ 15 for the motor mount, and 5-6 for the M-parts tree. You also need a 5x10mm bearing too instead of the Evo's 5x12 that supports the driveshaft towards the rear of the car
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 03-30-2004, 04:56 PM   #482
TFR
TFR's Avatar
Gary,
Thanks, do I need the N parts as well? I believe they are gear cover...
TFR is offline   Reply With Quote
Old 03-30-2004, 04:59 PM   #483
RCGaryK's Avatar
Yup, that was like the same price as the other parts tree. I think all in all it was around $45
HorizonHobby.Com
Old 03-30-2004, 06:50 PM   #484
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
I think you need to add a motor mount to it, either through the parts tree it is on, or through the aluminum mount.
If your local hobby shop can't help you, you can always get the parts from Tamiya direct.
tamiyarcracer is offline   Reply With Quote
Old 03-31-2004, 07:43 PM   #485
dsrbltoys's Avatar
Thats not quite right. The bearing was a 12x6 now its 10x6.
Everything needed;
Tub 9335398 12.50
upper deck parts 51044 6.50
m parts mtr mt/steering 51045 6.50
10 x 6 bearing
Or you can substitute
alloy steering 53678 32.00
alloy mtr mt 53680 23.00
use these and you don't need to buy the m parts
Also availble
plastic shock towers, and upper sus.mt B parts 51043 5.00
stabilizer set 53677 13.00
SSG reinforcing plate 53679 13.00
TB02 shaft 50993 7.25
lt/wt shaft 53686 9.75
hope that answers all q's
Kevin
dsrbltoys is offline   Reply With Quote
Old 03-31-2004, 07:48 PM   #486
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Hi Kevin
I'll be coming up to see you tomorrow..Jose need some med pit rear tires for F-1 201..Can you bring a diff tomorrow at work for my mini mo4. how much do you want for it?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 03-31-2004, 08:34 PM   #487
RacingStorm's Avatar
Default TA Setup
For those of you that run out at the TA facility, what would be a good starting setup for the TB-02 for the June TCS race?
RacingStorm is offline   Reply With Quote
Old 03-31-2004, 09:32 PM   #488
TFR
TFR's Avatar
Everything needed;
Tub 9335398 12.50
10 x 6 bearing
Also availble
Kevin
Kevin,
Thanks for the help. One more question, can I use the spur gear and pinion from the EVO III?
Old 04-01-2004, 11:12 AM   #489
dsrbltoys's Avatar
biggest spur gear on the car is a 96t in fine, but good luck on getting it to mesh with the stock motor mount. I had a friend machine an adjustable one.
Old 04-01-2004, 12:01 PM   #490
stonedgti's Avatar
Trader Rating: 15 (100%+)
Default 540 gearing
What are you guys geared at for 540 silver can motor???
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 04-01-2004, 01:48 PM   #491
dsrbltoys's Avatar
52 TOOTH SPUR FROM F201 HI SPEED GEAR SET AND A 26 PINION. HAS WORKED WELL ON BOTH OUR LONG TRACK AND SHORT TRACK.
Old 04-01-2004, 01:59 PM   #492
Manny's Avatar
Default 26 tooth part number?
I couldn't find a part # for that metric 26 tooth pinion. Does anyone know? Any help would be appreciated!
Manny is offline   Reply With Quote
Old 04-01-2004, 02:31 PM   #493
dsrbltoys's Avatar
Mine is hpi. but they discontinued it. 6726 was the number. I think an earlier post showed RW whick is distributed by schumacher
Old 04-01-2004, 03:10 PM   #494
i no this is the wrong place, sorry
but has anyone any idea of the internal ratio for a tb01?
thanks alot
Tarnjit
Evo_Uk is offline   Reply With Quote
Old 04-01-2004, 03:12 PM   #495
psycho's Avatar
2.6 same as the F201 and Evo3
thanks alot
Tarnjit
psycho is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
