Old 11-06-2008, 08:06 AM   #16
Ran the 5200 pack in modified last night with a 4.0 turn and the pack was very good.. I could not tell the difference between the two packs on the track at all.. Danny awesome job..
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 11-06-2008, 08:12 AM   #17
Davidka's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Danny/SMC View Post
Here are the cycle numbers on the first cycle on 2 random packs of each. I charged at 2C and discharged at 35 amps with the room temperature at 70 degrees. The voltage sensing leads are attached to the power leads.
4100/24C:
429 (4170mAH) - 7.29 - 7.8
428 (4161mAH) - 7.29 - 7.9
5200/24C:
534 (5191mAH) - 7.35 - 6.6
537 (5220mAH) - 7.37 - 6.4
If I'm reading that right, the 5200 pack shows slightly better average voltage and significantly better ir (1.2-1.5 better)? I've been running Lipo long enough that I'm a bit foggy on battery numbers.
Old 11-06-2008, 08:59 AM   #18
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Hey David,
Not Danny by any means but generally what everyone has noticed is that with Lipo's a higher MAH battery will always be better as long as your comparing brand to brand (Smc to SMC, EP to EP, IP to IP) and comparing the same C rating to C rating (35C to 35 C, etc).
Its a little strange looking at because everyone was so used to looking at NIMH cells where if you had higher runtime or MAH you usually had lower voltage.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-06-2008, 10:26 AM   #19
Davidka's Avatar
Yep, I get that part (ie. 35c=35x the battery's capacity current/amp output). I guess by the "new math", higher capacity is always going to perform better, in every way than lower capacity with lipo.
Old 12-02-2008, 10:29 AM   #20
johnnyshore's Avatar
Trader Rating: 72 (100%+)
Any recommendations for an inexpensive stand alone balancer for the 5200 packs?
Thanks!
johnnyshore is offline   Reply With Quote
Old 12-02-2008, 12:18 PM   #21
quantum's Avatar
when will great planes have these available? my local shop can't get these yet...
quantum is offline   Reply With Quote
Old 12-02-2008, 12:20 PM   #22
quantum's Avatar
Originally Posted by rcracingkid View Post
Skuba go with the smaller case and it will just about drop in...the 4100, il help get ya going...the 5000case needs some major dremelwork.
mike, which class do you race the 4100 with?
Old 12-02-2008, 01:09 PM   #23
Company Representative
Danny/SMC's Avatar
For a balancer that you will plug with your charger you should you can get and Atroflight Blinky , Common Sense also has one and the Electrifly Eqquinox.
Our Balance connector is the JST-XH.
Tell your Hobbyshop to order our packs from Horizon if Great Planes is out of stock. Were getting a new shipment in this week and will ship out backorders.
Danny/SMC is offline   Reply With Quote
Old 12-02-2008, 01:34 PM   #24
Oh? I thought I read somewhere that the blinky didn't work with Align type plugs?
Old 12-02-2008, 01:48 PM   #25
Danny/SMC's Avatar
I'm pretty sure it does as my friend who flies Helis uses our 800 packs and they have the JST-XH connector and he uses a Blinky. You may want to email Astro Flight to make sure as my friend could of altered something.
Old 12-02-2008, 03:06 PM   #26
Gotcha...I'll do that...thanks!!
Old 12-02-2008, 05:25 PM   #27
hanulec's Avatar
Trader Rating: 27 (100%+)
mike runs 10.5T to 17.5T mostly in his Losi type r
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-02-2008, 09:25 PM   #28
rc pete's Avatar
Yes, a Blinky fits the balance connector fine. I use it on my Lipo every few cycles (it's a 28c 4000, but I'm pretty sure the balance connector's the same as on the 24c packs).
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 12-02-2008, 09:30 PM   #29
Danny/SMC's Avatar
Thanks for the info. All our car packs have the same balance connector.
Old 12-09-2008, 08:04 AM   #30
ttso's Avatar
I'm trying to buy 5200 24c before x'mas but can't find anywhere (online shop), any idea who still have them in stock?
ttso is offline   Reply With Quote
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
Two (2) 4S 14.8V NeuEnergy 4100 30C/60C Lipos for sale SunnyHouTX R/C Items: For Sale/Trade 15 08-09-2008 11:49 AM
SMC 28C High Performance 4000mAh - 5000mAh Hardcase Lipos Danny/SMC Electric On-Road 420 04-24-2008 03:36 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
F/S dsl modem speed steream 4100 sirio man Other Items: For Sale/Trade or Wanted to Buy 2 05-02-2007 08:43 AM
