Old 10-21-2007, 11:48 AM   #1876
tb 02 is pretty much obsolete already. Stick with your 05 and change the gears to 48 pitch. They should be fine for outdoor.
slomo is offline   Reply With Quote
Old 10-21-2007, 01:48 PM   #1877
Trader Rating: 26 (100%+)
slomo, thanks for your response. i tried calling around the LHS and none of them carry the tb02. even tower only has 3 kits compared to the tons with ta05s and tt01s.
i'll consider your suggestion and go from 64(?) to 48 pitch and see if that makes a difference with my debris problem
Tamiya TRF416
Tamiya TA05-R
XRay T2 '007 EU
Mini-Z Parts Bonanza
http://www.rctech.net/forum/showthread.php?p=4709247
limbohz is offline   Reply With Quote
Old 10-22-2007, 06:04 PM   #1878
shaggys40oz's Avatar
Originally Posted by Monky View Post
nope..your wrong....ss4300 is equal to 19t.
The SS4300 Racing Stock Brushless Motor is one of three brushless motors from Novak. Designed for use with either the Super Sport ESC (#3205) or the Super Sport Plus Brushless/Brush ESC (#1705), the SS4300 provides all of the advantages of the SS5800 Brushless Motor, but provides lower speeds for increased vehicle control for newer drivers, and longer run-times for those trying to get some valuable "practice" time on the track. With a Kv rating of 4,300 RPM/Volt, a Kt rating of 0.45 in-oz/amp, and a power output of 175 watts, the SS4300 Brushless Motor provides performance similar to a 27-turn racing stock brushed motor.
That was from Novak.....
5800 = 19t
4300 = 27t
I know people say the 4300 is faster than 27t tho
I have some RC cars and other stuff.....shaft drive forever!!
shaggys40oz is offline   Reply With Quote
Old 10-22-2007, 06:07 PM   #1879
I love the tb-02 and it is a great out door basher. There is a guy selling a totally hopped tb-02r for 150. I think it is an evo 3 surikarn edition with a tb-02 tub chassis.
http://www.rctech.net/forum/showthre...10942&page=107
Old 12-15-2007, 08:30 PM   #1880
just read this whole threads...seems the TB02 is not so current anymore.....
but i do have a few questions:
1. has anyone who installed and _RACED_ the TB02 with the reversible lightweight suspension set, broken or fractured a lower arm?
i know they are titled lightweight but they also seem to be made of a more durable material.
2. did the reversible arm set widen the car's _TRACK_ at all?
3. has anyone seen a TB02 with a tub and the _PLASTIC_ covers over the spur/pinion area that also was using the EvoIII upper carbon deck?
4. is there a general setting that would have a TB02 have a front end that bites well in the corners and a rear end that would break free easily? is it just a camber setting or will springs come into play?
thesuper is offline   Reply With Quote
Old 12-15-2007, 08:41 PM   #1881
The lightweight reversible suspension(evo Iv arms) is used on pretty much every modern tamiya race car, except the short evo v version. When they first came out, people thought they were fragile compared to the ta04 arms, but they are very sturdy.
Old 12-15-2007, 09:34 PM   #1882
Waltrip55's Avatar
I'm still running my TB-02, and it's running awesome. The only complaint is the bevel gear stripping in the front, but the car is good otherwise. I'm running a lightened evo III shaft, reinforced evo III diff halves in back, front one-way with evo IV metal gear, universals all around, aluminum clamp hexes, carbon fiber rear brace(to make motor maintance easier), and bearings for the plastic steering. If I set the mesh between the bevel gears tighter, will I eliminate my problem
Brushless 13.5 is on the way after Christmas!
Brett Steller <><
HPI Blitz ESE 17.5--HPI Blitz 17.5(wife's)--Tamiya TT-01R--Tamiya TB-01 Rally (retired)
Waltrip55 is offline   Reply With Quote
Old 12-15-2007, 10:19 PM   #1883
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Waltrip55 may i know the part number for the front one-way with evo IV metal gear. Any picture of that?
thankss
KREATOR1 is offline   Reply With Quote
Old 12-15-2007, 10:22 PM   #1884
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Waltrip,
if you are at Trackside on New Years day come see me and I will help you shim your front gearbox so it won't strip your bevel gears. I use to run a TB Evo III and I was able to fix the front so it would not strip, even when I ran 19 turn. One thing you might want to try and find is the square aluminum gear box. its not TCS legal but you should run all the time except during the TCS race. This will also help keep the front end from striping bevels.
Larry
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is offline   Reply With Quote
Old 12-15-2007, 10:53 PM   #1885
Waltrip55's Avatar
thankss
Evo IV metal gear: Part # 53721
Evo III one way unit: Part # 50991
TB-01 Cup joints: Part # 53590
They don't come together, everything is seperate and needs to be pieced together. I don't have a pic of my one-way, sorry. BTW, you will need front universals with this set-up.
Brett Steller <><
Old 12-15-2007, 10:56 PM   #1886
Waltrip55's Avatar
Originally Posted by f1larry View Post
Waltrip,
Larry
I will be there for the New Years day race. I will definitely stop by, I would rather fix the problem than drop a lot of money on a race-prepped TA-05. My TB-02 still hangs in there at Trackside Thanks for the help
Brett Steller <><
Old 12-16-2007, 08:14 AM   #1887
Aluma's Avatar
anyone interested in a TB02 R? Mine hasnt been used in about a year.
has evo 3 diffs in it too.
Aluma is offline   Reply With Quote
Old 12-16-2007, 09:14 AM   #1888
wog....supraman's Avatar
Send a message via MSN to wog....supraman
well just to help bring this thread back 2 life, i thought i would show off my TB02 just a lil bit :P
PICS!!
plenty hopped up.....although it is soo hopped up.....it aint finished.....iam lookin 4 1 more thing!!!
a front tb02r brace.......and maybe, mayb a evoIII top plate!
wog
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 12-16-2007, 09:15 AM   #1889
BLUE IS BETTER!!!
Old 12-16-2007, 10:34 AM   #1890
KREATOR1's Avatar
Thanks Waltrip55 for the parts number. Does the TB-01 Cup joints: Part # 53590 still on the market?
Well im running Tamiya universal allround with tamiya blue sealed bearings,
Alumn motor mount, alumn steering set , front blue n red rear stabilizer bars , SSg stifner plate and TRF dampers.
I just ordered the Tb evo III Lightweight prop. shaft.
The only problem is my drive train (stripping Bevel gears) and i burn 3X 23 turn stock motors with this kitt.
Any suggestions?
My TB-02 pic.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
