Old 01-02-2009, 10:10 AM   #46
Born2Run's Avatar
Originally Posted by M-Technic View Post
The ICE only charges at 1c but I can enter up to an 8000mah battery. Should I just enter 8000mah with a 100% charge limit? i.e. it will just charge at 8amps.
If you want to charge a 4000mah on 8000mAh (2C) with the ICE i think you have to put 50% charge limit and not 100%.Actually for a 5200mah pack you should put 65% charge limit.Correct me if im wrong.
Whatever
Born2Run is offline   Reply With Quote
Old 01-02-2009, 10:12 AM   #47
Born2Run's Avatar
Originally Posted by ttso View Post
Got 2nd run today with 4100 pack, this time with full race legal 1500g weight. Love the pack as it give good punch whole 8mins in our spec race(3900KV motor), and faster than others non-brand LiPo...
But the wall of weight is indeed a bit... too much... At least this give me a perfect left-right balance right at 1503g
So you added 270 gr more? WOW!!
Whatever
Old 01-02-2009, 10:19 AM   #48
ttso's Avatar
255gr iron weight (not using lead, save the planet)
edit: I do need to recheck it since I think the scale at track probably mis-cal already, as it should need not so many (or did my car really so under-weight?)
ttso is offline   Reply With Quote
Old 01-02-2009, 10:19 AM   #49
sportpak's Avatar
Trader Rating: 26 (100%+)
If you want to charge on 8000mAh (2C) with the ICE i think you have to put 50% charge limit and not 100%.Correct me if im wrong.
You can leave it set it to 8000mah @ 100% and it will be fine. The charger watches the voltage, not the capacity when it charges. You could set the 50% as a safety in the freak event that the charger didn't acknowledge the battery voltage and just kept charging at WOT. That could be bad....
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 01-02-2009, 10:34 AM   #50
Born2Run's Avatar
I'd like to know how much time someone gain by charging on 2C on cc/cv lipo charging mode.I assume you arrive to the cv point earlier and from that point it takes the same time until full charge 8,4v.
Whatever
Old 01-02-2009, 12:37 PM   #51
Company Representative
Danny/SMC's Avatar
You save about 25 minutes charging at 2C on a discharged pack.
You need to get one of our packs and add it to your signature that would make your collection of Lipos more complete.
Danny/SMC is offline   Reply With Quote
Old 01-02-2009, 12:57 PM   #52
Born2Run's Avatar
Danny in the past i had more lipos from other "named" brands but they didn't last for long.And i haven't got the chance to try yours.But pretty soon i'll do it for sure.
Whatever
Old 01-02-2009, 08:23 PM   #53
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
for 60bux, this thing is a good stuff. only slight massage to the gussets in a tt01 chassis and it fits like a glove complete w/room to tape a lead bar on the batt strap for balance. now i can consider spec car done. if i keep runnin 2wd mod, i will get another 1 to leave in it, more than enuff batt there. performed well last wk in the CR. only needing about 900mah for 5min heat WOW!!!
R
UltegraSTI is offline   Reply With Quote
Old 01-06-2009, 12:46 PM   #54
quantum's Avatar
right out of the package, the case looks like it isn't sealed "properly". i can see the solid green of the bottom case .... anyone else have this? is it normal?
quantum is offline   Reply With Quote
Old 01-13-2009, 03:09 PM   #55
dougmartin's Avatar
Trader Rating: 14 (100%+)
Thumbs up
Hi Danny
I recently purchased 2 5200 SMC lipo's for my Mod TC. Just wanted to let you know that they are great so far...no complaints. Great power and awesome runtime.
How often should I balance them, I have the Thunder power 610C with built in balancer and how close should the cells be when balanced.
Thanks for your time
Doug
dougmartin is offline   Reply With Quote
Old 01-13-2009, 03:15 PM   #56
Danny/SMC's Avatar
Glad to hear you like our 24C packs. The response has been great on these packs so far.
Balance charging will not hurt the pack so if you have a built in balancer you can balance charge everytime. The 2 cells should be at the same voltage when the charge is finished.
Old 01-13-2009, 06:09 PM   #57
loopedeloop's Avatar
Default In stock?, where??????????????
Hey guys
when are there likely to be more stock hitting the shelves
Cheers
Geoff
loopedeloop is offline   Reply With Quote
Old 01-13-2009, 07:45 PM   #58
MelvinLee's Avatar
Default Nexus Racing has them in stock.
Originally Posted by loopedeloop View Post
Hey guys
Cheers
Geoff
LELO LEE
MelvinLee is offline   Reply With Quote
Old 01-13-2009, 07:49 PM   #59
Registered User
UltegraSTI's Avatar
the 5200 doesnt fit in the CR, even w/o foam block. only tried 1 b/c somehow i've lost my 4100. unable to find it. so put out over it. sux indeed. damn good battery.
R
Old 01-13-2009, 10:05 PM   #60
Danny/SMC's Avatar
Sorry I missed this post. The glue normally used was changed on the first shipment and the new glue didn't work as well. You can apply a little bit of CA on the seams of the case and press them together. I raced some 5200s this past week and the cases stayed together without regluing.
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
Two (2) 4S 14.8V NeuEnergy 4100 30C/60C Lipos for sale SunnyHouTX R/C Items: For Sale/Trade 15 08-09-2008 11:49 AM
SMC 28C High Performance 4000mAh - 5000mAh Hardcase Lipos Danny/SMC Electric On-Road 420 04-24-2008 03:36 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
F/S dsl modem speed steream 4100 sirio man Other Items: For Sale/Trade or Wanted to Buy 2 05-02-2007 08:43 AM
