Old 02-25-2008, 12:32 PM   #1981
Waltrip55's Avatar
I ran a TB-01 with stock everything(rules only allow changing of shocks). I ran 80wt, stock springs, ride height level at a "rally stance"(I honestly didnt measure it), and -2 camber all around. I could post some pics for sure when I get back from tennis practice...if its ok to post tb-01 stuff in this tb-02 forum
Brett Steller <><
HPI Blitz ESE 17.5--HPI Blitz 17.5(wife's)--Tamiya TT-01R--Tamiya TB-01 Rally (retired)
Waltrip55 is offline   Reply With Quote
Old 02-28-2008, 07:00 AM   #1982
Aluma's Avatar
LOL, I kinda meant rally setup for the TB02.
I had a TB01 many years ago, it was so much fun at the offroad track...that thing could take a BEATING!
Aluma is offline   Reply With Quote
Old 02-28-2008, 08:09 AM   #1983
green_overcomer's Avatar
Default TB02 or TA05
I am at a dilemma between choosing a TB02 and a TA05. Towerhobbies lists the two chasses as being of the same price range and I'm aware that the former uses shaft while the latter uses belts. Which chassis should I choose given these conditions:
1. I need a chassis that already has ball bearings on all prescribed areas and adjustable front and rear arms.
2. I drive on tarmacadam or asphalt with a few stones littered along the way.
3. I am looking for a chassis that can be as durable as my TT01.
Thanks. Please feel free to add your inputs.
Konti ang alam...........................sa RC.
green_overcomer is offline   Reply With Quote
Old 02-28-2008, 08:37 AM   #1984
miller1990's Avatar
Both the TA-05 and TB-02 are very durable cars considering they use the same suspension. Since you are running on asphault I would recommend you buy the TB-02 because it is shaft drive and if you have a TA-05 you could get rocks in the belts and easily ruin the car. The TB-02 drivetrain is way more efficient for the surface your running on. If you were running indoor on carpet or even outside on smooth asphault then I would say get the TA-05.
If you go on www.tamiyausa.com there is a TB-02 with Mercedes-Benz body thats discounted at only $119. This is because the body is an older style.
I would go with the TB-02!
-Tamiya TA-05 for GT-2 and 13.5
-Tamiya TL-01 for Rally--"TEAM GREEN"
-Tamiya TT-01 for driveway racing
Team Holy Rollers
miller1990 is offline   Reply With Quote
Old 02-28-2008, 09:43 AM   #1985
Waltrip55's Avatar
I haven't found time to post pics of it...so I guess its a good thing you didn't mean TB01. My guess for a TB02 setup would be 80wt, one hole pistons, no droop screws, and ride height at a nice, level "rally" height.
Brett Steller <><
Old 02-28-2008, 09:46 AM   #1986
Waltrip55's Avatar
The TA-05 is a much better car for the money, and is also a better race car. BUT, if you are outside with pebbles...an awesome belt drive car will be useless if one little pebble gets in the pullies or between the spur gear and pinion gear. If you want to take the risk, the TA-05 is a better car...but the TB-02 would be more durable drivetrain wise.
Brett Steller <><
Old 02-28-2008, 03:55 PM   #1987
Ed237's Avatar
Considering that the cost of buying both a TA05 and a TB02 would be less than a single TC5 or JRXSr or Xray I would get both and then decide for myself which was better.
Keep the one that works the best and sell the other one for almost what you paid for it!
Ed237 is offline   Reply With Quote
Old 03-03-2008, 12:58 PM   #1988
Send a message via Yahoo to hicheef
Default Diff outdrives
What's up all,
New owner here and I was wondering is there a hop-up for the stock plastic outdrives on the TB02? I've see the ones for the EVOIII, I was wondering if they were a fit. Got an 11 year old just started racing and he's been hell on those plastics
Thanks All,
Kevin
hicheef is offline   Reply With Quote
Old 03-03-2008, 06:13 PM   #1989
wog....supraman's Avatar
Send a message via MSN to wog....supraman
Originally Posted by hicheef View Post
What's up all,
Thanks All,
Kevin
yea the EVO III outdrives is a direct fit......actually......just so you know...the TB02 and the EVOIII are 95% identical...and almost everything on the EVo will fit on the 02....almost everything...the EVO III outdrives, go the delrin plastic ones, there white so you know....and they are much better than the stock pieces of c$ap.....!!!!
wog
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 03-07-2008, 12:22 PM   #1990
Aluma's Avatar
See, now that's what I was curious about. What does "rally" height mean? 8mm? Should I replace the normal shock ends with the longer ones that the TB01 uses? I was thinking of running with the 1/10 buggy class for fun.
Old 03-07-2008, 03:51 PM   #1991
Waltrip55's Avatar
I manual for the TB-01 tells you to use the normal shock ends up all around. The shocks are just longer in the back. My ride height is around 10-15mm. If you actually have to jump or roll jumps, being lower will have you digging into the clay/dirt.
Brett Steller <><
Old 03-09-2008, 10:27 PM   #1992
heyas,
just wondering a few things bout the diff screws on the o2......i havent blown a screw in a while now, but since drift puts a load of stress on the screw, itll blow sooner of later.....anyways....on my ta05 i noticed that the spring goes on the other side of the diff...so it goes
screw/bearing/outdrive/ring gear/outdrive/spring/locknut holder/lock nut
whilst on the tb02 it goes
screw/bearing/spring/outdrive/ring gear/outdrive/locknut...
if i was able 2 sum how get a ta05 outdrive 2 fit on the tb02 would it solve the tb02 diff problem...i have also noticed that u cant 'lock' a ta05 diff with just tightening the screw!!, why?? is it coz the bearing jsut allows the screw to turn, thus not allowing a 'lockd' state??
cheers
wog
Old 03-10-2008, 01:58 PM   #1993
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
Default Brushless TB02R
I dusted off my TB02R to use in the Vintage Trans AM series races we have been running and wanted to share my findings for using a 17.5 brushless:
I have the Yeah Racing adjustable motor mount, and found that a 76 tooth spur with a 53 tooth pinion (3.72 FDR) provides a good gear mesh.
Was great to bring the car out of retirement, and have it be competitive again.
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 03-10-2008, 08:18 PM   #1994
secretsg's Avatar
Stupid question. But does everything on an EVO III fit on the TB-02 chassis? I was thinking of getting a TB-02 to drift with. If I can use all the EVO parts then no hop ups are needed.
secretsg is offline   Reply With Quote
Old 03-11-2008, 09:17 AM   #1995
look a few posts up, some1 askd the xact same question on this page......does any1 actually read the last few pages b4 they ask questions???
wog
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
