Tamiya TB-02
#1741
Originally Posted by Aluma
wow, now that's what I'm talking bout! Thanks Juan! Do you mean having 2 mm of up travel? Like the little droop screw 2mm out of the arm? Also is this assuming I have the LWT suspension?
Yup, parking lot racing...well, its a dedicated track, but conditions are so bad, that'd it'd pretty much be an OOOLLLLDDD cracked, rutty, pebbly, parking lot that you'd find in an abandoned lot.
#1743
Dont want to be a bother but, when you say the longest camber link possible, does that mean:
Front camber link from C hub to the inner most hole on the mount?
Rear camber link from the outer hub hole to the inner most hole on the mount?
Stock spacers on the inner mounts too? 3mm front/ 2.5 rear.
#1744
hEy guys, is there anyone still sticking to their TB02 ?
#1745
#1747
#1748
Originally Posted by Hebiki
shake and bake! TB-02 is a very capable car if you like it, stick with it
#1750
Still race mine in the "mod" class in the club...finished 2nd today with a 3-season old set of HPI Pirelli tires and with an $18 17-turn Method R...
Just curious, what's the effect of increasing the rebound on the shocks (putting o-rings on the bladder)? I run 40-weight oil and 2-hole piston...
#1751
OH, great, I got those too! which hole do you use?
#1752
#1753
Originally Posted by westerdude42
You coming to the regional at SIR? If so what class. I know that at least 5 TB02's will be running GT3. I'm running the 05 cause it's smoother on power, but Jeff is maddeningly fast with his 02 and he only just started testing it.
#1754
Originally Posted by Juan Aveytia
I'll run my ta04. Hope it will be on pace.
#1755
Couple of them are running, they have been very fast. You commin up Juan? If so what class will you run?
