Old 01-25-2004, 10:46 AM   #376
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default Re: TB02ss
Originally posted by Racinrc14
I have to ask: Are the SS arms really that much better on the car that it warrants such a heated discussion?
Gary, I figured out the binding problem, now she spins like a TC3. I still believe the torque rods should be left off, though, even on carpet, IMHO.
Izzy, have you ran the TB02 with the standard rear arms? If so, how does it compare to the ss arms? Are you and Gary in disagreement because it is worthwhile to allow the arms, or are you guys fighting just to be fighting? Some people just like to argue (Gary).
I'm all for moving on and concentrating on TB02 discussion, not rule discussions. Anyone else?
Tommy
Nobody is fighting here... we all know were all tuff because we are still in the confinement of our private homes. Lets see how you react when we are face to face, we all be so very nice to each other. Gary mentioned somewhere in this thread that he likes a good discussion and I'm just giving him what he wants. The TB02SS setup has some advantage on tight tracks since it can come around turns better. Can it win over the standard setup? Depends whos driving! Gary you better let me know who you are so that I can KICK YOUR ASS! (bipolar)
Izzy
izzyracer is offline   Reply With Quote
Old 01-25-2004, 10:57 AM   #377
RCGaryK's Avatar
whether its an advantage or disadvantage to me is a moot point. They rules state X, yet Y is being allowed, and Z, which is very similar to Y is being disallowed.
I was out there for Nationals, and I will be there again this year, and I may be there for the Reedy race. I was the guy with the Cheeze Wiz GT2 car.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-25-2004, 11:16 AM   #378
izzyracer's Avatar
Ohhh right... ok! se you then!
Izzy
Old 01-25-2004, 11:22 AM   #379
RCGaryK's Avatar
Shouldn't you be at the Newark TCS today, or is that next weekend?
HorizonHobby.Com
Old 01-25-2004, 11:30 AM   #380
RCGaryK's Avatar
Tommy, I am going through mine right now to free everything up. There's grease smeared all over the ring and pinion gears, and the rear arms need to be shaved so the hub carriers don't bind up. I may try it Tuesday, otherwise a week from tuesday. I still need to get a servo for it, and I am debating whether to pull my HRS KO receiver out of my T4 and put it in the Surikarn, or just buy a new one, plus I need to mount the Hara Speedo in it too. A lot of work still to be done.
HorizonHobby.Com
Old 01-25-2004, 12:06 PM   #381
Roger that. To free up the drive, I took the diffs out, cleaned the Tamiya ceramic grease off of them, applied Crest toothpaste to them, yes, I said toothpaste, and then re-assembled everything. I installed the included Mabuchi, and ran it with the T35 on 3 volts for about 30 mins. Cleaned it all up and re-lubed and it worked. Nice and free. I had to shave .015" off the forward hole on the rear arms to get the hub to rotate freely.
Let me know how it works out. I assume you will be trying it at Trackside? Thanks,
Tommy Dale
Racinrc14 is offline   Reply With Quote
Old 01-25-2004, 01:19 PM   #382
RCGaryK's Avatar
Over Under Under Dunn to the Trackside question
HorizonHobby.Com
Old 01-25-2004, 06:02 PM   #383
izzyracer's Avatar
That's next week. Tentative plans are to leave Saturday and race next day. It's more looking like a suicide deal so I am thinking twice about it now. Will see.
Izzy
Old 01-26-2004, 01:51 PM   #384
Registered User
Suradaj's Avatar
Drove the TB02 with a oneway this past Sunday, it striped. Monster motor with a gear ratio of 7.5X.
Put the ball diff back in, still fast but I like the one way.
Suradaj is offline   Reply With Quote
Old 01-26-2004, 01:58 PM   #385
izzyracer's Avatar
Thanks for letting us know. I was going to do that but the fear of stripping was preventing me to do so and now it has been confirmed.
Izzy
Old 01-26-2004, 05:10 PM   #386
DZ
I've been running the one way and have had a few large hits and have had no problems..But i guess i'mm only running the kit motor.... class i have a my track...
i've just placed the ss arms on my car does anyone have a set up? Low grip dusty concrete tight track...
DZ
DZ is offline   Reply With Quote
Old 01-26-2004, 08:14 PM   #387
dsrbltoys's Avatar
Default Racinrc14
Ok, back to your comment on the diff spring. It is ground, just not that flat. I can however tell you that the stock plastic out drives are not as strong as the white plastic for the EVOIII(S). I have broken one side in the front, and a friend broke the other side. When I replaced it, I used the white for the Evo. This made the diff action much smoooooooother. All of the TB02 cars that I have looked at, the diffs seem lumpy, I thought it was the spring also, untill I tried the other diff halves.
dsrbltoys is offline   Reply With Quote
Old 01-27-2004, 12:48 AM   #388
Registered User
Suradaj's Avatar
I use the EVO III diff out drives, they are better then the stock ones. The molds on the TB02 are not good.
Old 01-27-2004, 03:41 PM   #389
Default Re: Racinrc14
In my kit, both springs were bare on both ends. The wire came to an abrupt stop at either end with no grinding. It is all academic now, however, as I have the evo outdrives on the way. Glad to hear the the Evo outdrives solve the problem, hard to get a car to run well with notchy diffs.
Tommy
Old 02-02-2004, 08:27 PM   #390
Suspended
Trader Rating: 28 (100%+)
Hey Guys!I just traded the kit I won from winning my main at the newark TCS for suradaj's TB02{thanks Joey!}The car was involved in a major reck and the Chassis was cracked at the rear arm mount.Has this happened to anyone else yet? I figured it shouldnt cost a bundle to replace and for the kit tamiya gave to me{TT01-eek!),I made out like a bandit considering all the hop ups and evo3 stuff thats on the car.
When will the chassis be available by itself? Thanks!
racenut123 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
