Old 12-10-2005, 03:48 PM   #1591
ford_racing's Avatar
Send a message via MSN to ford_racing
The Ta05 is lighter...JUST
The TA04 is heavier by a fair bit
Weight is all dependant on electronics, thickness of shell tyres etc
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 12-10-2005, 04:31 PM   #1592
rayman's Avatar
I thought the tao4 was the lightest among the 3.
Not installing anything is the tao5 the same as a tbo2? Of course electronics, etc are also factors but how about just the kit is there a significant weight difference? I just feel my tbo2 accelerates slower than my tbevo same gearing,etc. It could be the weight I'm thinking.
rayman is offline   Reply With Quote
Old 12-10-2005, 04:53 PM   #1593
The Ta04 I was comparing against wasa the R version, without any electronics it felt heavier than a TB02 with full electronics without batts
ARC R11
Yokomo YRF001
AE B5m
Old 12-16-2005, 05:12 PM   #1594
Hawk6's Avatar
Trader Rating: 50 (100%+)
Default Quick Question
Can I run a 27 turn stock motor (NOT a silver can motor) with the plastic motor mount or do I need the aluminum one?
Thanks.
Hawk6 is offline   Reply With Quote
Old 12-16-2005, 05:39 PM   #1595
westerdude42's Avatar
02 is slightly lighter but not drastically. Use the aluminum motor mount. I mean you can put a mod motor in a stock TT01 but that doesn't mean you should.
Hedgehogs rule!!!
westerdude42 is offline   Reply With Quote
Old 12-16-2005, 06:41 PM   #1596
Hawk6's Avatar
My question was basically, will the plastic motor mount melt with a stock motor?
Old 12-16-2005, 06:51 PM   #1597
Hebiki's Avatar
Trader Rating: 26 (100%+)
when properly geared, no it will not melt.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-16-2005, 08:40 PM   #1598
I know from experience that when it gets hot and is under torque, it tends to twist and the pinion shaves the spur.
Hedgehogs rule!!!
Old 12-16-2005, 08:59 PM   #1599
Hawk6's Avatar
OK, thanks. I run a stock motor in my TB-02, but it has the aluminum motor mount. I just got a used TB-02 for my son, but I guess I better wait till I get the aluminum motor mount before he drives it.
Thanks for the input.
Old 12-21-2005, 07:57 AM   #1600
rayman's Avatar
Did I get this right? A tao4 r without electronics is heavier than a tbo2 with elec without batts? How is that possible?
i thought the tbo2 was the heaviest of the current tamiya tub chassis kits. Even the tt01 was lighter than this piggy. Hehe.
Old 12-21-2005, 02:56 PM   #1601
Thats what I thought untill I held the two of them side by side it is wierd
ARC R11
Yokomo YRF001
AE B5m
Old 12-21-2005, 04:05 PM   #1602
My tb02 weighs 1560 grams with full electronics/battery and body. The body was 100 grams.
Phenochilus is offline   Reply With Quote
Old 01-09-2006, 06:33 AM   #1603
Hi Chaps
Just acquired a TB02 for some serious drifting to accompany my TA05 touring car, was wondering what pitch gears come as standard on this beast, is it .6module or 48d.p. ??
Thanks in advance.
DA_cookie_monst is offline   Reply With Quote
Old 01-09-2006, 02:55 PM   #1604
Hi.
Im currently racing my TBO2R in a UK carpet championship running 27 turn stock motors. It is very competitive against yokomo BD's and TC4's, Im currently placed 7th in a 70 car championship. My problem is that I am regularly shearing the 2mm diff screws. Usually one a meeting. Out of frustration I gave my diffs to my mate who runs an evo 3 and he reckons they are built and tensioned correctly. I have swapped to standard evo3 diff cups from the TBO2R ones but still the screws break. The only thing I can see is that an evo 3 runs no shims according to the manual behind the diff bearings. The TBO2R runs 2 X 0.1mm shims. I have now removed these and have yet to try the car at the next meeting in 2 weeks. Have any of you guys had this problem.
cheers
Dave
DaveMorris is offline   Reply With Quote
Old 01-09-2006, 03:04 PM   #1605
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by DaveMorris
Hi.
cheers
Dave
Yes this is a problem
I have usually found that the thrust bearing is in backwards.
the screw head should be on the side of the thrust bearing that has the taper on the ID
Also make sure the thrust bearing is well graesed with Aw or something similar.
tamiyarcracer is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
