Old 07-30-2009, 09:27 PM   #2116
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Originally Posted by tamiyarcracer View Post
Wow,
Being that the TA05 has the same diff front and back, I would think that it is not offset enough for the ring and pinion of a shaft car.
If I were to guess, a 415 rear diff would be a better fit than a TA05 diff.
But I have never tried either, so I could be wrong.
Because it was so long ago I did the change I could not remember which part box I got the diff from. After some research tonight I did figure out that it was a Rear diff from the 415.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is offline   Reply With Quote
Old 08-02-2009, 03:38 PM   #2117
Trader Rating: 112 (100%+)
Hello,
After doing some thinking, I am going to keep my TB02's. Does anyone have a good starting point for a carpet setup for the TB02?
Thank you
Dave
dragracer72nova is offline   Reply With Quote
Old 08-02-2009, 05:39 PM   #2118
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Originally Posted by dragracer72nova View Post
Hello,
Thank you
Dave
Dave,
I'll check to see if I ever wrote down my TCS setup for the TB02R. If not, I'm sure I can come up with a starting point to try.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 08-02-2009, 05:49 PM   #2119
Hello Jimmy!
I am going to run the car in RCGT this fall along with my 007's. I was going to sell them but no interest so I am keeping them.
Thank you for the help
Dave
Old 10-22-2009, 07:24 PM   #2120
gashuffer's Avatar
Trader Rating: 48 (100%+)
Are there aluminum ball diffs or at least the out drives that will work in the TB-02? Mine are about to go. Thank you
T-Sal
gashuffer is offline   Reply With Quote
Old 10-22-2009, 11:29 PM   #2121
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default yeah racing alum diff
here you go... http://www.yeahracing.com/catalog/al...bu-p-2283.html
Phat-Boy is offline   Reply With Quote
Old 12-17-2009, 10:51 AM   #2122
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
I m Looking for Tb02 tub chassis, anybody got extra?
PM me
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 12-20-2009, 01:10 PM   #2123
Default TB-02.. Still usable for a newb to racing?
Hello,
I have my TB-02 that I built a few years ago, and never ran it much (got into a couple of other hobbies for a while)..
Now I'd like to try racing- I'm excited about silver can racing. Is the TB-02 usable in this manner? Does it fit into any TCS racing still? Do clubs still have "silver can"/Mabuchi racing, and if so and I were to use a TB-02, would I need all the diff upgrade stuff people talk about? Or are the stock diffs OK for silver can?
I'm in Maryland- near Baltimore. Anyone know of any electric racing around here?
JasonRP is offline   Reply With Quote
Old 01-14-2010, 06:34 AM   #2124
Hi there,
Does anyone know if there's a spool available for the TB-02? Or does the one for the TB-03 fit as well?
Thanks in advance.
Infinity IF14
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 01-15-2010, 06:37 AM   #2125
KREATOR1's Avatar
Good question, !!! spool for Tb02
Old 01-15-2010, 07:26 AM   #2126
f1larry's Avatar
Very easy to make a spool for the TB02. You can use a TB02 diff and get the Associated diff slipper pads. Replace the steel tamiya rings and take the balls out of the diff. Then you just put the diff back together like you normally would. You just need to reem the slipper pad hole to fit better on the TB02 diff. and then tighten the diff screw and you now have a spool. Works great on my TB EVO III SE.
Old 01-15-2010, 08:01 AM   #2127
Toh WL's Avatar
Just to check if the TB03 spool fits the 02. Cause I saw the item readily available.
Toh WL is offline   Reply With Quote
Old 01-15-2010, 08:17 AM   #2128
KREATOR1's Avatar
Thanks larry, i try to find some of my tb02 slip diff and try them on.
Old 02-21-2010, 04:38 AM   #2129
Default Finally...
I might just start putting my TB-02 together.
I want run TCS here in Southern California. What are the min hop ups that you would run with this car for GT-3?
Trying to keep it budget minded, basic ESC nothing fancy and maybe a Lipo so I don't have to worry about matched cell nonsense.
Open to suggestions, thanks
djfourmoney is offline   Reply With Quote
Old 03-25-2010, 10:02 AM   #2130
rcwanaB's Avatar
Trader Rating: 14 (100%+)
Default TB-02 conversion
Starting off I am not all that familiar with Tamiya on road cars. My buddy was given a TB-02 subaru and he is trying go VTA racing with this chassis. Its brand new, and to me it looks very similar in design to a Assoc. tc3-4 and should work fine but the first problem we are running into is gearing. We want to run a brushless motor and at our local track im seeing various cars with a FINAL drive ratio ranging from 3.8-3.3 when running 1cell lipo & 17.5 brushless. Unless im reading the manual wrong the closest we can get is 5.72 or around that. I have seen a TB-02 to TB-03 conversion kit for 90 bucks is this what im looking for? It looks like the motor mount in that kit is the slideing adjust type. Can i switch to 64 pitch gearing with that? Can this car be converted with out spending a fortune? Ive seen the 415 cars and they look bad a-- but $400+ is not an option right now. Thanks for any help.
rcwanaB is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
