Gear Lubricants
Old 09-10-2003, 09:57 PM
Smile Gear Lubricants
anybody uses lube on their gears? on the spur & pinions?
i'm thinking bout using some dry lube like the trif-flow stuff..or grease..
inputs?
versa is offline
Old 09-10-2003, 10:38 PM
rc_bam226's Avatar
For gears, most chassis require either no lube, or a very viscous lube, specifically diff lube. Don't use greases or anything like that, you'll produce parasitic drag on your drivetrain, that'll defintely slow you down. Sure use the dry stuff, but don't over-do it, you'll end bogging down the drive train.
rc_bam226 is offline
Old 09-10-2003, 10:42 PM
holycow's Avatar
Graphite...
holycow is offline
Old 09-10-2003, 10:50 PM
On the TC-3 diffs, I've had good luck with white lightening, that's sold at bike stores.
zxracing is offline
Old 09-11-2003, 12:20 AM
Trader Rating: 21 (100%+)
white lightning is crap, at all costs do not use white lightning. it will turn into wax and not matter how little you use it will procuse drag in the drivetrain. i suggest that you ask your local bike show about krytech, if they have not heard of it, then go with a fluid that is put out by paragon ( the same company that makes the popular line of ground FX traction compounds) called ultralon. it is a dry lube that goes on wet and dries into an almost teflon like coating on the gears, this stuff is amazing.
but what ever you do... no white lightning...
peter
peter_robinson is offline
Old 09-11-2003, 12:38 AM
my kit came with some grease stuff to be used with the diffs.
but im asking bout lubing the gears, spurs & pinions..
versa is offline
Old 09-11-2003, 05:36 AM
CRASH's Avatar
Trader Rating: 26 (100%+)
A regular bar of soap works the best.
Later,
CRASH is offline
Old 09-11-2003, 05:53 AM
peter,
Thanks for the info, I"ll check out krytech. Although in my experience, I haven't had any problems with my white lightening turning into wax...
zxracing is offline
Old 09-11-2003, 07:48 AM
dirk's Avatar
Later,
you gave my secret away!
dirk is offline
Old 09-11-2003, 08:04 AM
soap? seriously? for the spur & pinion?
versa is offline
Old 09-11-2003, 08:20 AM
You can also take the krytech and allow your spurs to soak in it overnight, remove them and allow them to airdry.... WORKS great..... However DONOT do this with diff gears or diff pullies, The lube in the ballholes can allow slippage....
IMPACTPLAYR is offline
Old 09-11-2003, 08:44 AM
holycow's Avatar
What is this trick with plain old soap?
holycow is offline
Old 09-11-2003, 11:25 AM
CRASH's Avatar
Just rub it on your spur and pinion. Makes a nice lubricant. Makes them run extremely quitely and wear is reduced. There is a small tech article about it in the new RC Car Action.
Later,
CRASH is offline
Old 09-11-2003, 11:49 AM
popsracer's Avatar
Default White Lightning
Guys;
If you place a drop of White Lightning on a non-porus surface and allow it to dry, it WILL become waxy. However, I have NOT seen this when applied in a correct manner. A very small amount is all that is needed.
There is also a Dry spray Lube availible at Home Depot's.
popsracer is offline
Old 09-11-2003, 01:25 PM
i have seen the white lightning spray, but i have yte to use it becuase of my experience with the other stuff.
