Old 09-14-2008, 11:18 AM   #1
Scottmisfits's Avatar
Default Kawada T plate same as AE?
I have a Kawada 12 scale car. I broke my T plate. I was wondering if anyone knew if the AE one will fit. I can't seem to find the Kawada parts anywhere in north america. The Kawada and AE parts look the same bit nobody around my area has them to actually find out.
Scottmisfits is offline   Reply With Quote
Old 09-14-2008, 05:58 PM   #2
Maybell's Avatar
I highly doubt they would work...
Since the AE car is designed with standard US messurments and the Kawada being metric I doubt it....
You are probably going to just have to try one to find out...unless a very experienced Japaneze 12th scale guy sees this thread...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 09-14-2008, 09:55 PM   #3
One of the guys showed up with the AE car tonight and he had a spare plate. It doesn't work. Anyone know of another one that might work? I don't know 1/12 scale so I have no idea which cars are metric and which aren't, what may work, what won't.
Anyone know a place in North America, preferably Canada who can get or stocks Kawada?
Old 09-14-2008, 09:59 PM   #4
Rob Burns's Avatar
The Corally SP12X uses a t-plate too. It should be metric but no idea if it is even close to the Kawada.
@ $16 each it's not something I'd gamble on but you can find them at T-bang:
http://www.t-bang.ca/catalog/product...roducts_id=269
Rob Burns is offline   Reply With Quote
Old 09-15-2008, 03:18 AM   #5
The Corally SP12X T-bar will not work properly because it use some plastic inserts instead of the plastic hub with the metal ball.
I have a couple of Kawada M300 Rsw, but I'm in Italy (not Japan ).....
Here in Italy there is a shop that sell kawada parts but I think that the cost of the spare and the shipment is rather high due to the current Euro vs USD exchange rate.
Also http://www.rc-direct.co.uk/ sells kawada parts, however i think there is the same problem.
Another solution is to buy some spare fiberglass (or carbon composite) sheet and find a generous guy with a milling machine.
Bye
Emanuele
Ema-77 is offline   Reply With Quote
Old 09-15-2008, 03:48 AM   #6
Joost K.'s Avatar
RCmodel Online in HK has the Kawada T-bars but my guess would be that an AE T-bar would fit. I used these in the HB C12 also and I just drilled the mounting holes up to 3mm. If that's the only problem then I don't see it
Anyway, for original Kawada T-bars... See the site from RCmodel Online in HK with the following part numbers:
- KA-RSR-2
- KA-RSR-2S
Joost.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
IMPORTANT: New Product Arrival Alert! (August 2008) rcmart rcMart.com Mega Online R/C Marketplace 106 12-11-2008 10:52 PM
Teamwave Lightning top plate (Polycarbonate) GymBeam Australia For Sale/Trade 3 06-02-2007 07:28 AM
Starter plate for Hyper 8! rcjunky10 R/C Items: Wanted to Buy 1 03-17-2007 01:57 PM
Wanted HPI Pro 2 Motor Plate SpidarX R/C Items: Wanted to Buy 4 01-15-2007 09:30 PM
Kawada sales in U.S. hardadz Electric On-Road 0 09-06-2005 08:36 AM
