Old 09-09-2003, 06:40 PM   #16
I heard that story was 1/10 touring car & a Lrp speedo
rcconcept is offline   Reply With Quote
Old 09-10-2003, 05:20 AM   #17
Vegetto's Avatar
Hey,
You can't beat a Novak !
I have a TC2 had it for about two years now, have not had one problem with it !!
Couple of my mates have the GT7 and they wouldn't trade it for anything..
My 2 cents worth !!
Later guys
Vegetto is offline   Reply With Quote
Old 09-10-2003, 06:25 AM   #18
hobbipro's Avatar
Trader Rating: 21 (100%+)
Thumbs up
I'd recommend the GT-7 to anyone, even a newbie. The instructions are easy to read and understand. The performance is top notch. There are 7 profiles to choose from, which one is up to you, actually the 7th profile is for customizing if you desire. And as stated in previous posts, Novak's customer service is as good as it gets. I wish all manufacturers were as easy to deal with.
hobbipro is offline   Reply With Quote
Old 09-10-2003, 08:13 AM   #19
Hi,
Keyence set-up is not time consuming . . . but it is more expensive than Novak.
John
John Robb is offline   Reply With Quote
Old 09-10-2003, 02:16 PM   #20
dasgruvn's Avatar
looks like I'll be getting a Novak GT-7 soon ...anymore info would be appreciated
dasgruvn is offline   Reply With Quote
Old 09-10-2003, 03:35 PM   #21
Super Moderator
Grizzbob's Avatar
There is one hing I think you should be careful about, I have seen guys mess their GT7's up, but I think it was because of user error in soldering the wires on it. To be safe, make sure you use a grounded soldering iron(a grounded one should have a 3 prong plug for the AC outlet), & be careful not to hold it to the wire terminals for too long, or else you could end up damaging something on the circuit boards....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-10-2003, 07:49 PM   #22
JoshR 85's Avatar
HeY!!!
I love both of my GT7's i got one of the new ones w/ the wiring harness bcuz i got one when it first came out and they put the wiring harness out because they've been having troubles w/ them blowing up so they think that solved the problem... i hope it did. i also love it because it has the different setups for your driving style.
JoshR 85 is offline   Reply With Quote
Old 09-11-2003, 09:02 AM   #23
Rob Mincey's Avatar
I've had 2 GT7's and I'm now using the Keyence Zero V Extreme. Both are good units, performance wise, but I was disappointed in the durability of the GT7. My first GT7 died after catching a corner dot and tumbling end over end into a wall. I assume the sudden stop was just too much for the internals to handle. Oh well, mailed off to Novak, and had a replacement (new, not refurbed) in 2 weeks.
The second GT7 shorted internally, and melted the case. Mailed it back to Novak, and had a new, not refurbed, unit in less than 10 days (didn't even miss a race.)
Bought the Keyence, and haven't had a single problem with it. The Keyence seems more "punchy" than the GT7, even when the profiles of each are very similar. I can't be sure, but this might have something to do with the Keyence's lower "on resistance."
Anyway, I think you'll be happy with either. The 2 GT7's that I had were first generation, and from what I hear, MANY people had problems with the early units. It's nice to see that Novak has addressed some of the concerns with the new harness.
For customer service, you can't beat Novak.
My two cents,
Rob
Rob Mincey is offline   Reply With Quote
Old 09-11-2003, 09:27 AM   #24
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
wats bad about the keyence?
cHckbOY5 is offline   Reply With Quote
Old 09-11-2003, 09:32 AM   #25
Rob Mincey's Avatar
As far as I'm concerned, nothing.
The unit has performed extremely reliably. Plus, I like the fact that my ESC says, "Hello" when I power it up, but I'm wierd like that.
The only downside I see to the Keyence is the price. It's about $35-40 higher than the GT7.
I can't comment on Keyence's customer service since I've never had to use it, but the owner of the LHS says it's second to none.
Rob
Old 09-11-2003, 01:04 PM   #26
dasgruvn's Avatar
Default ok, GT-7 vs LRP 7.1
now an LRP 7.1 has stepped in...any info?
Old 09-11-2003, 01:34 PM   #27
Hi guys,
what is the drag brake with the prog #7?
What set up do you use in touring modified (asphalt & rubber tires) with the custom program?
Hugo is offline   Reply With Quote
thoughts on 8-t rjs_13203 Nitro Off-Road 14 09-02-2008 02:00 PM
thoughts on vrc TheDon502 Nitro On-Road 12 12-06-2007 05:02 PM
Could I get your thoughts? losi guy Buyer/Seller dispute and Feedback discussion forum 4 11-15-2007 07:37 PM
What are you thoughts on this one? Exposure Chat Lounge 0 10-28-2004 11:13 AM
Thoughts on the HPI .12R XS Darkseid Nitro On-Road 6 11-21-2003 07:59 AM
