Old 08-27-2008, 08:00 PM   #2056
808TXT1's Avatar
What is the formula to find the gear ratio for the TB02??
808TXT1 is offline   Reply With Quote
Old 08-27-2008, 08:02 PM   #2057
reenmachine's Avatar
Trader Rating: 26 (100%+)
(spur teeth/pinion teeth)*2.6=FDR of the TB02
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 09-06-2008, 11:39 AM   #2058
just built my tb02 and was wondering if anyone knows what the big puck is on the parts tree? is it an adapter for standard spur gears? if so what size 64 pitch spurs can i fit in this car? thanks in advance. mike
MiniMike is offline   Reply With Quote
Old 09-06-2008, 04:32 PM   #2059
I recently discovered myself that it is indeed an adapter for standard spur gears. I don't know how big a 64 pitch gear you can fit, but you can fit them.
Pete Waydo
Old 09-21-2008, 08:16 AM   #2060
i am running a lrp sphere speedo with novak13.5 brushless motor, anyone give me some gearing like spur and pinion to start with for good pop out of corners and good top speed down the straights.
Old 09-29-2008, 01:45 PM   #2061
Trader Rating: 70 (100%+)
hey guys I have a stock TB02 and I want to run on my local track in the stock class. A lot of people have Xrays, Serpent, Cyclones, Ta05s. My question is can I compete with this chassis or I have a big disatvantage?????
lnc0321 is offline   Reply With Quote
Old 09-29-2008, 02:46 PM   #2062
P956LH's Avatar
As long as you've got the right gear and setup, and you're an OK driver, it can still hang on with most modern touring cars. The TB's heavier (about 100g or so) than the carbon double-deck cars, and only marginally heavier than the TA05 and have annoyingly limited gearing range (something TA05 owners don't have to deal with), but otherwise it's alright. There's no reason not to try racing it (you can do a lot worse than racing a TB-02...), but I wouldn't pump so much money into TB-02 specific upgrade parts, since it is essentially a 6-year old design by now
TL-01, TB-02R, RS4 Pro 3, TA05R, Desert Truck.
P956LH is offline   Reply With Quote
Old 11-10-2008, 08:24 AM   #2063
Send a message via AIM to 89Mirageman
I just picked up 3 Tamiya TB-02's (58317 Mercedes) off ebay for $220 shipped. One for me, one for my 10 y/o daughter and even decided to get the wife one. I figured for roughly $73 each I couldn't go wrong for brand new cars. Especially with bearings, shaft drive and oil shocks.
Anyway I'm a Mitsubishi fanatic so I'll be painting up an Evo 6 body for mine, my daughter likes the SX4 and I'm torn between the Evo 7 or Suby body for my wifes car. I am wanting to convert all of them to rally cars and build a track in our backyard which also conveniently has a hill.
I know that I can lift them up a little and get rally block tires from either Tamiya or HPI but how should I build the shocks and with what weight oil? Any other tips for this conversion? What ride height am I looking for Rallying? We will all be keeping the stock motors and this will be a very low budget deal. Just wanted something fun to do with the family. I've been out of RC cars for probably 10 years or more and they have never even driven an RC car.
89Mirageman is offline   Reply With Quote
Old 11-10-2008, 11:21 AM   #2064
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Is there any way to get the gearing to match the 4.20 fdr for VTA racing with this chassis?
rctouringracer is offline   Reply With Quote
Old 11-10-2008, 12:38 PM   #2065
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
I've been wondering the same thing, however since I've been using my old 415 msxx for T/A I havent really tried.
I do have the YEAH racing motor mount on mine, which allows for some additional adjustment. I'll pull it out this week and see if I can get something to work.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 11-10-2008, 01:06 PM   #2066
What is the YEAH motor mount and where can i purchase one, do you have a part number?
thx
Old 11-10-2008, 04:29 PM   #2067
How about this spool? Is it new? I can't tell from the pic if the outdrives are both aluminum or if one is plastic.
TB-02 Spool on eBay
The only website I can find for Tech Racing is all in Japanese, so if anyone here can read it for info on this spool that would be very helpful.
Tech Racing
Pete Waydo
Old 11-10-2008, 07:40 PM   #2068
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default Short Reversible Susp Set
have anyone who owns tb-02 tried to put Short Reversible Susp Set from 416,ifs-r, and tb-03? will it fit on tb-02? what do i need to make work? i know tb-02r and tb evo iii use 415 susp set.
anyone has 27t av pinion and f201 52t gear for sale?
Phat-Boy is offline   Reply With Quote
Old 11-10-2008, 08:12 PM   #2069
mog ruith's Avatar
ok stupid question
is the tb02 discontinued or going to be discontinued some time soon
bcos the tb03 is out and im thinking of picking up drifting
mog ruith is offline   Reply With Quote
Old 11-10-2008, 09:07 PM   #2070
waOscar's Avatar
I am confident that the short TRF suspension will fit.
You will need to change the length of your Swing Arms.
I had a TB-02 with standard TRF suspension and the only difference is the slightly shorter arm length, so I can not see a problem.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
