Old 09-08-2003, 06:40 PM   #1
Switch Blade's Avatar
Send a message via AIM to Switch Blade
Default TC3 Glitching up the wazo
I am really stuck....my friend and I went to trackside a week or 2 ago and his TC3 was glitching very badly. First he had this thing from his esc, i think is is a power cap....something i dont really know, but anyways it was taped to his servo so we took it off but there still was a glitch. So we took it up to a guy that worked there, and he said that we could try swaping out the electronics to rule them out, and we could tap on the servo case very lightly, but that didnt work. I was thinking that since his reciever wire was touching the chassis that that was the cause but that didnt work. I was thinking that his motor needed a cleaning, and we didnt try that so mabe that would help. Isnt there something that you can solder to ur motor and it will reduce glitching???? He is using an am radio, but even my am never glitched so i dont think that that is the cause, or is it? Or mabe his crystals are messed up???
So we didnt try to clean the motor, swap the crystals or the radio gear.
Any Ideas??? Thanks
College
Switch Blade is offline   Reply With Quote
Old 09-08-2003, 07:19 PM   #2
if you got the RTR then it is probubly the raido because the one it comes with is junk, if you don't have the RTR you should make shure that you have a capassitor soldered between the negative and positive leads on the motor.
igkyoa is offline   Reply With Quote
Old 09-08-2003, 07:52 PM   #3
its not mine, and no it isnt the rtr....mabe the capassitor is the ....but he has a monster stock motor and so do i and i have never had a problem with glitching...i also thought i heard that the monster's have a capassitor already soldered on???
College
Old 09-08-2003, 09:21 PM   #4
When was the last time the comm was cut and new brushes put in?
Headbanger is offline   Reply With Quote
Old 09-09-2003, 12:50 PM   #5
fast-ho-cars's Avatar
if your car is over 6-mo old....check all your bearings. i was racing outdoors and indoors. i started having weird glitching problems, after switching all electrics and no help, i went thru the car . i had 5 bad bearing
one on the mainshaft in frt of the spur.
four on the axles
they were locked up or crunchy/very rough. causing metal to metal sweaking/interferrence
fast-ho-cars is offline   Reply With Quote
Old 09-09-2003, 02:45 PM   #6
speedxl's Avatar
R/C Tech Charter Subscriber
sometimes the motor get cracks ithe magnet or the magnet gets loose.
has he hit anything hard enough to crack a radio component.
also check the transmitter batts and different set of crystals.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 09-09-2003, 07:45 PM   #7
Try doing a search on this subject. I know I have responded to some subjects exactly like this, and after a while it gets kinda boring saying the same things over and over (especially because there's so many possiblity's). But here are a few quick things I'll mention:
1. Make sure that none of the wires are frayed or that the antenna is damaged. Also if you have cut the antenna you need to buy a new one.
2. Don't mount the reciever on the servo if you have.
3. Mount the reciever on 2 or 3 pieces of servo tape.
4. Keep any power wires (motor and battary wires) away from any signal wires (antenna, servo wires, esc wires). So just try to seperate those wires as much as possible.
5. Check transmitter battaries.
6. Try a new pair of crystals.
7. Search for "glitching problems"
Hope this helps!
racerdx6 is offline   Reply With Quote
Old 09-09-2003, 08:09 PM   #8
JoshR 85's Avatar
HeY!!! i think you should have ur freind take apart the car and clean it and then check to see if crystals are good, but mayb since ur on am if you on odd number freq. and the metal beams that trackside has it could cause glitching. or mayb one of his wires has a slit in it and is close to another open wire. if ur freind has the blue alum. shaft and the atenea wire or any wires that are cut that are close to the shaft could cause glitchin. mayb it's just that the rceiver is old.???
JoshR 85 is offline   Reply With Quote
Old 09-10-2003, 08:19 PM   #9
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Yes, Josh had this problem awhile ago at trackside with the big metal beams. Got an FM radio, no problems since
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-10-2003, 08:34 PM   #10
JoshR 85's Avatar
HeY!!!
yeah i still remember that...... man that sucked bcuz like i had no problems for like first few months then all a sudden one day bam glitches galore... lol but i love my fm radio man...
Old 09-11-2003, 01:58 PM   #11
holycow's Avatar
What is a "wazo" really?
holycow is offline   Reply With Quote
GTB Glitching Vegaspilot Electric Off-Road 4 06-11-2006 10:28 AM
Glitching berger Electric On-Road 9 06-04-2004 03:32 AM
Glitching Help CraigHandley Australian Racing 6 02-29-2004 11:56 PM
Glitching on my 3PK FUK_WRX Electric On-Road 10 08-15-2003 09:50 AM
glitching tdragon Electric On-Road 10 06-17-2003 11:03 AM
