Old 12-16-2007, 11:36 AM   #1891
Waltrip55's Avatar
Originally Posted by KREATOR1 View Post
Thanks Waltrip55 for the parts number. Does the TB-01 Cup joints: Part # 53590 still on the market?
Well im running Tamiya universal allround with tamiya blue sealed bearings,
Alumn motor mount, alumn steering set , front blue n red rear stabilizer bars , SSg stifner plate and TRF dampers.
I just ordered the Tb evo III Lightweight prop. shaft.
The only problem is my drive train (stripping Bevel gears) and i burn 3X 23 turn stock motors with this kitt.
Any suggestions?
My TB-02 pic.
The TB-01 Cup joints are still on the market, Tamiyausa.com has them out of stock right now, but they are most likely on order. I picked up my cup joints from Trackside, with the rest of the stuff from local tamiya guy Marty(414mph) and Towerhobbies. After reading your hop-ups on your TB-02(which looks nice), I forgot about my front stabilizer and my White and Blue springs.
As far as the stripping, I'm going to see f1larry on Jan. 1st about the front bevel gears.
What's your gearing with those motors?
Brett Steller <><
HPI Blitz ESE 17.5--HPI Blitz 17.5(wife's)--Tamiya TT-01R--Tamiya TB-01 Rally (retired)
Waltrip55 is offline   Reply With Quote
Old 12-16-2007, 11:38 AM   #1892
Waltrip55's Avatar
Originally Posted by wog....supraman View Post
well just to help bring this thread back 2 life, i thought i would show off my TB02 just a lil bit :P
PICS!!
plenty hopped up.....although it is soo hopped up.....it aint finished.....iam lookin 4 1 more thing!!!
a front tb02r brace.......and maybe, mayb a evoIII top plate!
wog
Nice TB-02, little more blue than mine!
Brett Steller <><
Old 12-16-2007, 12:40 PM   #1893
Waltrip55's Avatar
Pics of mine...its got everything that counts on it
Tamiya TB-02-tamiya-cars-005.jpg   Tamiya TB-02-tamiya-cars-006.jpg   Tamiya TB-02-tamiya-cars-007.jpg   Tamiya TB-02-tamiya-cars-008.jpg
Brett Steller <><
Old 12-16-2007, 01:27 PM   #1894
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Waltrip,
do you have the blue driveshaft that is tapered? You need to make sure that you have that one as it is 2mm longer than the stock shaft. Thats the first thing you need to be able to avoid striping the bevels.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC WC-Xti|TT02|TA05|TL01|
f1larry is offline   Reply With Quote
Old 12-16-2007, 02:29 PM   #1895
Waltrip55's Avatar
Originally Posted by f1larry View Post
Waltrip,
I don't...and my buddy has the blue one and I noticed they are different. Will the blue lightened evo III shaft fix my problem...or do I need another one? Thanks for the help.
Brett Steller <><
Old 12-16-2007, 02:39 PM   #1896
f1larry's Avatar
Even after getting that shaft you will have to shim inside the gearbox, Thats the part I will show you how to do on New Years day.
Old 12-16-2007, 03:20 PM   #1897
Waltrip55's Avatar
Sounds good...I will stop by your pit then. Is the lightened blue evo III shaft the one I'm looking for? Part # 49369
Brett Steller <><
Old 12-16-2007, 04:23 PM   #1898
f1larry's Avatar
Yep
Old 12-16-2007, 04:50 PM   #1899
Waltrip55's Avatar
Mom and Dad said my brother and I can get our brushless systems early so we can practice on the 23rd. This will get us ready for our first race with brushless on Jan. 1st
Brett Steller <><
Old 12-16-2007, 09:51 PM   #1900
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
my ratio is 6.85 (58T spur + 22T pinion) with yokomo LR 23 stock motor.
It gets really hot after few minutes.
What motor and ratio are you running?
KREATOR1 is offline   Reply With Quote
Old 12-16-2007, 10:12 PM   #1901
Waltrip55's Avatar
I'm running a Trinity CO27 motor with 58T and 19T. Trackside is a pretty tight course, but my motor and esc are never really that hot.
Try gearing down. I tried running a 20T pinion gear...and everything was hotter because I really didn't have as much torque and my speed down the straight wasn't as fast because I didn't get off the corner as fast going into the straight. With these metric 48 pitch gears, one tooth makes a huge difference.
Brett Steller <><
Old 12-16-2007, 10:12 PM   #1902
Waltrip55's Avatar
Since I did a double post by accident, I might as well tell you that Robinson Racing pinion gears are a must. Much smoother and last waaay longer than the stock tamiya pinion gears.
Brett Steller <><
Old 12-16-2007, 10:53 PM   #1903
wog....supraman's Avatar
Send a message via MSN to wog....supraman
dam you......iam getting my BL system (hopfulli a 3.5 GTB) on chrissie along wit my new TA05...u think the standard TA05 will handle it....or should i stik in sumthin a lil less powaful and put te 3.5 in my TB02??
cheers
wog
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 12-17-2007, 11:01 AM   #1904
Waltrip55's Avatar
cheers
wog
That's a lot of motor...I would put it in your new TA-05. Belt drive is much more forgiving, and the general rule of thumb is that shaft drive is for stock/19T racing and belt for modified(but everyone runs belt now). Your TB-02 will be able to handle it ONLY if it has the evo III outdrives, but the TA-05 stock diffs are good out of the box.
Brett Steller <><
Old 12-25-2007, 03:23 PM   #1905
Waltrip55's Avatar
Ran my car with my new 13.5 on Sunday...what a blast! I just had to dial drag brake to my liking, and my car was really hooked up. At trackside, they are all getting their gear ratios around 5.0 or so...and my car was at 5.7(thats the lowest!...for now). I ran a best lap time of 11.3....while all those pro guys are running 10.5s. The difference is that I am more consistant...many 11.4s and 11.5s in a row. I do have a trick up my sleeve though, the F201 52T spur gear will fit the TB-02, so that will make my final ratio around 5.4. Should be able to hit 11 flat or less for sure! Remember I am one of the few with a shaft drive tub chassis...and I those guys are running top of the line stuff. I'll give you an update after the new years day race.
Merry Christmas by the way!
Brett Steller <><
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
