Old 10-18-2007, 09:52 AM   #1861
wog....supraman's Avatar
Send a message via MSN to wog....supraman
yea ummm i just bought a plethora of alloy 4 my Tb02.....
yea BL would kill the TB02 drivetrain....i can destory the car with mt 15 double...
a few Q's though
http://www.rcmart.com/catalog/produc...ducts_id=15784
http://www.rcmart.com/catalog/produc...ducts_id=15785
if those 2 graphite bits would fit on teh TB02....or if there are alloy bits..
thanxs
wog
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 10-18-2007, 01:09 PM   #1862
shaggys40oz's Avatar
You can definalty run a BL motor in a tb-02. The drive train is exactly the evo3's, and that car is specifically made for stock & 19t racing.
18.5, 13.5, 10.5 BL would all be just fine in a TB-02. Just make sure your diffs are in good shape and shimmed correctly in the gear box and you are good to go.
If you are having gear melt down with a 10.5 BL motor in your TB-02, then something is put together wrong.
I have some RC cars and other stuff.....shaft drive forever!!
shaggys40oz is offline   Reply With Quote
Old 10-18-2007, 01:59 PM   #1863
Trader Rating: 31 (100%+)
True.. but the EVOIII doesn't have the massive chassis flex a TB-02 does. I've never melted any gears, but the front diff or one-way starts skipping after a few races. This is with upgraded diff gears as well (Evo IV). I'd hate to see what it would do with a spool!
ittjv is offline   Reply With Quote
Old 10-18-2007, 02:03 PM   #1864
Cant you run an evo top deck or what about those carbon chassis braces?
slomo is offline   Reply With Quote
Old 10-18-2007, 03:45 PM   #1865
Yes you can use the evo 3 graphite upper deck on the TB-02 tub chassis, I have seen it but never done it tho. I am using the front and rear carbon braces, they save weight more than anything, and make the chassis easier to work on. they do not add much stiffness over the stock plastic pieces. The best way to super stiffen that chassis is to use the stock plastic pieces instead of the graphite front and rear ..... and run a bead of CA all the way around where they meet the plastic chassis .... it makes it a little harder to work on (using sovent to remove the 2 plastic parts), but it makes for a stiff A$$ tb-02!!
Old 10-18-2007, 03:49 PM   #1866
Have you tried adjusting/adding shims on one side or the other of the diff cups, to tighten up your gear mesh inside the gear box?? as the gears wear you may have to swap shims from one side to the other to get good mesh and no skipping ..... I have had diff gear skipping ..... and it suks!!!
Old 10-18-2007, 03:50 PM   #1867
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
to save yourself some stripping one way gears in the front put in the aluminum EVO IV ring gear. the bevels will eventually wear out but not as fast as the plastic one way gear does.
I use to run the aluminum gear in my EVO III in 19T and Stock and had no issues. Just make sure it is shimed right.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|X-Ray T4 16|CRC Xti Altered Ego|Associated B5M|TT02|TA05|TL01RA|TL01|
f1larry is online now   Reply With Quote
Old 10-19-2007, 04:55 PM   #1868
welll....im running a BL Novak SS5800....its like the same as 7 turns i think....its runs great...but snaps the diff pretty easiily...but its just a simple change. and yes you can run a uper deck and it changes everything...it helps alott...makes the whole chassis Stiffer!
just take a look....this is my tb02....not an R....i just slowly modding it...still not done....i didnt want to change to evo3 cuz alot of stuff is going to go to waste....like the carbon braces on the front and rear...and the ssg on the bottom....soo i just kept it as it is...but wen that time comes to change to evo3, i just need "J" bag parts, motor mount, and chassis.
Monky is offline   Reply With Quote
Old 10-19-2007, 05:50 PM   #1869
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
woo!!! madness
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 10-19-2007, 06:40 PM   #1870
Now thats da bling bling!!! Hardly TCS legal tho
The Novak 5800BL is equal to around 19t+/-, not quite 7T
Old 10-19-2007, 09:38 PM   #1871
better to have a clean light evo 3 than a cluttered tb02 in my opinion.
Old 10-20-2007, 05:48 AM   #1872
nope..your wrong....ss4300 is equal to 19t.
Old 10-20-2007, 09:40 AM   #1873
a few Q's though
thanxs
wog
Can sum1 please answer my question of whether these would fit the TB02
thanxs
wog
Old 10-20-2007, 09:46 AM   #1874
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
thanxs
wog
No they wont
look for EVO3 shock towers
tamiyarcracer is offline   Reply With Quote
Old 10-21-2007, 09:33 AM   #1875
Trader Rating: 26 (100%+)
Default tb02 bashing
hello all!
i'm just getting back into the RC hobby since my high school days (about 15 years ago?).
i bought myself a ta05 and i had thought i could use it for casual racing and bashing with friends in parking lots and parks (unprepped surfaces). unfortunately, debris keeps getting in between and eating my pinion and spur.
so, with that said, i have a ton of questions...
i was wondering if a tb02 is a viable bashing car?
will the tb02 be in danger of becoming obsolete in a year or two?
will the speed and handling be a lot different than my ta05?
will i be able to upgrade the motor to be competitive with my friend's 19t losi drift-r?
thank you all for your input.
limbohz is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
