Tamiya TB-02
#1726
I used to race the tbo2,
use the evo 3 parts, the evo 4 will not fit.
You may want to invest in a TA05 I cannot count on how many diffs I went thru while racing this car. I think it was one or two a race.
good luck with your 02
wn
wn
#1727
The Evo IV spool will probably fit in your 02. My friend used the Evo IV outdrives on his TB02R which I believe are the same as the Evo III outdrives.
#1728
TB02, TB EvoIII and EB EvoIV all use same outdrives.
The EvoIII and the TB02 use the same ring gears.
But I don't think they released a spool for the EvoIII.
The EvoIV use differant ring gears (they changed the internal ratio on the EvoIV) so I'm not sure if that will work.
I would suggest posting your question on the EvoIV or EvoV thread because a lot of the guys who have those cars started with TB02s (just like me) and someone their should be able to give you a definate answer.
#1729
#1730
wn
wn
I raced a TB02 for 12 months and only damaged diff gears from very high speed head on collisions. I have a EvoIV now and i've read many complaints about bevel gear problems but again I haven't had any problems myself.
I still agree with you about the TA05. Excellent car for the price and with the right guy behind the wheel very capable of matching it with the top cars of any make. I run a TA05 for my daughter, our clubs top driver used it last week in stock and gave us a caning.
TB02 is a very capable car, if you are racing it, keep using it untill your consistancy is regularly around the 0.5 or below. Then its time to look for a new car.
Enjoy
#1731
Evo III/TB02 15T; EvoIV 17T; Evo 5 16T. Ring gear 39T.
#1732
Thank you all for your replies. About the gear stripping, It has happened once. I love the driveabilty of the car so much more than the the others I have to live with it. Replacing the gear boxes every 4-5 months is something I did with MY TA02, and something I do with this kit also. Cheers Amigos!!!
JUJUBEAN
JUJUBEAN
#1733
Hey guys,
Quick question, i broke the C-hub carrier on the front of my TB02
what one would be better?
http://cgi.ebay.com.au/Tamiya-50985-...QQcmdZViewItem
Or
http://cgi.ebay.com.au/Yeah-Racing-A...QQcmdZViewItem
Or any other from that site?
MDL
Or
MDL
#1734
tb02
If anyone is interested I have a bag full of hopups for this car. I no longer have the car, so the hopups, which were just installed, are for sale.
#1735
tbo2
Sorry for posting here...
#1736
Originally Posted by MDL
Hey guys,
Or
MDL
Or
MDL
#1737
my car is on crack! I raced this weekend and the first qual it was spinning out due to rocks getting stuck between the diff and inner camber mount.(shaved the mounts down) 2nd qual. car was pushing a bit too much, so I switched to blue front silver rear with top of shock all way out, from yellow yellow on first qual. 3rd qual, still pushing so switched to blue rear, silver front, with rear shock on outside hole on arm.(made it much harder) Actual race...Car pushed sooo bad, had to almost stop at each corner to turn! COuld swear that if the rear is harder it would oversteer, but it just planted the rear end! I was using assoc. springs, blue is harder than silver.
Did I miss something? why is it doing that?
#1738
I would go back to box stock settings. or a Tamiya yellow front and a Tamiya blue rear.
#1739
It's sounds like your racing in parking lot style tracks. Try not saucing your tires. Just clean them after each run.
#1740
wow, now that's what I'm talking bout! Thanks Juan! Do you mean having 2 mm of up travel? Like the little droop screw 2mm out of the arm? Also is this assuming I have the LWT suspension?
Yup, parking lot racing...well, its a dedicated track, but conditions are so bad, that'd it'd pretty much be an OOOLLLLDDD cracked, rutty, pebbly, parking lot that you'd find in an abandoned lot.
