Old 08-28-2008, 08:49 AM   #1
Default Losi JRXS and lipo
Hey guys,
does anybody run a jrxs with a lipo battery? Is it even possible to do?
Rocco
RIannitto is offline   Reply With Quote
Old 08-28-2008, 09:05 AM   #2
Tubaboy's Avatar
I don't personally, but I have seen a few cars that have. Not sure the details, but it actually looked easier to manage since the battery loaded in from the bottom.
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 08-28-2008, 09:12 AM   #3
I know you can with the type R, but I heard you couldn't with the jrxs.
Old 08-28-2008, 09:47 AM   #4
MikeXray's Avatar
Trader Rating: 73 (100%+)
They fit 3200 sized packs.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-28-2008, 10:11 AM   #5
Is that a hardcase pack?
Old 08-28-2008, 10:17 AM   #6
MikeXray's Avatar
Yes, look at the orion 3200, that case size.
Old 08-28-2008, 10:56 AM   #7
J@UNE's Avatar
Hi Mike, Have you tried it?
My 3200 didn't fit unless I removed the top deck or removed the bevel under the pack. They cant slide in... Once fitted, The connectors are under the bulkhead on both sides... The pack would have to be hardwired...
J@UNE is offline   Reply With Quote
Old 08-28-2008, 11:06 AM   #8
Suspended
Check the Type R forum, various people are running several different types of lipo's. I am running a 3200 soft case lipo in mine with a steel tray.
Wes Briscoe is offline   Reply With Quote
Old 08-28-2008, 11:43 AM   #9
MikeXray's Avatar
Haynes had one in this mid motor car his little bro was running for a while, I'm not sure if he had to modify it like you did or not, I'll check with him when he gets back from IIC.
Old 09-01-2008, 10:45 PM   #10
firehawk119's Avatar
I run the Type R and i use the Orion 3200 hardshell pack. If you set the connector side forward it will clear the upper deck next to servo saver. The only problem i had was adding weights under the battery on the lipo battery tray. It shoved the battery upwards and rubbed against both side pulleys. I "dremeled" notches in the battery case( very carefully and patiently) so no more rubbing occured. Another solution if class weight is a concern is putting weights on top of the battery in the lower shelf area. But this slightly raises the roll center so you'll have to experiement and see what worls best.
"If you're fast you might last...slow you gotta go!!"
firehawk119 is offline   Reply With Quote
Old 09-28-2008, 05:57 PM   #11
Default JRX-S PRO
Not the Type-R. I see plenty of "R"s with lipos but none in the mid motor, older PRO model. That said, has anyone run lipo in their JRX-S PRO and if so what battery? All I need is what battery, I can figure it out from there but, if you want to, please describe any chassis mods.
RJ
raj1 is offline   Reply With Quote
Old 09-28-2008, 06:31 PM   #12
Yeti35's Avatar
RJ
You have to run a softcase lipo in the car since it was not desigend to run Lipos at all. The Orion 3200 does not fit even though it looks like it would. The case is too big. Not worth modding/hacking the car to get a hard case lipo to fit.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 09-28-2008, 07:05 PM   #13
J@UNE's Avatar
The smc look close, not alot of dremelling required but im afraid the diff puley would rub on the pack...
Jon Gagnon
DirtTrax - Team FLR
Old 09-29-2008, 07:34 AM   #14
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
does anybody know if a smc 2 cell 5000mah will fit into a jrxs pro sedan
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Old 09-29-2008, 08:04 AM   #15
J@UNE's Avatar
The 4000 doesn't fit without modification. Like I said, even with the bulkhead dremeled, The diff puley rubs against the pack. You would have to shave the hard case.
It will be impossible to fit the 5000 imo.
Jon Gagnon
DirtTrax - Team FLR
team Losi JRXS TYPE R Steel Lipo tray TJames987 R/C Items: For Sale/Trade 1 08-10-2008 08:32 PM
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
losi jrxs lipo,s rhino20 Electric On-Road 6 12-23-2007 05:14 PM
wtb: LOSA4312 Losi Steel Lipo Tray for Jrxs Chris Furman R/C Items: Wanted to Buy 7 11-18-2007 08:48 AM
Onroad clearance Losi JRXS Type R, Jrxs and CRC T-fource pablo101 R/C Items: For Sale/Trade 32 07-30-2007 06:24 AM
