Old 09-09-2008, 07:23 AM   #31
Trader Rating: 38 (100%+)
Originally Posted by John Tag View Post
Also beware of under gearing. I personnally have seen some motors get really hot and seize from that. Being way over reved, That will heat it up a ton also. I know at some tracks I have run,I have geared up and dropped 20* at times....
I have seen the same John. That's always nice, go faster and stay cooler.
or8ital is offline   Reply With Quote
Old 09-09-2008, 12:09 PM   #32
Every brushless motor that I've burned up has been because of abuse. Some of the motors that are out there don't have a thermal sensor and won't shut off when they overheat internally.
Clamp-on heatsinks with fans will help reduce the external motor temps a lot but probably don't do as much for the internals and rotor. Cooling a motor in any way usually means that you need to gear to a lower temperature at the end of the run to be safe.
I've tried electric cooling 17.5's in 12th before and to be honest, it really only helps for the first 30 seconds or so. Plus if it's humid out (summer) you end up with a lot of condensed water on the motor both inside and out. Condensation isn't a good thing on the sensors especially with a speedo that automatically switches to brushed mode when it loses the sensors (LRP).
I burned up a couple of motors this year due to abuse and it's hard on everything in the car. The speedo gets screaming hot and it's hard on the ol LiPo's. Fortunately, the Tekin that I'm running will desolder it's self from the pack before it burns up.
Fred_B is offline   Reply With Quote
Old 09-09-2008, 01:14 PM   #33
TRF415boy's Avatar
Originally Posted by Dragonfire View Post
I would tend to think that mayb you guys have just been unlucky. It may just be that you track is hard on motors (large tracks mean you spend more time at high rpms)
I did some motor testing last weekend to compare performance. On a open track I ran 3 3.5t on 5cell till they dumped to compare on track runtime as well as performance. All 3 ran just over 7 mins and went strong to the end. Hottest motor after a run was the LRP (98c/209f) though this motor always runs hot. Even though they were hot all three motors did same lap times until the very final lap. I would say that as long as its not burning hot the temp has very little effect on brushless motors.
Lol
2 possibilities:
1 - I need to know what cells you used !
2 - you're way under geared if you can last 7 minutes with a 3.5T in 5-cell mod !!!!!!
TRF415boy is offline   Reply With Quote
Old 09-09-2008, 08:39 PM   #34
What would be under-gearing? like a FDR of 7 for a 13.5 for example?
stocker is offline   Reply With Quote
Old 09-10-2008, 08:10 AM   #35
Barry White's Avatar
I dunno what sensor whire does what but as this driver at the Japanese nationals did and a lot lot of other drivers. Not al the whires are connected.
Barry White is offline   Reply With Quote
Old 09-10-2008, 03:15 PM   #36
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The pic shows only the battery wires desoldered from the pack. The sensor harness and 3 leads to the motor are attached. Looks right to me.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-10-2008, 03:21 PM   #37
KHoff7's Avatar
I know what you mean, some of the actual sensor wires have been removed, but it may be an optical illusion.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-11-2008, 01:53 AM   #38
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
normally d wire tat remove is d cut off wire meaning d esc wont cut off when d motor overheat...
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-11-2008, 02:11 AM   #39
Number09's Avatar
That's what I thought, I would love to know how hot they get those motors!!
I am in fact a very humble person. I am WAY more humble than anyone. Help me spread the word
Number09 is offline   Reply With Quote
Old 10-02-2008, 02:23 PM   #40
Just to update everyone on this. I think my theory proved true. Everyone at our track that had been chilling their motors laid off the last 3 races of the season and no motor failures.
Old 10-03-2008, 02:06 AM   #41
Trader Rating: 198 (100%+)
But the outdoor temps the last few weeks are about 20 degrees cooler than summer.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 10-03-2008, 07:03 AM   #42
No they haven't been.
Old 10-03-2008, 07:30 AM   #43
Originally Posted by or8ital View Post
Some of the motors failing are geared very conservatively (for example this weekend someone had a Losi 10.5 geared at a 5.2 FDR fail). Some of the ones that have lasted all summer are geared very aggressively. The difference I've seen is just the motor cooler. But thanks for your contribution.
not sure 5.2 is conservative it seems low (more like 13.5 gearing) to me.
CPD Racing
chris_dono is offline   Reply With Quote
Old 10-03-2008, 07:34 AM   #44
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
5.2 fdr is very conservative for a 10.5 , here in Florida we gear the 10.5's around a 5.2 and the 13.5 in the low 4's.
Old 10-03-2008, 07:56 AM   #45
we figured out the issue as noted above. it wasn't heat or gearing. it was motor chilling causing the motors to go bad. Heck, since we figured it out someone came off the track at 225 b/c they forgot to hook up their fan and no problems at all.
Motor coolers carolinatc R/C Items: For Sale/Trade 2 08-19-2008 04:56 AM
motor coolers and brushless motors josh short Electric On-Road 3 07-07-2008 12:38 PM
** Motor Coolers ** nordheim R/C Items: For Sale/Trade 72 10-17-2006 08:50 AM
Motor Coolers micros_rock R/C Items: For Sale/Trade 26 06-23-2005 01:29 AM
motor can coolers SRW141 Electric On-Road 12 01-24-2004 04:38 PM
