#'s on Trinity Monster Metals >
Old 09-07-2003, 10:44 PM
Default #'s on Trinity Monster Metals
Hi everyone, while not being out for long, what is the best #'s you have seen on these new cells?
It seems like trinity is doing the right thing and putting more accurate numbers on the cells
Besercoe is offline
Old 09-07-2003, 11:57 PM
ScottyP's Avatar
Default EPIC GP numbers
Besercoe,
Best I've seen is 420, 1.185 volts at 30amps. I think you know what packs they are... I sing their priases all the time!
Cheers,
ScottyP
ScottyP is offline
Old 09-07-2003, 11:59 PM
holycow's Avatar
What cells might you be referring to?
holycow is offline
Old 09-08-2003, 05:04 PM
Default Re: EPIC GP numbers
Originally posted by ScottyP
Besercoe,
Cheers,
ScottyP
ScottyP - i know what packs, but i have also seen those numbers on local packs, which we all know are not true.
You cna only compare like with like, isnt there anyone out there who has bought or seen the ugly zebra epic cells, and if so what numbers have you seen?
Besercoe is offline
Old 09-08-2003, 06:02 PM
ScottyP's Avatar
Besercoe,
I just call it as I see it.... of course you can only compare like with like.
Any tool can backyard match a set of cell at 20 amps and come up with 1.2volts +.
I believe the company in question (Kinetix for anyone wondering) uses industry standard CE Turbomatchers @ 30 amps.
Scotty P
ScottyP is offline
Old 09-08-2003, 10:47 PM
Trader Rating: 83 (100%+)
I saw some packs at my LHS. Nothing different or special. Here is the deal.
A distributor buys directly from GP. GP will hand pick a small percentage of your order and in turn charge quite a bit more. What happens is: When your case or cases arrive there is supposed to be "more good" cells than before. So the 1.17 and 1.18 batteries will be more common. It is the EXACT SAME cell. Only difference is when buying a case you're "probably" going to have "more good" cells.
The Epic cells I saw were 1.16 and 1.17 400+. I am not sure how accurate Trinity's numbers are. I do not run their batteries. My personal recommendation is go with Fukuyama Racing. Great batteries and a great group of guys.
My $.02.
RBLove is offline
Old 09-09-2003, 12:33 AM
black-knight's Avatar
Default Re: Re: EPIC GP numbers
i'll vouch for the numbers on my "local" GP packs, matcher settings are as per epic / trinity / SMC units. All my local Fantom packs are matched at 30amps on CE's.
black-knight is offline
Old 09-09-2003, 01:31 AM
ive seen 6 zebra at my local shop most 1.16 some 1.17volts 410ish in run time
syntex1 is online now
Old 09-09-2003, 05:56 AM
CRASH's Avatar
Trader Rating: 26 (100%+)
I just ordered some cells form Kinetix, they are all 1.175 and up with 400+ run time. They are the new EPIC cells. All of Kinetix's cells are done on CE Turbomatchers at 30 amps as stated by ScottyP.
Later,
CRASH is offline
Old 09-11-2003, 02:23 PM
speedxl's Avatar
i ve been running the xspower batt for a while they are big here in florida and the numbers run about 1:16 to 1:17 for about 410 to 430 secs. and thier done on turbomatcher s , he treats the batts with care and they last longer some of these companys are zapping the batt excessivly and they dont last . try them and you guys will be happy.
speedxl is offline
Old 09-12-2003, 08:42 AM
kt racing's Avatar
Buy promatch and you dont' have to worry. Jeff R is the best.
kt racing is offline
Old 09-12-2003, 01:04 PM
Moderator
StephenSobottka's Avatar
Every pack i have bought from promatch is awesome. Jeff is an awesome guy and ships very fast. 1.173's my newest
StephenSobottka is offline
