Old 07-07-2008, 03:20 PM   #2041
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
No won't work...
rctouringracer is offline   Reply With Quote
Old 07-10-2008, 12:42 AM   #2042
What is the maximum length of universal shafts can be used on the tb02?
hermanchauw is offline   Reply With Quote
Old 07-11-2008, 12:14 AM   #2043
If your using the 'E' toe blocks the 46mm shafts with work...
For all other narrower toe blocks you can use up to the 44mm shafts found on the TRF416....
Old 07-11-2008, 07:39 PM   #2044
reenmachine's Avatar
Trader Rating: 26 (100%+)
I have a new Porsche Carrera GT body set (w/wing, mirrors, decals) from my TB-02 kit if anyone wants it. Make an offer...
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 07-11-2008, 09:37 PM   #2045
Is it correct that if you use the reversible suspension with 950 bearings you would need 46mm?
Old 07-11-2008, 11:01 PM   #2046
Blueman Austria's Avatar
Yes !
In my TB02R i run B/A in front, and A/C in the rear (the rear uprights are the 1 ote in), with the 46mm swing shafts.
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 07-14-2008, 12:48 PM   #2047
I searched this thread and found lots of speculation about a front spool for the TB-02 but no definitive answer (maybe I missed it). Will the Evo IV or any other spool fit the TB-02? I don't mind having to change dogbones or universal shafts. I have a spool in my TA-05 and it's extremely effective on our track.
Pete Waydo
Old 07-14-2008, 01:37 PM   #2048
good luck finding one.
slomo is offline   Reply With Quote
Old 07-14-2008, 01:51 PM   #2049
ummm...does that mean it'll fit?
Pete Waydo
Old 07-14-2008, 11:28 PM   #2050
No it doesnt fit!
But i have made a spool with the black stock diff outdrives.
First build a diff without the balls, an instead the diff rings, use sandpaper and glue it on the diff halves. The ball bearings i replaced with normal bearings.
Then i screwed it thogether, but with a normal shim instead of the trusth bearing.
to secure that it does not open up, drill a 3mm hole during the diff half, the ring gear and the second diff half. after that i take a screw wich is normaly mounted in the arms for adjust the droop. and secure the hole diff that it cant open.
after attaching the bearings on the diff outdrives, secure them with fiber tape.
I have build one, but never tried it out yet. But i think this must work.
Greetings Blueman
Old 07-15-2008, 10:01 PM   #2051
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Can anyone give me a base line for gearing on med outdooor track with the sport tuned black can motor?
VenturaDC is offline   Reply With Quote
Old 07-19-2008, 09:47 PM   #2052
I can lol! Maybe I shouldn't since I'll be competing with you! When I ran my TA-05 with the black can a 7.16 FDR (stock 70T spur, 22T pinion) was effective. I got the TB-02 together last night and shot for the same FDR, running the 58T spur with a 21T pinion, which yields 7.18 FDR. On the street at least it feels great!
I was actually pretty amazed at how this car performed. I built it box stock settings, black can, TEU-101BK. Shocks have 80-wt AE silicone oil with 2-hole pistons and in the absence of a spool the front diff is as tight as it can go. I also put the longer TA-05 dogbones in the front. They're not too long (don't bottom) but sit quite a bit further into the outdrives which will mean fewer broken outdrives and no ejected dogbones.
I really can't wait to get it on the track in Vintage T/A!
Pete Waydo
Old 07-20-2008, 09:10 AM   #2053
Your set-up isn't going to work at Tamiya. If you need some help PM me.
Juan Aveytia is offline   Reply With Quote
Old 07-20-2008, 10:34 AM   #2054
VenturaDC's Avatar
We're not running tcs and for our track near box stock with 80wt seems to be the ticket
Old 08-26-2008, 10:15 PM   #2055
If I get the 52T spur (53552) will it work with the 24t and 25t pinions for 5.63 & 5.41 FDR respectively? That FDR range is supposed to be the ticket in USVTA with 27T/4-cell.
Pete Waydo
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
