SMC 4100 and 5200 Hardcase 7.4V 24C Lipos
#46
If you want to charge a 4000mah on 8000mAh (2C) with the ICE i think you have to put 50% charge limit and not 100%.Actually for a 5200mah pack you should put 65% charge limit.Correct me if im wrong.
#47
Got 2nd run today with 4100 pack, this time with full race legal 1500g weight. Love the pack as it give good punch whole 8mins in our spec race(3900KV motor), and faster than others non-brand LiPo...
But the wall of weight is indeed a bit... too much... At least this give me a perfect left-right balance right at 1503g
#48
#49
You can leave it set it to 8000mah @ 100% and it will be fine. The charger watches the voltage, not the capacity when it charges. You could set the 50% as a safety in the freak event that the charger didn't acknowledge the battery voltage and just kept charging at WOT. That could be bad....
#50
I'd like to know how much time someone gain by charging on 2C on cc/cv lipo charging mode.I assume you arrive to the cv point earlier and from that point it takes the same time until full charge 8,4v.
#52
Danny in the past i had more lipos from other "named" brands but they didn't last for long.And i haven't got the chance to try yours.But pretty soon i'll do it for sure.
#53
for 60bux, this thing is a good stuff. only slight massage to the gussets in a tt01 chassis and it fits like a glove complete w/room to tape a lead bar on the batt strap for balance. now i can consider spec car done. if i keep runnin 2wd mod, i will get another 1 to leave in it, more than enuff batt there. performed well last wk in the CR. only needing about 900mah for 5min heat WOW!!!
R
R
#54
right out of the package, the case looks like it isn't sealed "properly". i can see the solid green of the bottom case .... anyone else have this? is it normal?
#55
Hi Danny
I recently purchased 2 5200 SMC lipo's for my Mod TC. Just wanted to let you know that they are great so far...no complaints. Great power and awesome runtime.
How often should I balance them, I have the Thunder power 610C with built in balancer and how close should the cells be when balanced.
Thanks for your time
Doug
Doug
#56
Glad to hear you like our 24C packs. The response has been great on these packs so far.
Balance charging will not hurt the pack so if you have a built in balancer you can balance charge everytime. The 2 cells should be at the same voltage when the charge is finished.
#57
In stock?, where??????????????
Hey guys
when are there likely to be more stock hitting the shelves
Cheers
Geoff
Cheers
Geoff
#58
#59
the 5200 doesnt fit in the CR, even w/o foam block. only tried 1 b/c somehow i've lost my 4100. unable to find it. so put out over it. sux indeed. damn good battery.
R
R
#60
Sorry I missed this post. The glue normally used was changed on the first shipment and the new glue didn't work as well. You can apply a little bit of CA on the seams of the case and press them together. I raced some 5200s this past week and the cases stayed together without regluing.
