Tamiya 415 & ta05ms Wheel Bearings???
does any one know a place to order the 9x5x4 wheel bearings for the 415 and the ta05ms in quantity. I'd like to order about 30-40 of these bearings and cannot find a single place to order then in quantitiy.
rc-mushroom will let me buy them 4 at a time... but that's not gonna cut it.
Thanks in advance.
Thanks in advance.
Instead of going through the cost of stocking up on 950 bearings, another option is to upgrade to the TRF416/TA-05 IFS-R/TB-03 front and rear uprights which use a 1050 bearing which is a bit more reliable than the 950 bearings.
that's a steller idea. So I would need:
Front knuckles (L/R)
Rear knuckles (L/R)
8 1050 bearings
Is this correct? I assume since these parts are used on the IFS that they fit the front hub carriers, and suspension arms/hinge pins perfectly? And also since these are 10x5x4 I can just re-use the same axels because the ID is the same right?
Rear knuckles (L/R)
8 1050 bearings
The 416 uses a 1.5mm spacer between the two bearings, while the 950 bearing cars use a 1.9mm spacer. Now either the 1050 bearings are wider, or the new axle is shorter...
