Old 05-05-2007, 04:04 AM   #1846
dorikin234's Avatar
Send a message via MSN to dorikin234
hi all,
slight problem with my 02 a the moment,
ive got unbalanced steering....it turns more to one side than the other
any ideas on how to resolve this problem?
any help appreciated
thanks, ryan
dorikin234 is offline   Reply With Quote
Old 05-05-2007, 07:25 PM   #1847
pole_position's Avatar
Originally Posted by TB02Man
i took my evoIII and turned it into a TB02
Hi
Keep us posted about the conversion and the testings ...
Thanks!
pole_position is offline   Reply With Quote
Old 05-07-2007, 07:11 AM   #1848
waOscar's Avatar
Originally Posted by dorikin234
hi all,
thanks, ryan
Could be;
Servo saver not on centre of servo.
Stearing rods differant lenght or you may have bent one
Incorrect hole on servo saver
EPA adjustments on your radio
Could also be caused by unevan chassis setup.
Check things like, shocky holes same both sides, spacers on suspension shafts the same.
Good luck.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 07-25-2007, 10:32 AM   #1849
wog....supraman's Avatar
Send a message via MSN to wog....supraman
WATS wrong with this thread.....?????
IT IS SOOO DEAD!!!!!!
i have a TB-02 (4 like 8months now)...
i find it pretty good....just wondering which EVO III bits will fit on it....
coz like....i dunno wat i should dooo...scrap the -02 and go buy a Ta-05....or keep it and upgrade..
hop-ups soo far
lightweight prop shaft
alu steering set
TRF suspension
Delrin diff joints
TT01 battery strap (metal, modded to fit)
24/55 gearing
cracked chassis (got a spare cbf puttin it in)
1/2 a bumper
i tryd to make a motor cover (underneath...to stop rocks flying into my new jett v8.0) but it didnt work, it brokeded
i think thts it????
sooo wat yas think.....upgrade or new chassis...
i have been into this for about 1 1/2 years...and am a HUGE 1:1 scale enthusiast so i know how to set-up a car....so i think Ta05....how bout u, wat u think
wog....supraman is offline   Reply With Quote
Old 07-25-2007, 10:59 AM   #1850
At one stage I was almost going to migrate my entire Evo III over to a new TB-02...
Anyway, I got a TA05R now and I plan to restore the Evo III...
You can transfer everything from an Evo III to TB-02 except:
1. Motor mount
2. Spur gear
Old 07-26-2007, 05:20 AM   #1851
waOscar's Avatar
hop-ups soo far
alu steering set
TRF suspension
Delrin diff joints
24/55 gearing
1/2 a bumper
i think thts it????
See me Tuesday night, I think I got a couple of Evo III Surikarn shock towers.
The only other hop up I can think of is the light weight suspension set.
(which if you do buy an 05, or TRF product down the track can be re-used)
Toby
Old 07-26-2007, 09:56 AM   #1852
Toby
u want me to cum down to Rypers Tuesday night....ummmm mayb i could do that...cant tell u a definite answer 2day...but ok....are the towers more adjustable than the standards or they just lightweight bits
wog
Old 07-26-2007, 10:04 AM   #1853
waOscar's Avatar
wog
Tuesday night is racing at PRECC in Maylands.
The shock towers are lighter, stiffer and make shock angle adjustments much easier. Changing shock angle is a very simple adjustment for adjusting for grip levels at a know track.
I race at PRECC every Tuesday and at Rypers every Sunday, although the weather has not allowed much Ryper racing lately.
Catch up to me sometime and I can tell you more.
Old 08-22-2007, 04:38 PM   #1854
shaggys40oz's Avatar
ANyone got a good set up sheet for the tb-02 on small-mid sized carpeet track on rubber tires? I'm sure there is one in this thread, I just couldn't find it
I have some RC cars and other stuff.....shaft drive forever!!
shaggys40oz is offline   Reply With Quote
Old 10-06-2007, 01:14 PM   #1855
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
1 question,need some help.
What upgrades do i need to run novak brushless on my stock TB02?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 10-17-2007, 02:41 AM   #1856
Monky is offline   Reply With Quote
Old 10-17-2007, 02:42 AM   #1857
oopsss....ignore that first post...
has anyone tried fitting this into the tb02?? if soo...wuts your opinion?? does it work??
http://www.rcmart.com/catalog/produc...ducts_id=17629
Old 10-17-2007, 08:12 AM   #1858
Common sense tells me that it probably wouldnt fit. Get ahold of an evo IV spool if you can. Evo 3 and 4 had the same one way and the spool should be of the same dimension. I was lucky and found a tamiya spool online somewhere.
slomo is offline   Reply With Quote
Old 10-17-2007, 09:53 AM   #1859
Trader Rating: 31 (100%+)
I doubt the TB02 can truly handle the power of a brushless motor. The drivetrain is strained with a 27T stock motor as is....
ittjv is offline   Reply With Quote
Old 10-17-2007, 09:57 AM   #1860
t4m1y4niac's Avatar
TB 02 can melt down if using BL 3.5R system
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
