Old 12-11-2003, 08:19 AM   #166
got a few queiries
i have an Evo3 SL, i was just wondering if you could use that same battery strap as it looks like it holds the cells down better?
and also how about that SSG stiffener thingy?
thanks alot
Tarnjit
Evo_Uk is offline   Reply With Quote
Old 12-11-2003, 08:23 AM   #167
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default TB-02 Mods...
Originally posted by Evo_Uk
got a few queiries
thanks alot
Tarnjit
EvoUK - id use the one that came with the kit. its not flat like the evo3 strap. its the same strap that yokomo SD uses. its shaped to fit the curves of a side by side back. holds the batteries more firmly.
Originally posted by madjack
I think you could come close if you used some standoffs that raised the plate from the plastic upper supports, but given the flex of the lower chassis I don't know how much more it would help.
(might be a fun project )
madjack hehe i guess ill be the first one to try it then. its not TCS legal then huh if you omit the front and rear plastic covers and just use the upper deck.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-11-2003, 10:10 AM   #168
Maybe thats why i was wondering, becasue i use side by side cells and if it holds them down better then it might be worth concidering?
Old 12-11-2003, 06:12 PM   #169
Aluma's Avatar
wow....while y'all are blingin' the tb-02 out to race onroad...I'm over here thinking of a replacement for the tb-01 rally racer.
we now have a car that has racebred suspension and a plastic tub and covered spur gear ....NOW if it only had a dust cover like the tb-01 and that nice WRX 2003 body....YEAAAAHHHH baby!
Bet rally would get a nice kick in the pants...
besides, who'd be nuts enough to use a surikarn evo3 at the park with your buddies and race around all over the place....
Aluma is offline   Reply With Quote
Old 12-13-2003, 04:13 PM   #170
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Thumbs up TB02 test at Tamiya America
I ran my "EVOed" TB today at Tamiya America
The set-up was the same as my EVO. Overall it worked very well with a 24 Monster. Very quick off the corners, plenty of steering at low speed and off power...the only improvement might be a bit more steering in the sweeper.
So far so good
madjack is offline   Reply With Quote
Old 12-13-2003, 07:24 PM   #171
SpeedTech's Avatar
madjack,
I was looking at Fred's car all day long, and I think I will join in on the Tamiya fun with my own TB-02 next week.
Also, I'm working on a Ti-Screw kit for the TB-02 right now.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 12-13-2003, 08:02 PM   #172
izzyracer's Avatar
Trader Rating: 27 (100%+)
Originally posted by SpeedTech
madjack,
Steve Wang
Steve, what about an Aluminum Screw Kit for all Tamiya Cars! It's legal and lighter who cares abotu strength. Will just replace em.
Izzy
izzyracer is offline   Reply With Quote
Old 12-13-2003, 10:20 PM   #173
SpeedTech's Avatar
Hi Izzy,
Aluminum are light weight, but titanium aren't that much heavier. In fact, if you have good grade titanium, they should be similar in weight to aluminum. The strength is key to Titanium, and because a lot of the screws are going into ABS plastci or nylon plastic parts on tamiya cars, Titanium would be a better way to go. The reason being, the plastic and nylon parts will provide a lot of resistence during installation of the screws and if they are aluminum screws, there will be more of a tendancy for them to strip or even just snap off.
I got the screws all calculated out (a total of 89 screws) and I believe we can have them available for around $40.
Steve Wang
Old 12-14-2003, 09:28 AM   #174
madjack's Avatar
Talking TB's
madjack,
Steve Wang
Steve,
I would have enjoyed staying...but had to knock out the "honey do list" before Christmas.
Glad to hear your back...it was just a matter of time.
JC
Old 12-14-2003, 11:49 PM   #175
gtypecanare's Avatar
Hey John,
The car looks good out on track this past weekend !
gtypecanare is offline   Reply With Quote
Old 12-15-2003, 12:20 AM   #176
Hebiki's Avatar
Default Surikarn TB-02
so this past weekend i joined in the madness for the TB-02.
i also ran my Surikarn'ed - TB-02 that Rod called the BLING Car. it ran great. transplanted my surikarn set up right into the TB-02.
really happy with it and i had fred inspect the car, he said its completely TCS legal.
during most of sat practice, i was trying to chase gtypecanare all day, that was fun
more fun next sat if im not on the slopes snowboarding.
Hebiki Design Works
Old 12-15-2003, 07:33 AM   #177
madjack's Avatar
Post EVO'ed TB02
Originally posted by gtypecanare
Hey John,
I'll guess the TB will be "the one" in TCS GT2 without a doubt.
I was concerned with the TB's weight vs. the 04, bit the drive train & suspension geometry seem to make up for that issue.
I plan on making a couple of changes before next Sat.(possible spring rate increase) to make up for that soft chassis...but overall it was pretty quick for the maiden voyage!
Old 12-15-2003, 11:44 AM   #178
izzyracer's Avatar
I'm also putting together my TB02. But I'm setting it up as a short wheel base. So far so good. I'll prepare it for Saturday at TA
Izzy
Old 12-15-2003, 07:51 PM   #179
Aluma's Avatar
hmmm...lots of talk of setups, I want to try a new one... I havent messed with my evo3 in a while....anyone have a good one for front diff equipped? I guess I could lock my front diff and tryout a spool setup. I run rubber tires, outdoors with bumpy tight asphalth track, 90ft straight.(not surikarn edition)
As it stands, I'm running this setup...handles nice for me, but inner part of tires seems to wearing more and car almost stops in the corners to rotate...pushes on power...I know it can go faster, I'm guessing its my setup.
Front copper springs, 1.5 camber, 0toe, shocks outterholes
AA blocks, no spacers, yellow sway. 50wt, top inner
camber hole on tower, 2mm spacer in wheels
Rear assoc. red springs, 1.5 camber, AB blocks, shocks 4th hole
yellow sway, 50wt, no spacers, top inner camber hole on
tower. 2mm spacer in wheels.
elects futaba servo S9+, LRP quantum comp., 2400's, p2k2
geared 72/30. switched to monster @72/26, but havent
tried it yet.
Old 12-15-2003, 10:43 PM   #180
Aluma soften the front rate way to stiff for balance. Stand up the rear shocks 2 holes lower the front 1 hole. Put 2 mm spacing under the rear blocks . Start there you should like the differences in feel If the track is bumpy as you say run 4mm front droop and 3 rear
Front spring rate should be 1 stiffer that the rear after that you start getting balance problems. I usually run the same at all foru corners
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
