Old 11-10-2008, 09:32 PM   #2071
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default tb-02
Originally Posted by mog ruith View Post
ok stupid question
is the tb02 discontinued or going to be discontinued some time soon
bcos the tb03 is out and im thinking of picking up drifting
tb-02 is dicontinued and parts are hard to find. some tb-02 kit is cheapper than tt-01 on ebay right now, but no parts (specally SPOOL) for drift. tb-03 is a lot better. wait till tb-03d coms out.
Phat-Boy is offline   Reply With Quote
Old 11-10-2008, 09:36 PM   #2072
mog ruith's Avatar
phew thanks alot i was about to get myself a tb02 since its very cheap
when it occur to me that the tb03 was just release
mog ruith is offline   Reply With Quote
Old 11-10-2008, 09:46 PM   #2073
Phat-Boy's Avatar
Default tb-02
tb-02 also has some problem on gear stripping, and melting ball diff out drive, etc... read this thread helped me a lot.
Old 11-11-2008, 06:44 AM   #2074
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
have anyone who owns tb-02 tried to put Short Reversible Susp Set from 416,ifs-r, and tb-03? will it fit on tb-02? what do i need to make work? i know tb-02r and tb evo iii use 415 susp set.
anyone has 27t av pinion and f201 52t gear for sale?
Hpi makes metric 48 pitch pnions up to 33t. I can get you the part numbers. I can get you the f201 gear if you haven't got one yet.
let me know
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 11-11-2008, 03:51 PM   #2075
Trader Rating: 22 (100%+)
Originally Posted by reenmachine View Post
How about this spool? Is it new? I can't tell from the pic if the outdrives are both aluminum or if one is plastic.
TB-02 Spool on eBay
The only website I can find for Tech Racing is all in Japanese, so if anyone here can read it for info on this spool that would be very helpful.
Tech Racing
Got this pic from the tech racing site and description translated via google
Tamiya drift machine-made "TB-02D" for the spool.
Since its introduction, the tension around the scene of the drift-tech HAIENDODORIFUTOMASHIN "DT-1 Speed" is used in the joints of steel parts with high stiffness, lightweight aluminum body and the light weight and durability Achieving balance,
The new development is a hybrid of the spool. DT-1 Speed Performance and durability, "DT-1 Speed" is a proven.
In the rear, of course, can be used to the front to rear to use in a KIKKAKE make you better, to improve speed and power.
If you drift to the front for easy stance to stabilize and even beginners who can enjoy a relatively easy run to the drift is by design.
品番 TTBD010 No. TTBD010
定価 \2400 Price \ 2400
twister25 is offline   Reply With Quote
Old 11-11-2008, 05:09 PM   #2076
reenmachine's Avatar
Trader Rating: 26 (100%+)
THANKS!
I love the TB-02, have two, and the only thing that's ever bugged me was the lack of an available spool. I've been using homemade ones and they only last so long. This looks like the perfect spool, with an aluminum center and hardened steel outdrives. I'm going to order a couple right away and I'll post details once they arrive.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 11-11-2008, 10:04 PM   #2077
I decided to get one too. I'm planning to try it on my evo IV if it will fit. If not, then I'll use it on my TB-02. Thanks for posting that link
Old 11-11-2008, 10:34 PM   #2078
Heheh, when I posted the link it said "3 available". After you saw it it said "2 available".
Now it says "0 available"...
Pete Waydo
Old 11-15-2008, 06:00 PM   #2079
Originally Posted by rctouringracer View Post
Is there any way to get the gearing to match the 4.20 fdr for VTA racing with this chassis?
Yes! I did a bunch of gear mesh calculations, ordered up a couple of gears, and it works.
I shot for a little higher (numerically) FDR of 4.37 and it meshes perfectly, so my calculations were sound and these other gearing combos should work.
All of the following numbers pertain to 64p gears (use the "hockey puck" spur adapter that came with the kit).
FDR 4.37:
- 74t spur, 44t pinion, motor mount position B.
- I got these from superiorhobbies.com. 44t pinion=RRP4344, 74t spur=XENG640074
- tested and meshes perfectly
FDR 4.28:
- 74t spur, 45t pinion, motor mount position C.
FDR 4.25:
- 72t spur, 44t pinion, motor mount position A.
- 72t spur may be hard to find, but PRS just started making them.
FDR 4.47:
- 74t spur, 43t pinion, motor mount position A/B.
- 3racing mount A/B position will probably work perfectly with this combo
FDR 4.58:
- 74t spur, 42t pinion, motor mount position A.
It wouldn't hurt to use the 3racing motor mount with any of these combos as it gives you finer mesh adjustment.
Pete Waydo
Old 11-15-2008, 10:19 PM   #2080
I received the spool today and I just had to put it together. I don't have time to put it on the car, but it looks like it should fit fine on the TB02 and on my evo IV. Here's a pic with the stock TB02 ball diff.
Old 11-18-2008, 05:43 PM   #2081
Received two of these spools today and installed one. Everything fits and works perfectly! Finally, a spool for the TB-02. Two thumbs up!
Pete Waydo
Old 01-02-2009, 04:58 PM   #2082
Trader Rating: 112 (100%+)
So does they anyone have Evo III parts laying around for a new TB02 owner?
Planning on using in VTA
Dave
dragracer72nova is offline   Reply With Quote
Old 01-03-2009, 07:45 PM   #2083
RielTime Racing's Avatar
What are your thoughts or opionions on the topic of gearbox ratio's http://www.rctech.net/forum/electric...ox-ratios.html
RielTime Racing is offline   Reply With Quote
Old 01-03-2009, 08:53 PM   #2084
Hawk6's Avatar
Trader Rating: 50 (100%+)
Dave
Dave,
What are you looking for? Carbon shock towers and stuff like that? Derek and I used to run TB-02s and Evo IIIs and have some parts laying around.
Let me know.
Hawk6 is offline   Reply With Quote
Old 01-03-2009, 10:43 PM   #2085
Hawk,
Pm'd you back
Dave
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
