Old 02-23-2006, 05:37 PM   #1681
Static_racing's Avatar
Does anyone know a good starting point for the monster stock motor for the TB02R? I'm looking to run it in the TCS races.
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 02-23-2006, 07:45 PM   #1682
rayman's Avatar
Try 20/58. I run on a 40m by 25 track and its a good start.
rayman is offline   Reply With Quote
Old 02-23-2006, 07:52 PM   #1683
Yeah I think thats a good place to start, I think I was running a 22 tooth last time. Thanks for the info.
Team Driver For:
Old 02-28-2006, 12:56 PM   #1684
crunchracer's Avatar
Question? has anyone tried using the spur gear off of a Trinity T-Spec sedan? It shows as a 60t, but does not say what pitch?
Any help would be great, Robinson quit makeing thier 60t 48 pitch gear p.n. #1960
www.FusionMotorsports.com
Team S.I.R
John's BSR Racing Tires
crunchracer is offline   Reply With Quote
Old 03-05-2006, 02:53 PM   #1685
Does anyone have a good set-up for asphalt??
Team Driver For:
Old 05-20-2006, 07:15 AM   #1686
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
anyone know the part number for the TB evo3 shock towers?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 05-20-2006, 09:49 AM   #1687
waOscar's Avatar
51017 TB-EvoIII Surikarn Limited Front Damper Stay
51018 TB-EvoIII Surikarn Limited Rear Damper Stay
waOscar is offline   Reply With Quote
Old 06-11-2006, 03:18 PM   #1688
Aluma's Avatar
well, FINALLY got to use my O2R....I set it up to its manual specs and ran it. wasnt sure on gearing though, so I used 58/22 to start. It runs as good as my evo3....but it kept spinning out on me turning left too much. So I check out the suspension settings using a board/setup stands...DANG! kit specs run something like 8deg camber up front and 6 out back with about 5deg toe out!!GGGEEEZZZZ. set it to 2deg front/rear and zero toe...much better but a screw came out of the steering arms. and couldnt continue.
Funny thing...it took me about a year to get the evo3 to handle that good.
Aluma is offline   Reply With Quote
Old 06-11-2006, 05:46 PM   #1689
Send a message via Yahoo to eagle racing
hi guys.......
i have my 02R can i use the 90t spurgear of evo3 in my 02R?
and wat 23t motor is better to use in competition
eagle racing is offline   Reply With Quote
Old 06-11-2006, 11:20 PM   #1690
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Originally Posted by eagle racing
hi guys.......
yes u can use it even if the kit wouldnt... ofcourse ur the boss.. ahehehehe
and about the 23t motor.,, dont use any motor on it,, just put your etits on the kit and jack it off.... aheheheh
nikkiesteban is offline   Reply With Quote
Old 06-12-2006, 03:25 AM   #1691
rayman's Avatar
hi guys.......
You cant use it. Unless you dremel the motor mount on your tbo2r so you can find a pinion/spur combination.
Old 06-12-2006, 09:17 AM   #1692
nagatahawk's Avatar
set up for asphalt
as a base I use:
yellow springs
30 wt shock oil
yellow anti sway bars. you can tune turn in buy going to harder rear or softer front. or reverse depending upon how the car is cornering.
use standard droop. off power steering can be adjusted by increasing rear droop, on power grip by increaseing front droop.
raise the front top suspension link about 5 mils 1/4 inch from stock.
Tire choice yours, whatever everyone is using at your track. TCS is b3's.
In order the use the Evo motor mount and gears, you'll probably have to go the the Graphite plate lower chasis and covert to an evo.
hope this helps
nagatahawk is offline   Reply With Quote
Old 06-16-2006, 09:27 PM   #1693
i have a question about the TB02 kits. do they(normal tb02 sets) all come with the same hopups? i was looking on the tamiya site and it didn't mention ball bearings in the 2003 impreza wrc model, but they do in the 2004. does that mean the 2003 impreza doesn't come with ball bearings, or did they just not mention them? thanks.
Also, is there anything i should know about the tb02 chassis? anything fickle about it or might need to stock up on some parts that brake easily?
SSJChar is offline   Reply With Quote
Old 06-16-2006, 11:23 PM   #1694
ford_racing's Avatar
Send a message via MSN to ford_racing
I believe all the kits come with full ball bearings
The only parts I have broken on my car was the diff bolt, that was using a 10turn motor and tightened up fairly tight.
The car is almost bulletproof
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 06-29-2006, 08:26 PM   #1695
So i now have the tb-02, only problem is that I dont know how much camber or toe im actually getting, and i can't tell if its even on both sides. i ran the car for the first time today and the camber on the front left is set abit more negatively than the right, and i think i fixed that, but is there a way to know for sure by using stuff like a ruler or jazz like that? thanks.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
