Old 01-14-2004, 10:57 AM   #286
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default Front one way gear issue
One design change from the EVO 3 to the TB02 that I thought would be benificial to the one way stripping problem is how the front plastic that holds the bumper from the top is now directly screwed to the plastic that holds the front sway bars which is attached to the front bulkheads. I'm just not sure if it is a good thing or bad thing because now. I would Imagine if you hit something it will directly affect the front bulkhead. Also, the new TB-02 foam bumper has a cut out that I thought made it weaker compared to the evo 3 front bumper.
Izzy
izzyracer is offline   Reply With Quote
Old 01-14-2004, 12:00 PM   #287
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
That could be a problem if you do take a big hit in the front end. I really want to see one built and get a good look at it instead of pictures so then I will see if I want one for sure or not. Might have to stick to my bullet proof TA03R-S and patiently wait til they make a car for TCS that I really like as I still get by with my 03R-S
ST Racing Concepts (STRC)
Old 01-14-2004, 03:40 PM   #288
DZ
Default DESIGN'S
I design change that i have noticed. also i'm not sure if it is a good or bad is the orginal tb-02 pinion gears on the shaft are quite loose. and if you shim the bevels correctly the bevels shouldn't move in a crash only the shaft will move. I believe they are loose due to the material tamiya used on these.
I've been running my tb-02 since December and beside not being able to gear it as i would like to. is performance is quite close to the Evo 3.......
I thing i have notice is that motors get a lot hotter in the tub compared to the evo 3
DZ is offline   Reply With Quote
Old 01-14-2004, 04:58 PM   #289
wyd
Tech Legend
wyd's Avatar
I know my TA03R and my TB-01 are motor heaters.
Old 01-14-2004, 05:05 PM   #290
Registered User
Suradaj's Avatar
I know this may have been asked earlier in this thread....
Can the TB02 spur gear be converted to regular 64-pitch gearing?
Suradaj is offline   Reply With Quote
Old 01-14-2004, 05:58 PM   #291
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Suradaj, the TB02 comes with a plastic spur gear adapter, you can also use the aluminum version from the EVO3. So Yes you can use any spur. The only small draw back is that the motor mount only allows for preset motor and gearing. IE the motor doesn't have infinate adjustability. the mounting screws go through holes not a slot.
DZ. I almost made a mistake when I built my TB02. make sure that the pin in the driveline in in the correct hole for the spur gear. It is pretty sloppy if it is in the wrong hole.
tamiyarcracer is offline   Reply With Quote
Old 01-14-2004, 07:27 PM   #292
Send a message via Yahoo to pugo1
hi guys, do you have some setup tips for the tb-02 to handle well on a low to medium bite asphalt track (medium size combination of technical and fast).
pugo1 is offline   Reply With Quote
Old 01-14-2004, 07:45 PM   #293
The box set-up wasn't bad. Lengthen the upper arms, and possibly stand the rear shocks up. But that was with a silver can motor.
Old 01-14-2004, 09:07 PM   #294
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default TB-02 for sale
hey guys.. got a TB-02 with the three main hopups
- alum. steering
- alum. motor mount
- chassis stiffner
for sale in the for sale forum. look for the thread called "All of it has to go! For Sale/Trade" or simply click here
TB-02 for sale
thanks for reading guys!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-14-2004, 10:53 PM   #295
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Default Re: TB-02 for sale
- alum. steering
- alum. motor mount
- chassis stiffner
TB-02 for sale
That did not last too long...how come the sale?
madjack is offline   Reply With Quote
Old 01-14-2004, 11:17 PM   #296
izzyracer's Avatar
Default TB02 SS Top View
see anything else not legal?
Izzy
Old 01-14-2004, 11:23 PM   #297
izzyracer's Avatar
Pugo1, Pards! musta ang pasig riber!
The TB02 is very new but a good source would be the EVO 3 forum. set-ups should be similar.
Izzy
Old 01-14-2004, 11:25 PM   #298
RCGaryK's Avatar
Chris, ygpm.
Izzy, no, just the rear arms
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-14-2004, 11:58 PM   #299
Izzyracer, Dre!, pasig riber itim parin
Ok just search on EVO 3 forum nalang. thanks.
Old 01-15-2004, 04:03 AM   #300
supersonic's Avatar
Exclamation
well no one has read the tb-02 box, The box quotes: Compatible parts: TB Evolution III and TA 04 option parts plus a wide range of racing tyres. So those arms are legal . The bumper being attached to the gear box is not all bad as i have raced it and not heard any weird noise from the front gear box so i think i can safely say the gears have not striped.
supersonic is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
